Question about Samson Resolv 65a Main / Stereo Speaker
Samson Resolv 65a monitor repair
One of my Resolv 65a monitors is not working. All I hear is a humm when I turn it on. Is there a repair center where i can have it fixed? My zip code is
93536.
  • 3 more comments
  • MitchLL Apr 19, 2008
    One of mine cuts out, a slap seems to remedy it for a moment but I don't think this is in the manual.
  • Anonymous Aug 31, 2008
    I'm having the same problem. My monitor was working fine yesterday when I powered it on this morning all i hear is that hum. can some one please help.
  • Anonymous Sep 23, 2008
    I have the same issue with one of my speakers (Resolv 65a). Not so much a hum but a screeching noise. Any ideas what's wrong?
  • jonathan_lin Nov 12, 2008
    same thing here. a pop, followed by a terribly loud distorted hum...did anyone find a solution?
    thanks,
    JSmith
  • micheallr Dec 05, 2008
    I powered it on this morning all i hear is that hum. It goes to a loud buzz when I turn the volume knob to full power.
Its prob a dry solder joint problem.
http://www.gearslutz.com/board/low-end-theory/314545-samson-rubicon-r5a-problem.html
Posted on Sep 16, 2010
Samson 65a: power good, speakers good , LEDs lit, no sound at all?
Check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Oct 11, 2016 | Samson Resolv 65a Main / Stereo Speaker
I need a transformer for my resolv 65a monitor
Are you an experienced tech? In most cases (unless there is a defect in manufacturing) transformers are not a common cause for failure. If it blows the fuse disconnect the secondaries and see if it still blows the fuse. If it does then the transformer is likely the cause, if the fuse doesn't blow then the problem is elsewhere. If you have 120vac at the primary and nothing(or very low) at the secondary(s) then the transformer could also be at fault. If you have done this already and narrowed it down to the transformer, sorry I cannot help. I used service Samson but no longer am able to get parts. Good luck!
Jan 04, 2015 | Samson Audio Resolv 65a Active Studio...
Samson Resolv 40A,no sound, power light on cables good.
Your best bet is to take them to an authorized repair center. You may also want to talk to Samson directly. Here is their support link-
Support SamsonTech
Mar 19, 2013 | Samson Resolv 40A Monitor Speakers
65a Resolv studio monitors. The left one just blew out -- maybe. The blue LED stays dim, as though the monitor has been sleeping. When I power off the monitor, the speaker gives a loud pop, and the cone...
You are getting DC offset voltage on one of your amplifiers that is the reason the speaker pushes out and you might be hearing a humming noise too. Do not turn on the speakers till you get it fixed or else you would end up burning the speaker voice coil too.The dim blue LED is also an indication of a short circuit in the output stage.
Your left amplifier needs a output chip (IC ) replacement. You will need professional help to do that. Will cost you about 20$ plus service charges.
Jun 27, 2011 | Samson Resolv 65a Main / Stereo Speaker
Tweeter is cutting in and out
need to open up speaker and check connections on tweeter. Check closely on tiny wires from magnet(voice coil) to paper cone
Jan 04, 2011 | Samson Resolv 65a Main / Stereo Speaker
Hi There the fuse just blew in one of my Samson
Hi there
To answer your question;
If it is not indicated near the fuse holder then look closely at the metal end caps of the fuse.
The value will be written on one of them,
It may look like 2A/250v for 2amps.
Hope this help
Cheers
Jun 14, 2010 | Samson Resolv 65a Main / Stereo Speaker
Tweeters will not put out sounds, they do not look blown.
You need to go inside and isolate the tweeters. Then with a 1.5volt battery apply the + to + etc for a second. If it pops it's working and the problem is in the crossover. If not it's dead!
Feb 23, 2010 | Samson Resolv 65a Main / Stereo Speaker
My tweeters are blown on my Samson Resolve 65a monitors...anyone know what I should get (and where) to replace 'em?
It might tell you on the back of the tweeter what rating they are. I should do a webserch for Samson spares and see what it comes up with.
Feb 02, 2010 | Samson Resolv 65a Main / Stereo Speaker
Samson 65a monitor speaker
If its not to big find a neostick or similar sintetic glue,piece of medicine bandage and black (if speaker is black) mat spray.First put some glue around the rip wait for 10 min and then put the bandage on it.After that again 10 min of waiting and new layer of glue on the bandage.Let it 24 hours for glue to dry an then respray it.If you can do it from the back side its better and repair is almost invisible.
Feb 29, 2008 | Samson Resolv Sub88 Subwoofer
Samson Resolv 65a Speaker - No Power!
There's a fuse input just underneith the mains input plug.A small screwdriver will open the small latch.You can get new fuses at Maplins.
Jan 07, 2008 | Samson Resolv 65a Main / Stereo Speaker
Samson Resolv 65a Main / Stereo Speaker Logo
1,551 people viewed this question
Top Samson Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
Jerry Umali
Are you a Samson Audio Player and Recorder Expert? Answer questions, earn points and help others
