Question about Bosch 22 in. SKT5108 Free-standing Dishwasher
Filter I have a free standing Kenmore Ultra wash and I would like some help on locating the filter and cleaning it out... you can come over if you like, otherwise you can just email the answer..., thanks, Hannah.
5 Suggested Answers
  • 148 Answers
SOURCE: Kenmore Ultra Wash Dishwasher wiring diagram
if unavailable on line, contact mfg's parts and you should be able to order it.
also, they likely do not make the unit. the sears may be able to tell you who made it. that company would be able to get you a diagram. just make some phone calls.
Posted on Dec 21, 2007
  • 1314 Answers
the odd shaped screws are called trox screws and can get a set of drivers any where also pull the hose off the sink connection and check it there the main motor reverses and acts as the drain pump if you recently installed it to a garbage disposal make sure you knocked the plug out where the dishwasher connects if not check the hole there i found a olive pit in one one day now when you go to by the trox drivers and a bunch of things are using them now days get the set in the metal case that fold out like a pocket knife if you know what i mean and the drain hose must come up 20 inches and then loop to the sink drain so let me know what you find and if i can help further
Posted on Mar 18, 2008
  • 83 Answers
SOURCE: Kenmore Ultra Wash dishwasher
check and see if you are getting ac 110 volts to your water vave when trying to start the unit. if no power check your breakers and /or the incoming power to your dishwasher if they are ok and show 110 voltage coming to the unit then you probably have a control board or touchpad problem which would need a little more detailed check out.
If you do have ac 110 to your water valve then you may just have a bad water valve. Because the washer has to fill first. Hope that helps!!
Posted on Jul 02, 2009
  • 1136 Answers
SOURCE: All filters are clean, but water will not come in
Hi, Check the float in the front corner and make sure it moves up and down freely. Also, you can check voltage at the inlet valve. It should get 120V at the start of the wash cycle. If there is voltage, the inlet valve will need replaced. If there is no voltage, the float switch needs tested. It is usually the inlet valve or the float.
I hope this helps you. Please let me know if I can assist you further.
Posted on Jul 04, 2009
Daniel S
  • 4323 Answers
SOURCE: kenmore 'ultra wash' dishwasher not
If the drain pump assembly is cleaned completely then the issue is with the drain pump that is bad and should be replaced. Hope this helps...please post back for further assistance.
Posted on Jan 31, 2011
0 characters
1 Points
Have a kenmore ultra wash , the spinning arms turn very slowly , not much pressure ,I checked for any blockage there is none , why?
Their are 2 possibilities
1) not enough water in the tub..water should be level with or just above heat element. IF not enough water in tub the water inlet valve is what i suspect is why
2) the pump filter is clogged and water is having a hard time flowing into the pump to be circulated.
this youtube video will show ya how to take apart the pump to get to and clean filter.
Aug 25, 2011 | Kenmore Dishwashers
I have a Kenmore Ultra Wash model 665 1373 and it isn't getting totally clean on the top rack - glasses and cups are almost clean but bowls etc are not, any ideas?
Check the shaft of the impeller, the plastic shaft might be broken, it was the problem with mine. To get to the impeller you have to remove the filter at the base of the diswasher and after you will see the screw that hold the impeller assembly in place, unscrew it and you will see right away if it is broken, Good luck
Jul 16, 2011 | Kenmore PRO 24 in BuiltIn Dishwasher with...
I have a Kenmore Ultra wash 665.16522. The water won't drain completely. About 2 or 3 inches of water will stay at the bottom. I wonder if there is a food catcher, and if so, how do I clean it? JSBravo
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller. Hope this helps... Please post back for any further assistance.
Mar 16, 2011 | Kenmore 16522 Built-in Dishwasher
The top rack on my kenmore ultra wash 3 dishwasher does not come clean and now even the bottom is starting to not clean
First perform a vinegar cycle wash in the dishwasher. Pour a cup of vinegar into the bottom of the dishwasher. Keep the temperature at the highest setting possible and perform a wash cycle.Then start using a dishwasher most probably that would solve the problem. If this does not solve the problem then there must be some parts worn out or faulty creating the problem.
There are many probable causes of failure .
To clean the dishes the water temperature is essential.It the water is not hot then the dishes will not be cleaned properly.So check the water temperature.
Also check the filter in your dishwasher.Clean the filter if there is accumulation of debris in the filter
If you are in an hard water zone , then try reducing the amount of detergent used and then try cleaning the dishes.
Dec 23, 2010 | Kenmore PRO 24 in BuiltIn Dishwasher with...
Dishwasher that leaves dishes dirty
Your drain could be blocked, remove the drain from the trap below the sink and try running the unit on drain, into a bucket. Also check the connection at the trap to ensure it is free from blockage
Mar 19, 2009 | Dishwashers
My kenmore dishwasher isn't cleaning the dishes very good
Your broblem is probably the cutter/chopper filter. This is located under the bottom cleaning arm assembly.
Remove the baskets.
Remove the bottom washing arm. Unscrew the centre post and lift off the arm
Remove the conduit to the top arm(s). Remove screw at top and at back. Rotate the conduit assembly 45 deg right and lift off.
Remove 4 screws (Star T-20 bit) and lift whole assembly out. Pop off screen and clean.
Remove cap over cutter/chopper. There is one screw at left front under assembly just removed. Remove it and the plastic cap (Needs some wiggling to free it up). Remove the cutter and filter. It is on a spring loaded pin. Pull in foreward and also lift the filter disc up and out. Thoroughly clean the filter.
Dec 01, 2008 | Dishwashers
Decible level for a Kenmore model 16625691 ultra dishwasher
Nov 12, 2008 | Hobart AM14-253 Free-standing Dishwasher
Kenmore ultra wash model 16625691
looking for a black/almond front replacement panel for my Kenmore dishwasher model #16625691. Any sugguestions as to where to find one?
Oct 17, 2007 | Hobart AM14-253 Free-standing Dishwasher
Need to remove wash module
You should be able to hold the spray arm and unscrew the center section to remove the entire assembly. Be aware of any washers or other parts that need to be re-installed when putting it back on.
Jun 13, 2007 | Kenmore 24 in. 16032 Built-in Dishwasher
Bosch 22 in. SKT5108 Free-standing Dishwasher Logo
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
prem mathew
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
