Question about RCA D52W19 52" Rear Projection Television
Front Panel need to clean inside of front panel due to candle wax drip. How to remove front panel for cleaning inside?
  • 1,153 Answers
Unscrew the screws around back, but hold front will start falling when screws are out
Posted on Jan 14, 2008
Raising and lowering blade almost impossible. How do I repair it
the blade is raised and lowered via a screw (long one) that you turn with a handle as with any mechanical item that moves , keeping it clean and lubricated is critical , I use candle wax on all my saws (not bee's wax) , as sawdust doesn't stick to it as much as a petroleum oil would cause, and it never mars my wood panels or stains it with a drip mark
Oct 29, 2015 | Saws
Cleaning residual candle wax off glass
Believe it or not you can get dried candle wax off of glass with a MISTER CLEAN MAGIC ERASER!! You can use generic erasers , such as Home Depot or your local grocery store. It works !
on May 23, 2015 | Crafts & Hobbies
House fuse blew last night
Plastic lead inside front of soap dispenser unlocks door.
Remove front panel, undo top panel & lift up, check wax motor (red / brown unit above / top of door), usually burnt out taking control board with it. If you are going to repair fit 5 amp fuse in line with wax motor or fit later model door lock mechanism.
Dec 08, 2013 | Maytag Neptune MAH5500B Front Load Washer
Water flushed from unit inside the room instead of beeing flushed outside throw the out let pipe
Possible that the tilt is more to the front that makes the water drip down. Another reason is that the drain pipe can be clogged with dirt build up and so it flushes back.
Finally if the evaporator is dirty and clogged due to dirt accumulation the water might drip down to the front.
So please check you filter, use high pressure air on to clean and reset the panel.
Aug 27, 2011 | LG LSC121PMA Split System Air Conditioner
I have a hotpoint wm54 and it is not rinsing or spinning properly, at the end of the cycle the clothes are dripping wet & soapy, however if i manually put on to rinse and spin it seems to work!
You need to check and clean the pump filter.
Remove rear panel od washer, locate and remove large black hose on bottom of drum, remove and clean filter inside the hose.
Nov 15, 2010 | Hotpoint Aquarius WF000 Front Load Washer
My kenmore HE washing machine was overloaded and now the door won't unlock. Help!!
Remove the bottom front access panel,reach up inside on the latch side and feel for the pull ring.
Pull it to open the door.
Clean out the drain filter while you have the panel off.
Replace the door latch wax motor.
Mar 02, 2010 | Kenmore Washing Machines
Water remains in machine after a wash, clothes dripping wet. What could the problem be?
I would say that the filter is need of cleaning.
If you cannot find a filter located at the front bottom right of washer, remove lower rear panel of washer.
Remove large black hose fastened to bottom of drum.
Remove and clean plastic filter inside hose.
Remove hose onto pump, and check for blockage or bstruction here as well.
Hope this helps.
Dec 18, 2009 | Hotpoint Washing Machines
KA dryer has been running without a lint filter. Other owner. I need to know how to take off the front and back panal to clean inside due to fire hazzard. Mdl # KGYE800TWHO . Need schematic drawing. I am...
Disconnect Power. Lift Cover on lint filter. Remove two Phillips screws taking care NOT to allow them to fall into the blower housing. Next, place a putty knife in the space between the upper and lower panel at the front of the dryer about 4 inches in from either side to push up the retaining clips while pulling on the lower panel. This will release the lower panel and give you full access to all the main components and most internal areas needing cleaning.
The only area affected by running with no lint filter is accessed by removing the rear panel. With rear off, the filter housing on the left will have several 5/16" hex head screws to be removed for access to the blower wheel and housing interior. With screws removed go to front and insert putty knife in the seam between the top and front panels about 4 inches in from both sides. Lift top at same time and raise when disengaged.The filter housing can now be moved sufficiently to vacuum the interior from the rear removing any large foreign objects first.
You have now cleaned all the dryer areas that need cleaning. Don't forget the airflow through the vent line of the house.
Reverse the above process to reassemble unit. Good Luck.
Wiring Diagram for your model is located at link below:
KGYE800TWH0 Wiring Diagram
Oct 02, 2009 | KitchenAid Dryers
My trackball is okay with large, sweeping
I have a total of six Logitech trackballs; four of the newer Trackman Wheel model, and two of the older Trackman Marble+ model (as pictured). All but one of them suffer from the problem described by dave48. The fifth, for some mysterious reason, never has this problem.
The solution I came up with is to light a candle and let melted wax drip onto the red thumb ball. A single drip falling on three random places on the ball usually does the trick. (The wax should dry as soon as it contacts the ball.) I then start moving the ball around to work the wax onto the teflon points. The movement will be VERY rough initially, but will gradually smooth out the more you use it. Sometimes the initial three drips aren't enough and the ball starts getting rough again, so I will melt three more drips of wax onto the ball and work them in as well.
This really seems to do the trick and for some reason the points don't seem to need cleaning as often either. You do have to be careful not to remove the wax when performing a cleaning, however. But if you do happen to remove some wax all you need to do is melt some additional wax onto the ball and work it in like before.
Jun 19, 2009 | Logitech Trackman Marble Trackball
Hi, I washed a candle, yes candle, in my daughters brand new lg dishwasher and now it doesnt work. Surprising i know. After spending days tearing it apart and removing all the wax out of the inside as well...
The problem is that when you ran a wash cycle.. the heater came on and melted the candle and some wax probably ended up in your pump or hoses in/out of that pump.. Since you did not provide a specific model number, I cannot provide specific details on how to dismantle everything but here is a link that you can get service manuals etc for LG products. Hopefully, yours is listed there and the details will be clear enough for you to clean everything up and get water draining again.
You might also find a detergent ( I am thinking liguid plummer or something ) that might break up any wax residue without having to open everything up to clean it.. Good luck and hope this helps you...
Sep 02, 2008 | LG Dishwashers
RCA D52W19 52" Rear Projection Television Logo
76 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
