Question about Lucent Lands Phones
ISDN 8510T
We have the ISDN 8510T phone one of them I am not able to progam to get any signal. I wanted to know what keys or code and need to input to get it to operate
2 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 3 Answers
SOURCE: I need to Progam a Samsung Smooth cell phone.
To Program any Samsung Verizon Phone:
+Go to Menu > Settings (may be listed as settings & tools depending on software version)
+Press the * Key (to the left of zero / 0)
+Enter the Service Programming Code (a.k.a. SPC, MSL, SEC) This code is usually 000000 for most Verizon phones, but if it was purchased prepaid you may have to get it from Verizon. Try 000000 first though.
+Go to Network Settings
You will now be in the programming menu. Enter the information as it pertains to the field indicated.
+When you have entered all of the programming information, press END.
The device will now reset and save the programming information.
Posted on Sep 30, 2009
Require ISDN connection diagram for Ericsson BP 250 PABX
you wanted to connect the isdn pri to btu d , from the modem 1,2 will go to pair 8 og krone block and 4,5 will go to pair 6 in krone block.
Mar 14, 2010 | Lands Phones
Jul 25, 2009 | Cell Phones
2005 FORD F150 AC blows cool/warm in front and cold n back vents
Check i the truck comes with separte a/c units, if the front is warm check for an open heater valve, if ok, check for proper gas pressure.
Jul 08, 2009 | 2005 Ford F-150
The camcorder doesnt reset anything. The mini DV still stuck in
Networking Configuration A network architecture is a set of standards for how computers are physically connected and how signals are passed between hosts. Some typical network architectures are described in the table below.
Network Architecture Description Ethernet Ethernet is a wired networking standard and is the most common networking architecture used in LANs (both in business and home networks). Dial-up Modem Dial-up networking is a common way to connect a computer (often your home computer) to a remote network, such as the Internet or a business network. A modem on each computer uses the phone lines to send and receive data. DSL (Digital Subscriber Line) DSL is a fast-growing alternative to dial-up networking to connect to the Internet. DSL uses regular phone lines to send digital broadband signals. ISDN (Integrated Services Digital Network) ISDN is another alternative to traditional dial-up that can be used to connect to the Internet or to directly communicate with another computer connected to the ISDN network. ISDN is more common in Europe than in the U.S. ISDN can use regular telephone wiring, but must be connected to a special ISDN network. Wireless Wireless networking uses radio waves or infrared light (with the air as the transmission medium) to send data between hosts. Wireless networks are common in homes, businesses, airports, and hotels. Most wireless networks connect into larger wired networks (such as LANs) which are in turn connected to the Internet. Communication between hosts on a network generally takes one of three forms:
  • Simplex--one-way communication from a sender to a receiver.
  • Half-duplex--two-way communication between two hosts. Communication only travels in one direction at a time.
  • Duplex--two-way communication between hosts. Communication can travel in both directions simultaneously.
Jul 08, 2009 | Panasonic Palmcorder PV-GS15 Mini DV...
Lexmark x6150 unalbe to fax phone line is active using dsl
Hey Tony - Did you recently hook this up to the DSL for the first time? This unit is supposedly not able to work with a DSL line.
The fax modem in your AIO is an analog device and cannot be used on an ISDN, DSL, or PBX digital phone service. However, you can connect certain devices to your AIO that let you use the fax function in addition to these digital phone services.
To connect without an unsupported line:
Connect an active telephone cable from the AIO to the telephone wall jack.
To connect with an unsupported line:
If you use an ISDN phone service, you can connect to an analog telephone port (an R-interface port) on an ISDN terminal adapter.
For more help and to request an R-interface port, contact the ISDN provider.
If you use a DSL (Digital Subscriber Line) phone service, you can connect to a DSL filter or router that will allow for some analog (rather than digital) use.
If you use a PBX phone service, you can install an analog phone line for a fax machine.
If this was working on the DSL let me know. I don't know the location but obviously a separate phone jack is the easiest. Let me know. If this helps you fix it you can rate this as fixed. If you are just going to rate this as helpful I'd rather you please not rate it and just add a comment and say thanks for the info.
If you need more help just add a comment and I'll be glad to assist you further. Thanks.
Jeff
May 09, 2008 | Computers & Internet
Tv will not program in digital signals; only anolog from direct tv box
Any TV hooked up to a cable or satellite box can only "see" one channel...the set-top box (STB) converts the channel you are watching to (usually) Ch. 3 or 4. With cable you can split the input if your TV has 2 RF inputs, with a dish that won't work.
That's why the TV stays on Ch 3 and the STB changes to whatever you want to watch.
Dec 20, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Video calls over ISDN does not connect.
recheck the spid on your ISDN lines and make sure the order is correct
Feb 14, 2007 | Polycom VSX 7000 Video Conference
Reprogramming
Open Internet explorer and type the ip address of the router in the address bar and hit enter. (it should be 192.168.1.1) The setup page for the router should open. Click "Advanced" then click "ISDN Configuration" then click "ISDN Parameters" You can enter the new SPID's the phone company gives you there. Good Luck, El Duderino
Nov 15, 2006 | Ramp Networks WebRamp 410i (516S)...
Lands Phones Logo
174 people viewed this question
Top Lucent Lands Phones Experts
Ekse
socrtwo
Level 1 Expert
Are you a Lucent Lands Phone Expert? Answer questions, earn points and help others
