Question about Kodak EasyShare DX6490 Digital Camera
Kodak Easyshare Z700 Camera
One of my students dropped our Easyshare Kodak Z700 camera. The lens won't close. You can hear it trying but it keeps shutting itself off. We've tried a different battery, pulled the card but don't know what else to do.
  • moonteetee May 05, 2009
    camera error #e45 - see users guide
Camera erro #b03 - see users guide
Posted on Mar 20, 2008
  • 34 Answers
You will probably have to send it in for repair.
Posted on Feb 29, 2008
6ya staff
SOURCE:
Kodak m1063 lens stuck closed won't open
I suggest you take your camera to a digital/Kodak camera repairer.
Apr 18, 2013 | Kodak EasyShare V1003 Digital Camera
The lens don't close all the way
Hi there:
I suggest check in this link, some tips about fixing-lens-error-on-digital-camera.
Hope helps.
Aug 17, 2012 | Kodak EasyShare Z700 Digital Camera
Lost software for my z700
You can download Kodak Easyshare software from
http://support.en.kodak.com/app/answers/list/c/890/selected/true
You might want to consider NOT connecting your camera to your computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Jul 11, 2011 | Kodak EasyShare Z700 Digital Camera
My camera lens is stuck in the closed position. When I turn the camera on, the motor runs, but nothing happens. I accidentally picked the z740 camera when posting the proplem originally, but the z700 is...
If you've dropped the camera you may have damaged the lens housing - which will require professional repair, but the problem you describe is frequently due to corroded battery contacts inside the camera. Remove the batteries and wipe the camera contacts firmly with a clean cloth (heavy corrosion may require cleaning with a fine wire brush, steel wool, or fine sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, clean the contacts at both ends of the batteries, and reinsert them in the camera. This cleaning cures the problem about 90% of the time, and I hope it works for you.
Aug 31, 2009 | Kodak EasyShare Z700 Digital Camera
Lens shutter one side is loose and flops
the only place i've ever seen that fixes small digital cameras like that is portatronics, but it's a mail-in business.
Jan 15, 2009 | Kodak EasyShare Z700 Digital Camera
Kodak Z700
Tentative solution:
I had the identical problem. I went as far as disassembling the camera ... not recommended.
Instead of fussing with the lens cover, I pressed on the lens assembly (gently), the lens retracted and the lens cover closed.
My camera works now. It will be my last Kodak.
Good Luck,
Mike
Jun 08, 2008 | Kodak EasyShare Z700 Digital Camera
you have a problem with your lens alignment try to turn it lightly and push it or tap it..
May 15, 2008 | Kodak EasyShare Z700 Digital Camera
Powers off
I have the same problem. Removing the memory card and then starting up seemed to fix it; the camera would then start up ok even with the card in.
Nov 24, 2007 | Kodak EasyShare Z700 Digital Camera
Lens Error
the mechanism is wrecked. Kodak will quote a repair price you won't like it much or you could simply buy another camera
Oct 05, 2007 | Kodak EasyShare Z700 Digital Camera
Kodak EasyShare DX6490 Digital Camera Logo
118 people viewed this question
Top Kodak Cameras Experts
Ekse
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Kodak Camera Expert? Answer questions, earn points and help others
