Lens will not function
Lens on camera will not open
  • 44 Answers
It's a power supply problem or some part of your camera is not working. if you can tell me how it happens- day by day or sometime or suddenly....then may be i can tell u the proper way...
Posted on Feb 12, 2008
View through viewfinder is dark, looks like dark sunglasses over lens. 24mm lens indicates fE E on lcd code. Shutter will not function or lens will not automatic focus. Switch to 70-300 lens, view finder...
Sounds like the aperture control actuator ring in the camera body is not opening the aperture diaphragm blades fully a repair quote and decide if a different body upgrade may be a better option
May 29, 2017 | Nikon N80 35mm SLR Camera
Lens error, restart camera
Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Apr 28, 2009 | Canon PowerShot SD850 IS Digital Camera
Cannon powershot sd900 lens will not close
work for about 50% of lens errors, but they're worth a try. The list includes:
  1. Remove the batteries and wait a few minutes
  2. Try pressing and holding the Menu, Function, Function Set, or OK while turning on the camera, or otherwise find a "factory reset" option.
  3. Try turning the camera on without a memory card inserted
  4. Place the camera flat on its back and turn it on while holding down the autofocus button, to try to cause the camera to attempt autofocus while the lens is extending
  5. Blow compressed air in any gaps around the lens - or use a shop vac
  6. Use a thin piece of paper or a needle to dislodge any visible bits of grit
  7. Gently tap the camera in an attempt to realign jammed mechanics or dislodge particles (obvious warning: could cause further damage)
  8. Gently push or pull the lens barrel, as a last resort (again, potential for further damage).
Dec 02, 2017 | Canon PowerShot A75 Digital Camera
Problem at switch on
The problem was caused by fine particles getting trapped between the sections of the lens. I tore off a thin strip of paper and wrapped it around the inner barrel of the lens. By rotating the paper, I dislodged the particles, switched on and the camera functioned normally.
Mar 22, 2009 | Kodak EASYSHARE M1063 Digital Camera
Lens Stuck open on Mz67 hp camera Error code Mz60-022
Was this stuck fully open or was the lens partially opened, or was the lens jammed?
The lens can be removed and replaced with another lens from another non-functioning camera (See ebay). The lens component can also be dissembled. Putting the lens back together is tricky because the parts have to be aligned just right for the lens to work. If working with a Jammed lens, extra care has to be considered not to break any of the moving plastic parts of the lens or that part (if not entire lens) is junk.
With the motor detached from the lens, the lens should extend and retract freely. Use this to test the lens when you dissemble the camera. Be careful of the flash board.
Mar 15, 2009 | HP Photosmart MZ67 Digital Camera
Lens error
The lens on my canon camera power shot A430 wont open and when I try to start it is says lens error restart the camera
Aug 04, 2008 | Canon PowerShot A430 Digital Camera
Lens cover stuck DSC600
You may have the same problem that i had. It does involve taking the camera apart. Not overly difficult - just fiddly.
Let me know and i'll talk you thro' it
Jul 24, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
K850i
The easiest way to take pics with the SE K810i, I just slide the lens cover and it auotmatically goes to camera mode
Jan 06, 2008 | Sony Ericsson W850i Cellular Phone
Camera - Open Lens Cover.
The switch that looks if the lens cover is opened is broken, you will have to ask a repaircenter to replace the switch for you, as the camera won't function without it. the switch is soldered on to a flex cable, thats quite difficult to solder by yourself.
Aug 07, 2007 | Sony Ericsson K750
90 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
