I have a 4 stroke ride on mower - engine starts but runs properly then tends to die out - runs properly again, dies out cycling like this every two seconds or less. Spark plugs new, small amount of smoke coming out of oil filler when cap removed and running.
You need carburetor work.
Youwill need to disassemble the carburetor and spray withcarb.cleaner.
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
The smoke is more than likely because it is flooding. There's too much fuel getting into the carburetor. The choke may be sticking.
If you need further assistance just let me know.
Jim
Took the ride on mower to a repairers - with the engine running, the guy sprayed carb cleaner into the carb (filter off of course)- did this about 4 times and it seemes to have fixed the problem - saved dismantling the carb !?
