Denon S301 picture and sound
Hi expert(s),
I bought a Philips (32PFL5332) television and connected it to my brand new home cinema Denon S301 via a HDMI cable.
1. How can I get the sound of my TV-program out of the Denon speakers?
2. When I play a DVD I can hear the sound, but there's no picture. Why?
Thanks in advance for solving my problem.
Rgds,
Trudy
  • 7 Answers
SOURCE: no sound from ps3 to home cinema via an optical cable
If you have not run the set up you will need to, however I'm guessing you did because you would have had to make some changes to the settings to get the image to come up on the screen but without being physically at your location I can just guess.
In order to view your PS3 in full 1080p you need the HDMI cable which you already have. If you have not gone into your video settings then you are not viewing via the HDMI cable and you will need to to get things working right.
In order to view via the HDMI cable you would have had to had both the standard PS3 interface cable that comes in the box (the one that goes from the PS3 to your tv with the composite video (yellow) and the left and right audio (red and white) and the HDMI cable pluged into your PS3 and your tv at the same time. then you turn on the PS3 making sure your TV was set to whatever imput the composite and left/right audio is pluged into (typically VIDEO 1,2,3 ect.) and enter the menu, go to the settings and then down to your display settings and change it to HDMI, the image should then leave the screen (because it switched to HDMI) you will need to have your TV remote handy for this because you will need to switch sources on your tv to HDMI 1,2,3 ect, which ever one you have it pluged into. When you have switched to the right HDMI imput there should be an on the screen that is counting down and asking you if you want to accept the changes. Select yes and Move on through the settings selecting the maximum resolution your tv is capeable of
720, 1080i, 1080p) which can be found on the box the tv came in or somewhere on the tv or manual. While running this settings change it should ask you the audio source you are using make sure you select Digital Optical and that it is pluged in to you PS3 and your reciever. Once this is all done you can remeove the standard PS3 hook up that came with the box and put it away you wont need it any more, unless you move the PS3 around and the tv you move it to does not have HDMI in which case you will have to change the settings before you move it back to the standard cable or you will not be able to see it displayed on the tv sceen you move to and it will be impossible to run the settings.
If you have already done that and just want to verify that your source for audio originating from the PS3 is digital optical you can check that in the same settings menu under audio settings. Then make sure the reciver is on and set to whatever imput you have the cable pluged into and you should be good to go.
If all that I have described has been done already then the audio cable could be bad or the problem lies internaly with the PS3 or the reciever.
Good Luck hope this helps
Posted on Oct 04, 2008
  • 905 Answers
SOURCE: HDMI to DVI gives pink screen
try a regular video input on the tv and on another tv, and if that pink is on both tv's then its the dvd but if it only does it to that tv your hooking it up to then there is a problem with the tv video input
Posted on Oct 12, 2008
mistersony
  • 320 Answers
SOURCE: SONY DVP-NS57P does not display video
If your TV has no input selector but has a video input, the TV probably "hides" the video input between the lowest channel on the tuner and the highest channel. That means if your tuner goes from channel 2 to channel 119, the video input will be between 119 and 2. The best way to see if this is the case is to slect channel 2 and then use the up/down channel selector to go down and see if you find the video input. Let me know if this works!
Posted on Nov 02, 2008
  • 33 Answers
SOURCE: sharp television and panasonic cinema system with hdmi connection
Ok, here's the deal. You can have sound being putout from hdmi coming from one of those sharp units, but it just depends on how you are connected. If you are using a digital audio output, from the tv, it wont push out the sound the way that it should. You will have to downgrade to using audio composite cables to connect to your external speaker system from the audio ouputs, not the digital audio outputs. Its not designed to push out sound from an hdmi cable. The BEST way to have this setup is to run your sound directly from the cinema to the external audio source(leaving the hdmi cable in the tv).
Posted on Dec 12, 2008
SOURCE: Can't get tv sound from home cinema system speakers
you need an optical cable going from the TV to the home cinema for an audio output, it worked for, had the same problem!!
Posted on Dec 26, 2008
Philips: HTS3520 doesn't use surround from HDMI feed from SKY
Check your connections and the settings in the menu.
Good luck
Mar 11, 2014 | Philips HTS3520/05 5.1 ch Home Cinema...
Denon 1312 receiver composite video inputs do not work.
I'm having the same problem with my Wii output. The manual for the Denon AVR-1312 says that analog video signals (i.e. component/composite outputs from the Wii) are not converted to digital video signals (i.e. HDMI output from the rcvr). I'm running only HDMI to a projector, so the video signal is essentially lost. The fix appears to be to run an additional composite cable all the way to the projector. Sounds like your fix is the same. No Wii tonight! :(
Jul 07, 2012 | Denon AVR-1312 5.1-Ch A/V Home Theater w/...
Denon dvd-2900 suddenly has music and background sound but no dialogue
Is there subtitles instead of the dialogue? Sorry, may be an obvious thing that you have already checked.
Jan 22, 2012 | Denon DVD-2900 DVD Player
No sound from TV when connecting Philips HTS3530 Home Cinema to Sony 32CX520 TV, but there is sound from radio and satellite box. Connection through scart or/and red, white and yellow plugs. There is no...
I am buying Philips HTS3530 home cinema, and I saw that there is some difficulties connecting it to Tv (40' Samsung smart Tv) Is there any cable which u need buy (i have HDMI).
Thank you
Sep 14, 2011 | Televison & Video
Help with connecting home cinema to xbox
if your tv supports this. go to ebay type in "hdmi" buy one for around $10.00 plug into xbox. set your tv to which port you have ,(if you have more then one). bingo,bango ,your done.
"no hdmi"? and you have com. on your tv. plug corrosponding color plugs for component ,L&R audio plugs .
change tv to comp.( not video) your done
Jan 30, 2009 | Audio Players & Recorders
Configuring two soundcards for parallel functioning
a windows computer can only use one sound card for one function
you can use the internal sound card for output
you can use the usb sound card for input / recording.
you can't use both for both.
Start -> control panel -> sounds and audio devices properties
open up audio page
You can have one device selected on Sound playback
You can have one device selected on Sound recording.
you can change which sound card is used for which function on this page. if you want to use the internal sound card set both settings to the internal if you want to use the external change both settings to the external.
Jan 09, 2009 | IBM Lenovo ThinkCentre M55e PC Desktop
Windows does not play nicely with 2 sound cards. Perhaps one of these days Microsoft will get out of the stone age and recognize other options, but for now, the general consensus is that it is not feasible.
About the only thing I have seen is to turn off one sound card in the hardware profile, but that is not what you are trying to do.
Jan 09, 2009 | ASUS VIA Apollo Pro Plus Chipset P2V-B...
How do i get the sound from my Philips TV into my samsung 2.1 home cinema system?
To get sound from any TV (including Philips) to an amplifier or a home cinema system, the TV should have a LINE OUT RCA pair. Thereafter, it is a simple case of connecting said Line OUt to one of the INPUTs of the cinema system.
Often (but not all), Cinema Systems have their own TV tuner and would provide a video out that could be connected to the Video IN of the TV.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 19, 2008 | Samsung Televison & Video
Trying to install a new 50
a good way to go is to connect the home cinema kit staight to the tv though phono leads, see if your tv has a phono in and out this must not be a av socket. you should then connect it in to your cinema kit so what ever you watch comes though ur cinema system
hope this helps
Feb 09, 2008 | Televison & Video
37pf7531 tv
If you have a later Philips home cinema model: HTS3100, 3300, 3500, 3154, 3357, 6510 & others, the sound from the TV will go through the existing scart connection.
Just select TV on the home cinema remote control.
For any other models, use a scart - twin phono lead (red & white), from the TV to one of the inputs into the home cinema.
Scarts 1 & 2 on the TV will have different results. Try both.
Nov 29, 2007 | Philips 37PF7531D/10 37 in. LCD Television
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
