Question about Samsung SyncMaster 460P 46 in. HDTV-Ready LCD Television
Computer Image How can I clean up or make better the computer image on the Samsug 460p. Everything else looks great, but when I show a computer screen on the monitor it is out of focus and looks blurring. Is there a way to clean this up to make it look just like what I see on my desktop computer monitor?
  • 53 Answers
The picture quality is better on smaller monitor due to higher resolution i.e the image can only be reproduced at a maximum resolution as specified by the by the manufacturer. for instance 1366x768 for the 460p
Posted on Mar 18, 2009
Screen has no image except it looks like madras
Try to plug in this monitor to another pc. If it still does not show an image you may have to replace the monitor.
Mar 15, 2010 | HP L2208W Monitor
No picture on my new 46 inch samsung LCD
Hi...there,
It's seems your backlight lamp is burnt out... if you are still under warranty... call the mfg. up and get a replacement lamp.
Nov 29, 2008 | Samsung SyncMaster 460P (Silber) (Silver)...
I hooked up my new acer p191w to my dell laptop 1525.HELP!
Not sure what the problem is, but I would suggest pressing the Fn+F5? There is a function key that toggles from dual screen, just the laptop screen or just the monitor. Hope that helps..
G'luck
Nov 11, 2008 | Acer Computers & Internet
Monitor is Flickering and screen becomes pink
Hi this is the way how to examine what's wrong with your LCD monitors. Power on both CPU and monitor. After it goes back to white, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. I used to check my LCD monitor and could see window image using flashlight and found out that Some of CCFL lamps inside were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so.
Thank you,
Tan
Mar 10, 2008 | Acer AL2017 20" LCD Monitor
MAG Innovision LT916S monitor problem
Hi this is the way how to examine what's wrong with your monitors. After you turned it on and the screen went black, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Tan
Mar 07, 2008 | Mag Innovision 19" LCD Flat-Panel Monitor...
Dell E193FPC - Screen is getting too bright.
this is the way how to examine what's wrong with your LCD monitors. Power on both CPU and monitor. You check that you can see the image on the screen. If you can see the icons or any image, there will be a minor problem. Like me, I can see window image using flashlight and check lamps inside. Some of them were broken and it is easily replaced. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so.
Oct 25, 2007 | Dell E193FP 19" LCD Monitor
Black screen
Hi this is the way how to examine what's wrong with your LCD monitors. After you turned it on and the screen blacked out, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Sep 21, 2007 | Mag Innovision 19" LCD Flat-Panel Monitor...
Monitor Generated Image
Great picture! Big problem! i suggest is time to do a monitor change.
Sep 17, 2007 | ViewSonic VX910 19" LCD Monitor
Monitor Constantly Pulses Between Black and Light Black, But Won't Display Images
Check inverter board for bad 2sc5707 drivers...could be shorted.
Also check driver transformers for over heating symptoms...they could also be shorted.
May 11, 2007 | Dell E173FP 17" LCD Monitor
Samsung SyncMaster 460P 46 in. HDTV-Ready LCD Television Logo
47 people viewed this question
Jerry Greenberg
Jerry Greenberg
