Question about ASUS A7N8X-X Motherboard
Motherboard replacement My motherboard needs to be replaced. I have an ASUS A7N8X-X motherboard. Is there a board I can get now that will work in its place due to the fact it is discontinued? Thanks.
  • thor4477 Jan 14, 2008
    Thank you. Do you think an ASUS M2N-MX SE Motherboard CPU Bundle AMD Athlon 64 3800+ would work? Or can I go faster. Thank you. I am new to this and I am trying to do this myself.
  • 102 Answers
Any AMD socket A board which supports your cpu, memory and disk type will do. Instead I would go for an newer and faster combination of board/cpu.
Posted on Jan 14, 2008
  • As long as it supports your current memory modules. That is if you want to reuse that memory. If your bank manager supports you to :) I would also go for faster memory. You can always go faster as long as the board you choose supports any of the old parts you plan on reusing. For instance your harddisk which is probably IDE/ATA should be supported and this is no problem on most of the modern board which still have ATA ports next to the newer SATA ones.
    Do remember that when you run windows it will start complaining about the new hardware and refuse to run because you changed to much and you will have to rea-ctivate or re-install.
It is embedded on motherboard. Download driver.Unzip. Run setup in marvell_v627\Marvell\Win2K_XP after extraction.
Asus A7N8X-E Deluxe Marvell LAN Driver 6.27
Oct 03, 2012 | ASUS A7N8X-E Deluxe Motherboard
Need sm bus controller and ethernet driver for a7n8x-vm motherboard
Go to the Asus site:
Choose :
"Socket A (465)"
in the dropdowns.
Enter your OS
Choose the "IDE" driver, that is actually an "all-in-one" chipset driver that should get you taken care of.
Feb 15, 2011 | ASUS A7N8X-VM Motherboard
I recently bought a used Asus a7n8x mobo so I can rebuild my dead xp Pro 462 A Socket system. I am upgrading the mobo to the "delux = A7V8X-E" board and replacing my 2400 athlonxp cpu with a used 3200...
You dont need the drivers untill after windows has been installed....However... If windows does not pick your network adapter up, you will need to load these before you can get online.
Download all the drivers for the motherboard and just Burn them onto a cd as a data disc, so you have them ready
Jul 14, 2010 | ASUS A7N8X Motherboard
I need motherboard sound drivers need fix
try googling the model number, that usually works for me
Feb 24, 2010 | ASUS A7N8X Motherboard
Computer will not start
first you connect your harddisk data cable to mother board
connect your hard disk powercode using smps
connect smps 24pine connector threw mother board
connect 12v connector threw mother board
connect cpu&external fan connections
also connect the front panel connections on mother board using mother board details
Jun 17, 2009 | ASUS A7N8X Motherboard
Can i replace supreme fx with fxII on my asus a7n8x-e deluxe
mother board as class as form factor this is a standard connector and mounting style if the two board you are trying to replace are the samr form factor then yes it should fit make sure the all you parts like the cpu and the video are compatable. if you using a agp video card then make sure the board has an agp slot and it the correct speed bou other then those type of checks it should work if thing match up the form factor
Jun 10, 2009 | ASUS A7N8X-E Deluxe NForce 2 Ultra 400...
Need diagram of how to hook up my western digitial sata harddrive to mother board a asus a7n8x-e deluxe
this motherboard does not support your new Hard Drive. SATA is a connection type required for your hard drive. Your motherboard supports IDE connector. You probably can get a pci card that allows you to attach the hard drive.
May 24, 2009 | ASUS A7N8X-E Deluxe NForce 2 Ultra 400...
Stopped working
Why doublepost?
Jan 14, 2008 | ASUS A7N8X-X Motherboard
ASUS A7N8X-X Motherboard Logo
60 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
