Question about Braun Tassimo Espresso Machine/Coffee Maker
Tassimo my tassimo coffee pot, is good, but the coffee tastes like cardboard, so does the cocoa, and the cappaccino... all taste like cardboard,, and suggestions? its a great machine, i even went and bought new t-disc's thinking mine were old or something.. same thing.. cardboard? gross..
  • 1 more comment
  • dari6 Dec 17, 2008
    The coffee from the tassimo used to taste fine but now there is an acrid taste to it. I have changed the filter, ran the cleaning disc and even changed the type of water.
  • Anonymous Apr 14, 2009
    Hi everybody! I have the same problem. Mine tastes like it's acrid or extremely burnt! It didn't do that for the first two months I used it. Since that started, I have descaled and ran the cleaning disc. That hasn't helped. I have not changed the filter yet and I do use water from my faucet. I will try changing the filter and using bottled water. If it works, I'll let you know!
  • Dan New Mar 08, 2013
    I have the same problem. I have two machines one at home and one in the office. The coffee tastes acrid and burnt in the office machine. I also noticed that the temperature of the coffee in the office machine was much hotter compared to the other machine.
Have you tried using bottled water? I had the same problem and found that Spring water tasted the best.
Posted on Feb 05, 2008
Coffee tastes bad
Brew a pot with vinegar and no coffee grounds. Then rinse well with water and run a pot or two with water alone.
Mar 08, 2015 | Miele CVA615 Espresso Machine
My tassimo coffee maker is ruining the coffee it taste like water
i too had this problem BUT it was AFTER i descaled it and did the cleaning, now coffee tastes weak, and ive tried different discs (other coffees) and all come up weak.
Nov 13, 2011 | Bosch Tassimo TAS 4012 Coffee Maker
I had a stick of butter laying on top of my bunn coffee pot and some butter leaked through the vents. the coffee tasted terrible so i cleaned it with vinegar and ran about 10 pots of clear water through...
Believe it or not I had a customer once that left 6 pounds of butter on top of one of our brewers. They had it cleaned up on the outside so it took me a while to figure out what had happened but I could taste the rancid oils.
We ran about 20 pots of just water through it... make sure you let it heat back up before each one. I think the only thing vinegar might help with would be lime/calcium build up so I wouldn't think it helps this particular situation.
Dec 21, 2010 | Bunn BT10B Coffee Maker
Lost instruction manual. How do I clean coffee maker to get rid of strong acid taste coffee? MoldelB60 single cup coffee maker
Most coffee pots are cleaned by running 1 part white vinegar and 1 part water. Just put in the reservoir and run a cycle. Once completed, run again with 1/2 pot of water only and it will clean it. If you use your pot daily, this should be done once every few months. If you have foul tasting coffee, you should use bottled water to rectify that. Plain tap water has minerals that dilute the taste of the coffee and over time build a residue in your pot.
Oct 09, 2010 | Keurig B60 Coffee Maker
What can I clean my Bunn proffessional coffee maker with ?
mcdevito75 here, Contact Bunn for their recommended cleaning material for your coffee maker, or see any large store that carries coffee makers for their cleaning kits.
Jul 11, 2010 | Bunn VPR Coffee Maker
Just got one of ebay working but just tried hot chocolate and only a bit of water came out and didnt taste nice
i tried cocoa powder in my coffee mach the grind wasnt right too powdery it acted like it was plugged tight as a drum just a few drops then it shut down luckily after a good cleanout good as new!
Feb 05, 2010 | Braun Tassimo Coffee Maker
Mr Coffee Maker FTX25 - coffee tastes bad
Try running a 1/3 white vinigar -2/3 water mix into the brewer, let it brew, then run several pots of clear water through it. This should clean up any bad taste.
Feb 09, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
Coffee tastes like plastic!
We have had our DCC-1200 for 3 months. The plastic taste occurs about every 3rd pot, and it does NOT get better. We've wasted over a pound of coffee. Cuisinart says we are the only people in the world with the problem. Well, I guess not...
Jan 16, 2009 | Cuisinart DCC-1200 Coffee Maker
Coffee pot
durabrand has no contacts outside china this is a unit made for and imported for walmart only walmart is the only contact ...... your problem is not anything you or walmart can do anything about the problem is the cheap plastic that is used , when it gets hot some people can taste and smell it and others cant . .. its getting more common in everthing that heats water .. personaly i would not drink anything from an appliance that puts a plastic taste in my water ..... if you move up in price the problem is reduced , better plastics are used , but your not going to get one for 10.00 ! "you get what you pay for " more now than ever .... good luck Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob
Mar 18, 2008 | RoadPro 12-Volt Coffee Maker
Plastic Smell & Taste
Just because its made of plastic doesn't mean it should taste like plastic! The engineers made a mistake in design! Get your money back and don't risk taking in carcinogens!
Feb 25, 2008 | Mr. Coffee 072179228578 12 Cup Coffee...
Braun Tassimo Espresso Machine/Coffee Maker Logo
557 people viewed this question
Top Braun Coffee Makers & Espresso Machines Experts
ellipse0904
Level 1 Expert
Jim Thurston
Are you a Braun Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
