Question about Plantronics 510 Voyager Headset - PLN-510 Headset
Plantronics Voyager 510 & Blackberry Curve
After successfully using my Plantronics Voyager 510 with my Blackberry Curve together for the past month , today I they don't seem to be correctly synched.
I turned off and then fully recharged them both last night. This morning, when I tried to pair them, the got hung in the trying to connect mode then eventually gave me a failure message. Tried to make a test call and would only work from the handset. When I checked the headset status in the Bluetooth menu, the only option it gave me was to disconnect. I did hear the disconnect tone in my headset, but that was all.
I tried shutting both off and on again, but didn't have any better luck. I tried re-synching, but I can't seem to get my headset into synch mode (pressing power and hook button simultaneously, right?).
Incidentally, prior to the Voyager 510, I had a different model of Plantonics headset that is still listed on my phone - might that now be the source of my problem?
Please help if you can.
Thank you!
Lorraine
  • Anonymous May 21, 2008
    plantronics 330 and curve
  • markstr351 Apr 28, 2009
    I have Plantronics Voyager 510 that worked fine for more than a year with my Blackberry Curve but last month stopped. It's paired and it seems that everything is OK but can't answer the phone through it and it stays disconnected. Can this be fixed?
    Mark
  • 5 Answers
 Plantronics Support Phone Number: 1-800-544-4660
Do not use the power button to sync.
To sync device, Press + button (volume) and Silver button (on boom) at simultaneously. LED Light will blink RED & BLUE.  Device ID should appear on your screen.
Posted on Mar 12, 2008
MUCH APPRECIATED GETTING THIS HELP!
Posted on Jun 06, 2008
    Genius:
  • 1,003 Answers
Delete all bluetooth devices under blue tooth menu then try to sync AGAIN
Posted on Jan 17, 2008
How do i connect my plantronics 510 voyager headset to my blackberry
Once you make your BlackBerry discoverable, then put the Plantronics Voyager 510 into pairing mode by holding the call control and volume up buttons at the same time until the headset flashes red and blue. Here is the link below for the 510 pairing instructions.
Plantronics Voyager 510 Pairing Instructions
Good luck from Headsets Direct!
Oct 19, 2011 | Plantronics 510 Voyager Headset - PLN-510...
Can't hear my pc to head set..can u help
Hearing a Plantronics Voyager 510 headset through a computer:
To use a Plantronics Voyager 510 headset through your computer, you either need a USB Bluetooth adapter or you must have Bluetooth built in to your computer. Once the Voyager 510 headset is "connected" to your pc (by one of the mentioned ways), you may need to go into the control panel on the computer or the specific software program being used to set the Plantronics Voyager 510 headset as the "default device". Keep in mind that the headset has to be powered on and to also have to activate the headset to connect to the Bluetooth adapter or computer.
Good luck from Headsets Direct - 800-914-7996.
Aug 20, 2011 | Plantronics 510 Voyager Headset - PLN-510...
When you press earpiece to pickup call the phone lift not working and a red light blinks on front left on desk top charging station .It worked fine yesturday - I come in today and it doesn't work. there...
This could be several problems, I am going to give you the one that I believe is the answer. It sounds like it may need to be subscribed again. First here is your user guide:
Plantronics Voyager 510 User's Guide
If that doesn't work, it may be that your headset is bad. If it is you can replace that with this headset:
Plantronics Voyager 510 Replacement Headset
Mar 01, 2011 | Plantronics Voyager 500A Deskphone Adapter...
CAN'T GET MY BLACKBERRY 8330 TO PAIR WITH MY
Did you do the steps listed here?
This is the Plantronics information.
Your new headset includes Plantronics QuickPair technology to simplify
the Bluetooth setup process. The rst time you turn your headset on, your
headset automatically enters pairing mode for 10 minutes. Once paired
successfully, your headset stays on for instant use.
If not sucessfully paired after 10 minutes, your headset automatically
powers o. When you turn the headset on again, it automatically goes
into pairing mode until successfully paired with a Bluetooth phone.
To pair your headset for the rst time:
Turn ON the Bluetooth feature on your phone.
TIP: For most phones, select Settings/Tools > Connections > Bluetooth > On.
See your phone’s user guide for more information.
Press and hold the call control button to turn on your headset. (The indicator
ashes red/blue to show that the headset is on and in pairing mode.)
TIP: If you don’t see the red/blue ash, press and hold the call control button to
turn your headset o, and then press and hold the call control button again until
you see the red/blue ash.
Use the commands on your phone to locate your headset.
Search > 520Plantronics. See your phone’s user guide for more information.
When prompted for the passkey, enter 0000.
When pairing is successful, the indicator on your headset ashes blue. Your
headset is now connected and ready to use.
Apr 15, 2010 | RIM BlackBerry? Curve 8330 Cellular Phone
Pair plantronics voyager 510 with mac book os x
1. Turn Bluetooth On in Macbook 2. Turn the headset On 3. Press the Up volume and the conversation On/Off key at the same time until the blinking blue lights blinking Blue and Red alternatively 4. In a couple of seconds the Mac will ask for the Authorization Key 5. The Auth key is "0000" (4 zeros) 5. Pairing should now be successful and you should be able to use the PLT510 headset with your Mac. I can
Jul 13, 2009 | Radio Communications
Earpiece slipped off the plantronics bluetooth,and i want to know if there is anything to help put it together again.
my plantronics 510 voyager did the same thing. try putting the earpiece back on to the main bluetooth and wrapping a small rubber band BETWEEN THE TWO. the object is to put some opposing pressure on the earpiece to force it to stay on. it'll work at least till you get anoter earpiece
Oct 05, 2008 | Plantronics 510 Voyager Headset - PLN-510...
Light is not on..
I'm facing the same problem with my plantronics 510. Would love to hear if it is fixable. I've already bought myself a new one (tip - look at craigslist for a cheaper deal than even ebay and amazon)
Aug 02, 2007 | Plantronics 510 Voyager Headset - PLN-510...
Plantronics 510 Voyager Headset - PLN-510 Headset Logo
3,006 people viewed this question
Top Plantronics Radio Communications Experts
skiffy99
skiffy99
Level 1 Expert
shaun taylor
 Grubhead
Grubhead
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
