This problem should be removed because:
Problem with Vacuums
Where can I find a belt for my Fantom Fury vacuum and how do I replace it?
Solutions (1)
You can get replacement belts and view the manual here:
Fantom Fury Replacement Belts and Manual
Testimonial: "Thank you! Very helpful and speedy response."
Suggested Solution (3)
HOW DO I CHANGE THE BELT ON THE FANTOM® THUNDER® AND FURY®?
- Unplug the machine.
- From the front of the machine, remove the collection bin.
- Facing the back of your vacuum, remove each of the Philips head screws located above each of the rear wheels. (Figure 1)
- To remove the base cover, place your thumbs in the two screw holes in the back of the machine. Push forward and up on the screw holes to disengage the 3 cover locking tabs. Put the cover off to one side, and go to the front of the machine. (Figure 2)
- Check the drive arm for any black streaks which indicate residual rubber from the last belt. The drive arm is located on the right side of the motor. The easiest way to remove any residual rubber is with some nail polish remover on a rag or with steel wool.
- To attach a new belt, remove the brush from the base of the machine by pulling up straight up with two hands.
- Take the new belt and hook it over the steel drive arm. Pull back on the belt slightly, to create some tension.
- Put the brush inside the belt loop so that the track for the belt is aligned with the belt itself.
- Replace the brush by aligning the metal end so the points face downward. (Figure 3)
- Rotate the brush by hand to check that the belt is running freely and easily in its designated space between the bristle.
- Replace the cover by placing the nose in first. Once in place fasten with the two cover screws and then replace the collection bin.
Source: fantom fury vacuum
You will have a blockage in the vacuum hose. Take it of and outside and push the garden hose from one end to the other.
or the intake from the vacuum sweeper bar to the canister is plugged. You may have to take the top off the vacuum and clean out the passageway to the canister. Need a long screwdriver or a hanger to clear the clog.
Here is a link to the parts available for your model of vacuum:
http://www.appliancefactoryparts.com/vacuumcleaners/brands/fantom/fm310k.html
And here is the link to the belt that you need (part number XFB1310):
http://www.appliancefactoryparts.com/search/partinfo.php?partsID=1043859&modelsID=137895&typeName=vacuum cleaner
Just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information and items at the website indicated.
I hope that was helpful to you, good luck.
If you choose to rate this solution using the Thumbs Up scale provided, I thank you very much for your time and consideration.
Joe.
Source: Is my vacuum FM310K considered
Add Your Solution
Fix-O-Meter
128
128 people viewed this problem
- 2 people found this problem to be helpful.
- 0 people are following this problem. Be the first!
Top Vacuum Experts
Recommended Services
Small appliance repairs Vacuums and steam cleaners
General small appliances
Diagnosing problems and repairs -
quick and easy service quality and reliable technician
quick and proficient service
18+ years experience -
Vacuums problem? Missing your Manual or User Guide?
Need a source for replacement parts
Looking for troubleshooting advice?
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
