Question about Hyun Won mobiBLU DAH-1900 MP3 Player
System error Hi, After resetting the device it sends a "system err" message when trying to turn on. No buttons functioning. Thanks Peter
Website www.mobiblu .com
once on page, go to the 'data' option, across the bar at the top
good luck learning a foreign language
Posted on Jun 11, 2008
TPeter 1/14/08
mobiBLU has a "software fix" for this problem. I had the same thing happen to my player. I had to return the machine to them. When I received the machine back, they said that I could have downloaded a program from them. So I went to their site and did. When I returned my player to mobiBLU, they had it for only about 3 hours and put it back in the mail! I shipped it USPS with a "confirmation Return Receipt". It showed delivery at 12:34 PM..and the Return E-mail from them was dated (same day) at 2:57 PM. PRETTY FAST..HUH! I have the Program in my computer. It came zipped. I opened it and ran it. Fixed the problem right off. You can call mobi BLU and I am sure they will e-mail you the program. It is only 2.22 MB. The program IS:
Firmware file version 4.0.100.1190 It even says **SYSTEM ERROR FIX** DAH-1900 Updater M110 060424.exe This Updater Program also has all the "PODDER" stuff on it too! I don't know enough about my computer or I would E-mail it to you!
Good Luck
kboyum@centurytel.net
Posted on Jan 17, 2008
2 Suggested Answers
ThaMp3Doctor
  • 8596 Answers
SOURCE: system error
There are two ways to format an Mp3 player - one on the computer itself, and one in Windows Media Player. Both methods will end up erasing all the songs on the player, but the player will be "good as new" after that. Sometimes reformatting in this manner will override the player's native formatting and cause problems - this can be reversed in most cases by updating the player's firmware. Firmware upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or FAT32. - Connect player to computer, double-click my computer, right click on icon of mp3 player and select format. This only applies to Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
-Tha Mp3 Doctor
Posted on May 28, 2008
My Canon iR 2020 Photocopier machine is giving me message - system eror E001. How do I reset the machine for that eror message to cease?
to reset the error:
Enter the service mode:
press asterix key ( add. functions ) "*"
press 2
press 8
With right arrow, go to CLEAR, press OK, with arrow choose ERR and OK.
Turn off and on.
If these doesn't helps, you need to replace fixing heater.
Jun 13, 2011 | Office Equipment & Supplies
My Ir2800 canon photocopier is not functioning, if I switch the main power button on, I get an error message on the screen wit the code E000003-0000
these is temperature related error, fixing fault.
First you need to try cancel it, follow these steps:
turn on the copier
press *
press 2
press 8
press *
select COPIER
select FUNCTION
select CLEAR
select ERR
OK
turn off and on
If these doesnt helps change fixing film assy ( heater )
Hope that helps
Aug 16, 2010 | Canon Office Equipment & Supplies
Error code E000002-0000
Get in the service mode *28* and there under function, clear, err.
If not replace the fixing film unit
Jan 02, 2010 | Canon (6981A002AA) for imagerunner 2200,...
Message in the display "err 2" and my kettler treadmill doesn't work
Hi Rendra,
Try this:
Switch the treadmill off and then on again.
Push the "minus" speed button and the "stop" button simultanuously.
If all is well you will now have entered the maintenance mode.
Next push the "plus" speed button and the "stop"button smultanuously.
Now you you've reached the error mode.
Push the "plus" or "minus" speed button to browse the error codes untill you've reached "L er".
The push start to erase the message.
Turn the power off and then on again to restart the treadmill.
With any luck the error has disappeared and the treadmill will function again. If not.....you'll have to contact Kettler.
Btw...This error occurs when the belt is "pushed" by the runner. For example when you put weight on the handlebar and the push your feet backwards.
May 10, 2009 | Exercise & Fitness
I have a canon 4080i error code e000004-0401 comes up and have to shut down when retart get the same message.
you have a fuser related error code, either thermisters or thermo fuse.
to reset error code you need to go in to a service mode and reset it.try this hit the additional fuction button then hit 2 and 8 keys together and additional function button again that will put you into service mode BE very careful in there though.
under function/clear/err code highlight err code then ok reset machine see what happens if error code comes back then you need to get a tech to have a look at ya fuser
Canon Tech
Apr 09, 2009 | Canon Office Equipment & Supplies
Error E000001 -0010
The error code is for the fixing assy not getting to the correct temperature in a specified time. The 0010 part of the code is indicating the copier was turned off and back on without resetting the error. To reset the code, Press the additional function button, then the numbers 2 and 8 at the same time and then the additional function key again. The display will now be indicating the service options available. Touch COPIER, then FUNCTION at the top of the display, the CLEAR in the middle, then ERR, then OK. Power down copier at the right side rear, then turn back on. If the error comes back then you will have to check the fuser assy to see if the front drive gear has failed or one of the thermistors has gone bad. Good luck
Mar 06, 2009 | Canon imageRUNNER 5570 Copier
Nikon N75 - error message, nothing working.
You have to reset the rewind counter by pushing the two buttons simultaneously - one on the side of the lens mount, the other by the release button - red, cassette symbols. This tells the camera there's no film in it.
Nov 30, 2008 | Nikon N75 35mm SLR Camera
System error
-Tha Mp3 Doctor
Feb 11, 2008 | RCA OPAL M4001 MP3 Player
Error message on screen E000001-0002
E000001-0002 refers to the fuser assy either getting to hot or not hot enough. Fuser error codes cannot be reset by power cycling the machine even though that is what the display tells you to do. In order to reset the fuser error code you must enter the service mode & reset the code. To enter the service mode: press"Additional Functions" button (looks like a picture of a head with a star inside) press the #2 and #8 at the same time (simultaneousley) press "additional functions" again The display should show a choice of copier,feeder,sorter,fax,or board service modes Select copier select clear select ERR press OK Turn power off & back on. ****IMPORTANT**** After clearing error stay at the machine to see if it comes to ready. The fuser assy can reach 139 degrees C.(Water boils @ 100C) The error can only be cleared through the service mode because a technician should inspect the fuser to verify there is nothing faulty that could possibly start a fire. If you enter the service mode & clear the error, power cycle the machine & during warm up the machine throws a code again- turn it off, unplug it & call a tech for fuser repair. Good Luck!! I can be reached @ bspier@carlsonsupplies.com if you have any questions.
Sep 21, 2007 | Canon imageRUNNER 2200
Hyun Won mobiBLU DAH-1900 MP3 Player Logo
252 people viewed this question
Top Hyun Won Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Hyun Won Audio Player and Recorder Expert? Answer questions, earn points and help others
