Question about Mitsubishi WS-65809 65" Rear Projection Television
Red convergence, cannot adjust left to right
My mits ws-65809 got hooked up to a nintendo64 & now the red is pushed over about an inch. i cannot adjust it left to right on the convergence menu, but it will adjust up & down. i think my problem is just the left-right adjusment. any ideas on how to fix it?
    Scholar:
  • 90 Answers
The Nintendo had nothing to do with a convergence problem. It could be in your conv generator board, but very unlikely. Chances are it's in the ICs.
Go in and find the conv ICs, they will be mounted on a
big heatsink and the wires going to the conv yokes will
most likely plug in somewhere closeby.
Conv ICs are the workhorse of the CRT RPTV, and it is
not unusual at all for them to need to be changed out
at some time in the life of a CRT RPTV.
Mr Bob
Comment by MrBob84, posted on Feb 04, 2008
PS -
The wires for the conv yokes at the CRT necks are the
thin ones. The thicker ones are for the hor and vert
sweeps, which must never be disconnected from their
circuitry during
CRT operation.
If your beam loses sweep on any of the CRTs, it will
instantly score/gouge your phosphors on your CRT faces,
vaporizing the phosphors there and ruining the CRTs.
The beam is very powerful, but in normal operation
moves incredibly fast, not damaging anything. Any
slowdown of the movement of the very powerful beam that
draws the picture, acts like the searing vaporizing beam in Tom Cruise's War of the Worlds.
Posted on Feb 04, 2008
    President:
  • 4,402 Answers
Replaced convergence amp ic's
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Jan 14, 2008
Curved top bottown, now ws 65809 turns off.
Your convergence has failed and need to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed.
You can get the parts and instructions from www.TvRepairKits.com
Apr 24, 2011 | Mitsubishi WS-65809 65" Rear Projection...
SCREEN HAS VARIES RED -BLUE-WHITE- LINE SHOWING, I TRIED USE THE
It needs to be repaired by having the convergence ICs replaced or resoldered (if intermittent).
Parts are STK 392-570. Be sure to use thermal paste on the ICs.
Jul 02, 2010 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi 55859
if i understand you right your blue convergence is off? and you have tried to go into the adjustment for the convergence? now do you crosshairs move up and down and left and right? on bpth red and blue. I see two possiblitys for this your convegence output ics commonly called stks or and you convergence ouput resistors. not a difficult repair for most shops and aroud 250 for parts and labor the ic run about 45 apeice
Jun 19, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Convergence is off - Blue and Red are fine Green will not line up
On most units, the Green is constant and the Red and Blue are adjustable. Here are 2 links on how to manually adjust the convergence. There is a menu option using the remote control. Once there, you will find step by step procedure on how to adjust the convergence. Hope this helps answer your question. All the best!
Greg
http://www.fixyourowntv.com/menumitsubishi.php
http://www.ehow.com/how_2034880_perform-convergence--tv.html
May 23, 2009 | Mitsubishi WS-65809 65" Rear Projection...
No Red, can't adjust Red convergence, Blue works fine
looks like the red "bulb" has blown.
you need to replace but can be expensive.
Apr 28, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi Rear Projection 65" tv picture becomes blurred bouncing right to left and color is red & green. TV is 8 years old approx. Any suggestions. Have not had any problems prevoiusly. First it woudl...
Sounds like possible solder connections on the convergence ICs. If so, you will see the red, green, and blue not lining up on ever input and even the mits menu. If you can bump it to correct, its just a solder connection, but if its out all the time then the ICs need replaced. This is a difficult repair only recommended for skilled technicians (40 solder connections + possible re-alignment needed)
Dec 03, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Mits 55908 Convergence problem
Good Day, John;
It sounds like the Convergence IC's have poor solder connections, by re-soldering the convergence output IC's should solve your problem. The IC's are large and mounted to large silver "heat sink" with STK 392 # on them. Good Luck, big IRISH.
Aug 29, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Red blue are separated
Good Day;
From what you say it sounds like the Convergence IC's have failed. Part number 267P150010, STK392-570, replace both IC's. They are on the middle board secured to a large heat sink.
Aug 17, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Convergance
youre most likely needing to change the convergence Ics
Jun 24, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi WS-65809 65" Rear Projection Television Logo
82 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
