Question about HP PSC 750 All-In-One InkJet Printer
Turning off the color cartridge
I never use the color, so I don't put in a new cartridge for color how can I turn off the color so it will print black, It says replace color cartridge, so I can't print anything . Does anyone have an answer?
I have been fighting the same annoying issue for several hours this evening. I even used HP Live Chat and was told I needed to buy new cartridges. I'm not satisfied with that answer of course. Out of nothing more than a whim I told my puter to print a txt document I had open at the time...IT DID...with the red error light flashing and a color cartridge error on my display panel.
This was just a few minutes ago so I have no further info to offer. I look forward to seeing what others have to day regarding this issue.
Posted on Jan 20, 2008
Why won't a new tri-color cartridge print red?
Tri color cartridge contains Cyan,Magenta & Yellow color inks, mono cartridge contain black ink, combination/mixing with these inks desired color out put will prints on paper.. If any one or more inks are missing/dried, result mis matched print outs on paper.
In your case I feel it's Magenta ink is not firing..,nozzles may clogged, try to clean the nozzles with solvents & try it...If no result ,. replace the color cartridge..
Mar 28, 2015 | HP PSC 1315 All-In-One InkJet Printer
My color ink cartridge dont print i always have problems with my color when i put it in y dont it print it is a new cartridge?
You could try to remove both of your ink cartridges.
Turn printer off and wait at least a minute.
Turn printer back on and wait until printer recycle.
Printer will indicated no cartridge installed.
Turn printer off again and wait at least a minute.
Turn printer on and wait until printer indicated no cartridge.
Install back both cartridges.
Jan 23, 2011 | Lexmark X2250 All-In-One InkJet Printer
Pixma MP150 Will not print. Error 2 says paper out.Won't print no matter how much paper is put in Recently replaced color cartridge. Have reset cartridge, shut printer down and restarted. Nothing works
Are you using a factory new Canon cartridge or a third party cartridge or even worse a refilled cartridge.
80% of the time, that's the failure.
Feb 24, 2010 | Office Equipment & Supplies
New ink cartridges. Printer won't print and does not show the new cartridges.
Step one: Run the clean print cartridges utility
Press the Setup button.
Press the down arrow key.
Select Clean Print Cartridge and then press OK . The device prints a test page.
Examine the test page. If the print quality of the page is good, stop here. If the print quality is bad, go on to the next step for further cleaning.
Open the Printer Toolbox . There are two ways to do this:
select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox .
Open Printers and Faxes in the Windows Control Panel , then right-click your printer icon and choose Properties . Click Printing Preferences . Click the Features tab, then click the Printer Services button.
The Printer Toolbox opens. On the Device Services tab, click Clean the Print Cartridges , then follow the on-screen instructions. Up to three levels of cleaning are available. Discard or recycle the page that prints.
Step two: Replace the problem cartridge (you probably have a defective cartridge)
If a cartridge replacement was not tried previously to solve this problem, replace the problem cartridge now
Cause and prevention
Color mix is usually caused by a material touching the nozzles. Ink can wick along the material and travel from nozzle to nozzle. When different colors of ink mix in this way, the result is muddy, inaccurate colors.
Missing colors occur when the cartridge nozzles dry out, or when a color is exhausted because of specific printing demands.
Do not remove the protective tape from a new print cartridge until just before you install it. Once you remove the tape, do not reapply it.
After you have removed the protective tape, do not allow anything to touch the nozzles.
Print at least once a month to keep the print cartridges in good working order.
Always turn the printer off by pressing the button on the printer control panel, rather than by unplugging the printer. Turning the printer off properly allows it to protect the cartridges.
If you are removing a cartridge from the printer temporarily (for instance, removing the black cartridge in order to install the photo cartridge), put it in a cartridge protector.
If you do not have a cartridge protector and need to remove a cartridge temporarily, put it in an airtight plastic tub. Make sure nothing touches the nozzles. Do not use a plastic bag. If you intend to store print cartridges in a tub for a long period of time, place color cartridges with the nozzles down, and black cartridges with the nozzles up.
Nov 25, 2009 | Epson Stylus Multifunction Inkjet Printer/...
I need to get new color toner. It indicates
go into your printer menu to your replace supplies section and turn on your override I did this and was able to print out about another 250 sheets
Oct 06, 2009 | HP Color LaserJet 2600n Printer
I put in new color and black cartridges a couple of days ago and was able to print okay. Now I keep getting ''Remove and Check Black Cartridge'' prompt. I've taken out Black Cartridge, turned off printer,...
hope you put back both cartridges before trying again..try wiping the tip of the black cartridge before replacing it..then activate the head cleaning process..
Oct 03, 2017 | HP G85xi All-Color InkJet Printer
Message in LED is ''Remove and check color cartridge''
It means that the printer has detected a problem with the color cartridge. If it holds multicolors one could be empty & the cartridge must be replaced in order for it to work. Best advice would be to try a new cartridge and see if the error message goes away. Hope this helps.
Mar 25, 2009 | HP OfficeJet V40 All-In-One InkJet Printer
Have put in a new colour cartridge but the note on the printer comes up error 50C
Cartridge Error 50C
Your print cartridge has shorted.
  1. Power off your All-in-One and unplug it.
  2. Plug in your All-in-One again and turn it on.
  3. Uninstall and then reinstall your cartridges.
  4. If this does not resolve the issue, try the troubleshooting steps for the other cartridge errors below.
Error: Black Cartridge Missing
The black cartridge is not installed. (Install cartridge PN 82)
Error: Color Cartridge Missing
The color cartridge is not installed (Install cartridge PN 83)
Cartridge Error
Complete the following instructions:
  1. Power off your All-in-One.
  2. Use both hands to lift up the scanner unit until the scanner support holds it open.
  3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
  4. Remove the color print cartridge.
  5. Lower the scanner unit until it is completely closed.
  6. If the error message reappears, replace the black print cartridge with a new print cartridge.
    If it does not repeat steps 1-3 and then go to step 7.
  7. Reinstall the color cartridge and remove the black print cartridge.
  8. Lower the scanner unit until it is completely closed.
  9. If the error message occurs again, replace the color cartridge.
  10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
  11. Lower the scanner unit until it is completely closed.
  12. If you receive the error message again, replace both cartridges.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 03, 2009 | Lexmark X5150 All-In-One InkJet Printer
I put new color cartri#27 and new black cartri #17 and only use black
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 03, 2009 | Office Equipment & Supplies
Color light will not go out
remove the cartridge close the printer, then again turn on printer and put the cartridge back effectively..
Jun 18, 2008 | Epson Stylus 880 InkJet Color Printer
HP PSC 750 All-In-One InkJet Printer Logo
94 people viewed this question
Ben Johnson
