Question about Acer Extensa 500T Notebook
Acer start up
I did not shut down the laptop properly just with the power button now it wont start up and start up repair cannot fix the problem what can i do to fix this
  • giusti Mar 22, 2008
    i wasnt shuting down properly and now when i press the power button on my laptop it acts like its starting up but just brings startup repair up, and startup repair can not find the problem and eventualy brings me in a full circle. PLEASE HELP I CANT FUNCTION WITH OUT MY LAPTOP.
  • Don D May 11, 2010
    What is the problem exactly? how far does it get when you turn it on? any error messages?
    Genius:
  • 1,003 Answers
Use your recovery disc that came with your computer to restart windows. or if you have a windows xp program disc this will give the option to do a repair or reload computer with a fresh copy of windows.
Posted on Jan 15, 2008
MY LAPTOP AFTER 2-3HR WORK SHUTS DOWN AND WONT TURN OFF.i HAVETO PRESS THE START BUTTON TO REBOOT-PRODUCT ACER F5
Just wanted to confirm a few things..
Did you do a hard power down by holding the power button down for 5 seconds or by just briefly pressing the power button (which would put the computer to Sleep).
I've found this laptop occasionally does not properly recover from Sleeping under Win8, that's why I ask.
Either way, do a hard power down by holding the power button for 5 seconds.
Unplug the laptop and find the battery disconnect pinhole switch underneath (indicated with a picture of a battery lifted up) and using a paperclip press and hold for 30 seconds.
Try powering on again, do you atleast get the Acer logo appearing when powering on?
Aug 22, 2016 | Acer Computers & Internet
Screen is frozen and won't shutdown. what do I do?
hold the power button down till switches off or when its on unplug charger and take off battery.
laptop repair london computer repair service no fix no fee
Mar 01, 2014 | Acer C7 Chromebook
Laptop will not shutdown
Remove the battery and unplug it from the wall. Try holding down the power button for about 8 seconds it should shut down. Just a suggestion! When you shut down your laptop make sure that your shutting down properly at the start button select shut down. If all else fails and this does not work.
You may want to have the power button checked out or the board. Or clean files out and start up programs add-ware or spy-ware may be preventing you from shutting down as well. This is also a common issue that causes very slow shutdowns on any computer system packed up junk having to close out. John
May 11, 2012 | Dell Latitude E5500 Laptop
My laptop wont turn on
You may have a RAM problem. Try reseating the RAM modules, if this does not fix your problem, remove the RAM modules and take then to your friendly computer repair shop and get them to test the RAM for you.
Feb 06, 2012 | Acer Aspire 5520-5908 Notebook
I undocked my compaq 6320 laptop - just after accidently hitting the dock- power button (before hitting the eject button). I ejected the computer but noticed it began to start-up but shut down because my...
Try removing the laptop from the doc, pulling out the battery, hold the power button down for 10-20 seconds, and re-install the battery.
This should drain out the laptop and it should boot up properly without the dock.
May 27, 2011 | Computers & Internet
Computer will not start up only sometimes after it sits for days but after shut dowm wont start up again
Try performing a hard reset on the laptop by removing the battery, unplugging the Power Adapter and disconnecting external devices connected to the laptop. Once everything is removed/disconnected, press and hold the power button for around 15 seconds. Put everything back then power the PC on. The reason this issue happens is because the computer doesn't shut down properly and because of this charges get left on the laptop's motherboard, holding power button down with nothing connected to the PC drains these charges. If still the same issue exists, try updating Windows, there might be updates that doesn't install completely. Update drivers as well and run a system scan with your security software.
Hope this help. Goodluck!
Mar 29, 2011 | Dell Studio 1537 Laptop
I press the power off button and it doesn't power off
You should never power down by pressing the power button unless your system is deadlocked and won't respond to any other actions. Powering off in this fashion can cause you to lose data, corrupt files, and improperly shut down Windows.
Nonetheless, if you are in need of shutting down the laptop in this fashion you must hold the power button instead of only pressing it. You'll find this in the power settings of the device. Honestly, the power button may even be set to do nothing, which is possible.
To properly shut down your new Pavilion laptop, which should be running Windows 7, follow this process: Click Start > Shut Down
Start is now simply a circular Windows icon in the bottom left corner of the screen and shut down has an arrow pointing down next to it. Click the words shut down instead of the arrow which will bring up other power save options.
Oct 17, 2010 | HP Pavilion dv7-1245dx Notebook
When i push the power button, inspiron 1525, it turns
try this.... go to start | run | control
go to power options
on the advanced tab there will be a option called
"when i press the power button on my computer"
select the "shutdown" option
click apply and ok
then try shutdown your machine using the power button
Dec 22, 2009 | Dell Inspiron 1525 Notebook
No output at all
okay close laptop remove battery, open ram / memory compartment, remove memory. try holding down power button for 3 minutes. THEN INSTALL BATTERY , NOT RAM/ MEMORY AND PRESS POWER BUTTON AND IF YOU HEAR A SOUND THAT GOOD NEWS THE SCREEN MIGHT COME ON, OR IT MAY NOT, BUT YOU SHOULD HEAR A BEEP, IF POWER BUTTON REMAINS LIT HOLD DOWN TILL COMPUTER TURNS OFF, THEN INSERT MEMORY/ RAM AND FIRE IT UP. WORK THESE STEPS
Jun 02, 2009 | Dell Vostro 1500 Notebook
My laptop won't shut down properly!
Is it possible that you have changed the settings of what buttons do what on your system? E.g. you could have changed the power button to "switch user" instead of "shut down", to check this (in XP) go to "Power Options" (in Control Panel" and then click on the "Advanced tab" at the top, then select "Shut down" from the drop down menu at the bottom of the window.
If this is already set to shut down then maybe you could do a system restore in case another setting has been changed, restore it to before the PC started doing this.
Alternatively try actually choosing "Turn off Computer" from the Log On screen (press Ctrl + L to get to this screen, or choose switch user/log off). If you are using Vista I beleive that there is a shut-down option from the Log In Page there (which again you can access by pressing Ctrl + L on the keyboard.
Hope this helps!
Dec 29, 2008 | Computers & Internet
Acer Extensa 500T Notebook Logo
51 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
