Question about Motorola Mobility RAZR V3m Cellular Phone
Ring settings seem to change by themselves
It seems that my ring styles change automagically, actually it seems that the button on the side of phone is unintentionally being pressed. So my phone changes from vibe and ring, to vibe then ring and then to silent. Silent is not what I want.
Is there a way to disable the side button and only change through the settings?
Thanx
  • lrharley Jan 23, 2008
    Same Problem here. It goes from Ring to Silent which causes me to miss calls.
  • 4jjjjs Feb 04, 2008
    My husband has the same thing but and I don't think locking the keypad will lock the side buttons on the phone. Now we are experiencing his ringtones are really faint even set at loud - volume 7 - you can barely hear them - something else is going on. He says it is a junk phone.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 105 Answers
First you cannot change what is there,just use the keypad lock it solve our problem....
Posted on Feb 01, 2008
6ya staff
SOURCE:
My phones ring style is set to loud detail and volume is at the highest being 7,when I recieve a call it is silent?
Hi There,
As per my understanding you have set your ring style profile to loud and highest volume 7 but still ur phone phone rings on silent when someone calls..
Please change the Profile setting once again as mentioned below:
How to change call alerts and styles?
1.From the general menu, select "Settings" > "Ring Styles" > "Style Detail"
2.If you select one of the styles, ie. "Loud" you can then highlight by scrolling down on the wheel & select "loud detail" & press on the "change" button (top right corner key).
3.Here you will be prompted to change any feature available to the "loud" style: volume, ringtone, alerts, voice mail, text messaging sounds, reminders beeps etc etc. All you need to do is to select the feature you need to change with the directional wheel and press the "change" button for each.
If you think my solution helped u to resolve ur issue please do vote for me..
Thanks
Enjoy!!!
Oct 28, 2010 | Motorola Mobility RAZR V3
MOTOROLA W376G...turn off phone on ringtone
Hello!
Set phones ring style as "Vibrate then Ring" , "Vibrate" , or "Silent" to avoid the power on alert.
I set my ring style to "Vibrate then ring" so that I dont have to change the settings everytime I turn it on or forget to so when I receive phone calls or alerts it still rings & then I dont have to go back and change the settings again when I turn tha phone off so that is dosent have the power on alert.
This is the Only way I have found to turn the phone power on tone/alert off.
Change Ring Style:
-Go to Main Menu
-Settings
-Select Ring style
-Then choose change, & set it to the ring style you want.
Feb 21, 2010 | Motorola Mobility W376 Cell Phone
My Motorola Razr won't ring or vibrate when receiving an incoming call except when plugged in to the charger
Turn off the ringer id function in settings, ring styles, load detail, ringer id's off.
Hope this helps
Jan 11, 2009 | Motorola Mobility RAZR V3
Motorola w377
Like most of the W377, this one's very odd. The only way I know how to do this is to switch off all Key tones. Key volume is part of the Ring Style menu, so:
>Settings
>Ring Style
>Ring Detail
>Change
> On the Detail menu use the 4 way selector arrows to cursor down to Key Volume
>Change
>0
>Ok
>Back out
NB The Ring Style settings for ALL ring parameters (Ring Volume, Line 1, Text Msgs, Voicemail, Alarm, and Key Volume) change whenever you select a different Ring Style, so you can set up one ringtone in Loud Ring but get a different one for Soft Ring, a different one for Vibrate and Ring, a different one for Vibrate then Ring, etc.
For the sake of sanity (and to avoid the alarm waking me up with a loud blast of Bach when I wanted a quiet 'Ding') I have set the same ringtones etc in all of the above profiles.
BTW whenever you can't find a menu you need, try pressing the black round button (OPEN MENU) in the middle of the 4 way selector arrows - it opens submenus that can't be accessed any other way.
Hope this helps.
Jan 02, 2009 | Motorola Mobility W377 Met Silver/Pink...
My razr does not ring when someone is calling
volume may be turned off or down or it is set on silent. go to settings, go to ring styles, select style and edit/add. scroll down to the ringer of choice and hit select. hopefully that will work. also try the volume on the side of phone. by pressing top left button, you can change ring styles that way.also controls volume.
Jun 27, 2008 | Motorola Audio Players & Recorders
Ring tones are all distorted
if you having distorted sounds even if you change the ring style and deafault ring tones' the problem is the speaker buzzer of your phone....:D
Apr 09, 2008 | Motorola Mobility RAZR V3
Pebl U6 I have a menu at the left of my screen but can't figure out how to remove it. The phone seems to have limited funtions. I owned one before this one and didn't have this problem, would...
show/hide menu icons
Show or hide menu feature icons in the home screen:
menu > Settings > Personalize > Home Screen > Home Keys > Icons > Show or Hide.
change menu icons & home keys
Change menu feature icons, soft key labels, and smart key function in the home screen:
Menu > Settings > Personalize > Home Screen > Home Keys.
external display
Set external display orientation:
Menu > Settings > Initial Setup > External Display > Left Orientation or Right Orientation.
language Set menu language:
Menu > Settings > Initial Setup > Language scroll Set the highlight bar to stop or wrap around in menu lists:
Menu > Settings > Initial Setup > Scroll.
ringer IDs Activate ringer IDs assigned to phonebook entries and categories:
Menu > Settings > Ring Styles > style Detail > Ringer IDs
ring volume a > Settings > Ring Styles > style Detail > Ring Volume.
keypad volume
Menu > Settings > Ring Styles > style Detail > Key Volume.
Mar 30, 2008 | Lands Phones
Razr v3
Can you not go to sounds and set a ring tone from there?
I Used to have a Pebl U6,and thats how i set my ringtones.
Hope I Helped.
Sophie x
Feb 13, 2008 | Motorola Mobility RAZR V3
Ringing styles problem sir,,
try resetting your phone to its factory settings...
Oct 16, 2007 | Motorola Mobility RAZR V3
Changes ring style when charging
My phone also does this and its something Motorola have built into the phone. Can't change it I'm afraid!
Jan 13, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3m Cellular Phone Logo
82 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
Lawrence Oravetz
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
