Question about Sonic EV SonicXS Computer Speakers
The cable that connects from my ev sonic 2.1 satalite speaker to the bass is not working and I believe I may need a new one. How do I get a new one?
The cable has a number of mettle points sticking out inside the socket and seems to provide power from the bass to the satalite speakers or vis a versa. I believe I need a new cable, how do I go about doing that?
  • juan5194 Nov 29, 2008
The subwoofer is acting as a amp , wats the problem?
Posted on Jan 17, 2008
Can u tell me what amp I need to run my 2 x 400w EV sb122 bass speakers and 2 x 300w EV sx300w top speakers
The wattage listed on the speakers is the peak wattage the speakers are rated to handle. You need amplifiers that do not exceed that maximum. A 50 watt amp would drive them fairly well but you would do better with a 100 to 200 watt amplifier. Note: the speaker rating is peak power handling. Amplifiers these days are usually rated at peak output too but sometimes (old or very high quality) amplifiers are rated at sustained power (RMS). If you are working with one of these amplifiers you will need an amplifier with a lower rating. Also make sure the amplifier is designed to run the same load as the speakers. This is usually either 8 ohm or 4 ohm. Make sure the speakers and amplifier are rated the same.
Apr 17, 2013 | Audio Players & Recorders
What you use to hook them up? i dont know how to hook them up to my pc or tv
you connect all the speakers to the amp sub woofer and run a single or multiple jack plug lead into the back of the pc
Mar 05, 2011 | Sonic EV SonicXS 4.1 Computer Speakers
Unable to receive optimum output. The bass is totally flat !
Hi, ok the Bose Acoustimass III system consists of two small cube speakers and one subwoofer unit called the Acoustimass bass module. If the subwoofer stops working, three points can be the cause of the failure. The Bose Acoustimass III is a passive system, meaning the speakers do not power themselves, but instead are connected to a receiver or amplifier. Thus, the amplifier, the speaker between the amplifier and the subwoofer, or the subwoofer itself could be the issue.
Things You'll Need:
* Amplifier
* Speaker cable
* Extra subwoofer
Instructions
Disconnect the speaker cable from the back of the Bose Accoustimass bass module and connect it to a subwoofer that is known to be working. If the subwoofer works, the bass module needs to be replaced.
Disconnect the speaker cable from the back of the receiver or amplifier you are using and from the back of the subwoofer in Step 1.
Connect a speaker cable that is known to be working between the back of the receiver or amplifier and the back of the Accoustimass module. If the module starts working, then the cable was the issue.
Disconnect the speaker cable from Step 3 from the back of the amplifier or receiver, then connect the cable to the subwoofer port on the back of an amplifier or receiver that is known to be working. If the subwoofer works, the receiver was the issue. If the subwoofer still does not work, verify that the speaker cable is in the subwoofer port of the receiver/amplifier and that the cable is connected securely to the subwoofer.
If you think you did the connection properly,Fine... If not you can use the manual from the below link and know how to connect it properly..
products.bose.com/pdf/customer_service/owners/og_am5iii.pdf
Have a nice day..
Feb 19, 2011 | Bose Acoustimass 5 III System
My transmittor does not work where can i order a new one? will it be expensive?
from prior issues involving the same problem, the transmitter frequency ranges are in the hundreds of thousand. to find the correct one would be a miracle. the cost of one seperate would be better off buying a new set.
Dec 20, 2010 | Sonic EV SonicXS 4.1 Computer Speakers
Need owner`s manual
you can download Sonic EV SonicXS 4.1 Computer Speakers manual from this link below:
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000011734.pdf
Aug 06, 2010 | Sonic EV SonicXS 4.1 Computer Speakers
No sound from EV SH-1502 ER 15" driver
Either the 15" speaker is dead, or the passive crossover inside the unit. The simplest way to identify your problem is to remover the speaker that isn't working from the enclosure, and exchange it with the speaker that is working. If there's no sound still, it's the speaker itself that is the problem. If it works in the other cabinet, then put the "working" speaker in the cabinet you took the "bad" speaker out of, and if it doesn't work, then there's a problem with the crossover in the first cabinet. I believe you can buy a replacement crossover from EV. If it's your speaker, do a google search for "speaker re-coning" in your area - it's cheaper to re-cone the speaker than buy a new one.
Jun 18, 2009 | ElectroVoice . Speaker
No sound on EV SonicXS 4.1
Good day Idn2000
you may check also in the manual your actual conection, and see if is the right, then check on control panel and speaker setup, for 4.1 setting. if the speakers don't work,at back, something is bad inside the controller, on sub. be carefull opening and moving things inside, but you can check that .
Nov 28, 2007 | Sonic EV SonicXS 4.1 Computer Speakers
EV sonic XS 4.1 computer speakers and amp
Hi CarrieBeth
depending on the brand of your speakers (creativelabs) etc, have different models, but some of them have problems with AMP, and subwofers. Send me your brand or model, to help you out more direct, or depending on the brand, some models lile 5600 from CL. have problems on the AMP module on the sub. have to change or fix the AMP chip.
hope I can help
Carl
Nov 16, 2007 | Sonic EV SonicXS 4.1 Computer Speakers
I only hear sound out of two speakers........
Have you set the computer up for 4.1 speakers in the audio software? Go to start control panel and click on sound's speech and audio device's, then click on sound's and audio device's. A window should pop up with a load of menus at the top, click on the one that says volume. Where it says speaker settings click on the advanced button. Click on the menus until the picture lookslike your system you have.
Feb 19, 2007 | Sonic EV SonicXS 4.1 Computer Speakers
Open Questions:
Sonic EV SonicXS Computer Speakers Logo
280 people viewed this question
Top Sonic Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Martin Murray
 Grubhead
Grubhead
Are you a Sonic Audio Player and Recorder Expert? Answer questions, earn points and help others
