Question about HP PSC 1210 All-In-One InkJet Printer
HP PSC 1210 All-In-One InkJet print problem
My printer feeds a sheet through before printing and another after printing. Bothe these sheets contain no printing. All other functions appear to be OK. Anyone got any solutions?
    President:
  • 4,402 Answers
Follow the steps below to enable or disable the cover page option in Microsoft Word.
  1. In Microsoft Word, click File , then Print . The Print window opens.
  2. In the bottom-left of the Print window, click Options . A new Print window opens.
  3. Do one of the following:
    • Select Document Properties to enable cover page printing.
    • De-select (remove the check mark from) Document Properties to disable cover page printing.
  4. Click OK to close that window.
  5. Click OK again to print the document.
Posted on Jan 15, 2008
Hi I have HP 1210 All in one, and now it wont print. It tell me to check paper (none there, even inside..) and cardridge. And whats more important, when I turn it on, cardridge start riding from left to...
hi
1. 1 Switch off the printer and disconnect the powersupply. Allow any residual charge to fade away before putting your hands ormetal tools inside the chassis. 2. Step 2 Pin down the exact location of the jam. Thethree hot spots for a jam are the paper tray, anywhere between the feed trayand the print carriage, or between the print carriage and the output tray. 3. Step 3 Take off the front paper tray if the sheet gotstuck while it was still in the front area of the printer. If the sheet jammedhere, you should be able to see most of the paper. 4. Step 4 Pull on the sheet with both hands and steadypressure. Do not tug as you might rip the paper, leaving a chunk of it deeperin the machine. 5. Step 5 Open the back panel to reach paper jammedbetween the feed tray area and the print carriage of the all-in-one printer.Carefully remove the jammed paper from the machine. 6. Step 6 Use the carriage access door to reach a jamfurther inside the all-in-one printer. You may need to move the print carriageout of your way to clear the jam. 7. Step 7 Return any access panels to their closed andlocked positions. Plug your printer back in and flip the power switch.
Jun 14, 2011 | HP PSC 1210 All-In-One InkJet Printer
Sheet feed on switch on
paper sensor clean & roller check
Nov 30, 2009 | HP PSC 2355 All-In-One InkJet Printer
I have re-installed my printer. It prints, but doesn't print anything what's going on?
I think you mean it sheet-feeds but does not print. If so, power off. If network connected, power off the print server. Power all back on after a minute. Depress power button on printer for 10 seconds.
If auto test page prints, problem is with printer configuration on your computer. Check the configuration carefully. Did you uninstall with the HP Scrubber utility before you did the re-install?
In If the test sheet feeds but does not print, use the HP printer utility, check ink levels, check cartridge "expiration", and clean heads several times. Test again.
Oct 21, 2009 | HP PSC 1610 All-In-One InkJet Printer
I have printer HP PSC 500 S/N SGH02E112T WORKED FOR 5 YRS - NOW WILL NOT PRINT EXCEL SPREAD SHEETS OR WORD DOCUMENTS - STILL PRINTS EMAIL AND INTERNET DOCUMENTS HAVE HAD OTHERS CHECK SETTINGS...
Friend,
There's apparently a problem bwtween your Office suite and the spooler. Usually uninstalling/reinstalling the Office suite will fix the problem. (please do a backup of all your Office documents before proceeding!)
When reinstalling, please make sure that any antivirus program is shut down or deactivated during install, in some cases for example Norton Antivirus will block files that need to be updated, causing problems. You SHOULD use some form of virus protection when using your computer, don't get me wrong! :)
//Al
Mar 08, 2009 | HP PSC 1210 All-In-One InkJet Printer
Cannot align print cartidge on HP PSC 1315
i have the same problem. i think mine centers around the fact that i refuse to spend the money to buy a color cartridge. i believe the alignment sheet must be in full color.
i did find a very strange solution to preventing the alignment page from printing, but i haven't tried it yet. http://h30434.www3.hp.com/t5/Printer-All-in-One-Software-and/Alignment-Page-HP-PSC1315-prints-every-time-printer-is-turned-on/m-p/224243
not a solution, but it might help...
Dec 22, 2008 | HP PSC 1210 All-In-One InkJet Printer
Alignment sheet prints---cannot print anything else
u will have to first scan the alignment paper in your scanner this will solve your problem
Nov 14, 2008 | HP PSC 1315 All-In-One InkJet Printer
Print images bad
It might be due to the cartridge is not properly recognised by printer.
Or may be the printer is set on Fast Draft.
In either case Let me know if I can assist you further.
Regards
Ellin
Sep 25, 2008 | HP PSC 1210 All-In-One InkJet Printer
Hp psc 1315 paper jam
. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Jun 18, 2008 | HP PSC 1315 All-In-One InkJet Printer
Paper feed
The feed rollers are slipping on the surface of the label, causing the page to load incorrectly. There is no permanent solution at this time. Try one of the following workarounds to correct this issue. Workarounds Workaround 1 Adjust the top margin using Page Setup.
  1. Click File , then Page Setup in the program being used, (accessing Page Setup may vary from program to program. Refer to the Help file for that program).
  2. Adjust the top margin until printing is correct on the label.
Workaround 2 Manually print one sheet at a time. Place one sheet of labels in the input tray at a time, printing only that page. Repeat for all pages of labels needed.
Nov 20, 2007 | HP PSC 1210 All-In-One InkJet Printer
Paper Jam
Double check when u remove the paper it may still have some left
Need to know the exact error
Thanks
Jaywizz
Oct 04, 2007 | HP PSC 1210 All-In-One InkJet Printer
HP PSC 1210 All-In-One InkJet Printer Logo
78 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
