Question about Sony Playstation 3 (PS3) Console
PS3 - Screen Flicker
I have a 40GB PS3 connected to a Samsung LNT4661 and when I turn on the unit everything is fine at first. About 30 seconds after the menu appears, the screen starts to flicker (the display jumps around) and at times the screen goes blank. After 3 or 4 minutes everything is fine. What can I do to fix this?
  • 1 more comment
  • dbtink Jan 14, 2008
    I wanted to add that my cable box and dvd player displays fine on the tv. Not sure if it's the cable or the PS3.
  • nick1189 Apr 17, 2008
    i have a samsung Full HD N8 40" LCD connected to my 40 GB Ps3 via HDMI. and the same thing happens to mine, after 30 or so seconds it starts to flicker (like a snowstorm) the screen will go completely grey and after a couple of minutes of that, everything is fine.
  • Anonymous May 11, 2010
    the problem has to be with the tv is it NTSC perhaps?
You need to try a new HDMI cable.. Cheap HDMI cables do that? I had the same thing happen to me... I switched the HDMI cable and it fixed mine.
AV
Posted on Nov 12, 2008
Its for sure not the HDMI cable. I've got a high end shielded cable and still the flicker occurs. I'm also using HD Samsung 40" screen and have the same flickering going on for various intervals on the XMB. Any settings on the SAMSUNG TV that can solve this or is SONY doing something to remedy the problem?
Posted on Oct 21, 2009
How do I adjust the settings to fix the problem?
Posted on Jan 17, 2008
6ya staff
SOURCE:
PS3 Discs Not Loading.. (Dvds, Cds) We Opened Up The PS3 And Checked The Drive And Cleaned The Lens And Dusted Off Everything Pretty Much And We Put It Back Together And turn it on Still Not Working Jus...
Welcome to Fixya
Try the troubleshooting procedure below:
Step 1 - Turn off the playstation 3 by holding the power button on the front of the unit till the power light is red.
Step 2 - Touch and hold the power button, you will hear the first beep, meaning the playstation 3 is powering on. Continue to hold the power button and after about 5 seconds, you will hear a second beep, indicating the video reset. Continue to hold the power button and after about 5 seconds, you will hear a third beep and the system will power off (power light is red).
Step 3 - Touch and hold the power button, you will hear the first beep, again for the playstation 3 to power on. Continue to hold the power button and after about 5 seconds, you will hear a second beep for video reset. Continue to hold the power button and after about another 5 seconds you will hear a quick double beep. At this point release the power button. if you succeeded in activating the safe mode, you will see a message on the screen saying 'connect the controller using a USB cable and then press the PS button.
Step 4 - Perform the safe mode options in the following order until one of the options works for you. If one option works, do not continue onto the other options.
Restore Default Settings
Restore File System
Rebuild Data Base
Restore PS3 System etc...
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Dec 31, 2010 | Sony Playstation 3 (PS3) Console
I move my ps3 to another hdmi tv but i cant get a picture.
HDMI doesn't usually like being plugged in live so turn everything off before you connect leads
On the PS3 you might have to reselect the output preference so hold on the power for a few seconds, you'll hear multiple beeps and hopefully it will auto select the resolution etc.
Jan 30, 2010 | Sony PS3 40GB Best Sellers Bundle Console
PS3 Blue Ray White lines on left side of TV
I have the same TV, and a Sony BluRay player (not a PS3). I have the same problem.
I found it only does this when playing back 24p disks. My player has an option to disable 24p output to the HDMI, and it "fixes" the problem.
Not really a fix, but a workaround.
Not sure whether it is the TV or player, and sometimes I have fixed it by turning the tv off and on multiple times.
I am going to test the player on another monitor and see if it does the same thing. If so, the player is going back to the store.
Jul 22, 2009 | Sony Playstation 3 40GB System Console
When PS3 boots the screen turns green with white dots
Emergency cooling should be cleaned. If not cleaned, you risk expensive repair.
Oct 24, 2017 | Sony Playstation 3 (PS3) Console
PS3 not working on 42'' JVC via HDMI cable port
I have the PS3 and this TV and it works....Try this.
1. Turn ON TV
2. Connect HDMI from TV to PS3
3. Select the correct HDMI input on the TV for the PS3(important)
4.Turn OFF PS3 if it is ON.
5. hold [I/O] Power button on PS3
6. Wait about 5 second and you should get the "HDMI Detected" or some similar message.
7. Configure the HDMI output for the PS3
Also, If you set the PS3 to "auto" for hdmi, it may set the resolution to 1080i. You may want to deselect everthing but the 1080P.
Mar 24, 2009 | Sony Playstation 3 40GB System Console
PS3 does not work in 1080p
My ps3 didn't like a HDMI connection very much. I tried the Composite input cables and they worked great with no screen flicker.
-Captain Jake
Feb 13, 2009 | Sony Playstation 3 (PS3) Console
Samsung 215TW Monitor Flicker
Its the capacitors on the backlight power supply. Samsung installed crappy ones and they blow up after a year or two. Change out the caps and you're good to go
Jan 30, 2009 | Samsung 215TW SyncMaster 21" LCD Monitor
Problem connecting HDMI cable
Hey there I don't see why your playstation 3 should be doing that other than the console being defective. Sony doesn't have this problem that often and actually this is the first time i have heard of such problem. Try making sure the the HDMI cable is connected at both ends all the way in and also make sure your Samsung is a 1080P which i am pretty sure it is and finally if you have a friend or another 1080P HDTV in your house i would try and see if your ps3 will support the 1080P feature. If you still have the problem even when you use a different TV then its the ps3 that is malfunctioning otherwise it would be your Samsung. Let me know how that turns out alright.
Oct 04, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
1,670 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
