Question about Mitsubishi WS-55809 55" Rear Projection Television
Power Failure TV was working fine, it went out momentarily then came back on for about a second more of viewing time, then went OFF. Their was a slight crackle like pop noise prior to the final shut down. I have done the follwing: Checked Fuse, O.K. Uplugged overnight, still the same problem.
  • Mitsubishi Master
  • 8,617 Answers
You may want to go to the following link> They have the service manual for your set for 12.99 and they offer free unlimited support when you purchase a manual.They will also email it to you if you return to the site and request them to. Here's the link.
Posted on Jan 25, 2008
What is the reason for my E701i-A3 failure? All boards were replaced, worked for a minute, and then had the same "fade to black" failure as the first time.
Your back light controller board or the ballasts for them may be bad if they weren't incorporated into the power supply board.
Dec 05, 2016 | Televison & Video
TV turns on then off no picture
this is very common. it is the power supply going bad. it should run at 130 volts dc. but it is now running much lower that this. just enought for the tv to come on. but not enough to power all the circuits right.
Nov 20, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Kdl-55ex620 red light blinks 3 times
Unplug your TV from the AC power. Press and hold the power button on the TV itself for about 10 seconds and then release. After another minute, plug the TV back in and press power once.
If the blinking is still occurring then this unfortunately indicates a failure within the TV and will require a service. If all OK then happy viewing!
Dec 09, 2014 | Sony Video Game Consoles & Games
Toshiba sl738b
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
?Check the cables, connectors and connections.
Take it to a repair shop.
Apr 11, 2014 | Toshiba Televison & Video
Having problems with the sound on the 37z3030d model, it was working fine but now crackles all the time and cannot find the manual
Look for any loose contacts in RC jacks, cables and connectors. Also look for any fungus growth in connectors.
Aug 13, 2012 | Televison & Video
First of all, sorry for the mix up on model the model #. I was viewing a problem regarding LG LCD TVs and found your link. My problem is with an LG 42LGX LCD HDTV. It has worked fine without any issues...
welcome to fixya and thank you choosing my service..
OK,that is the most and common problem of all LCD TV...
Usually dim and totally have no back-light is cause of bad inverter board.One of the inverter board is shorted that cause dim light and crackling sounds..
This are the sample images of inverter board.
to make sure that the problem is on the inverter board kindly try to disconnect/unplug it from your TV and power ON then observe if the crackling sounds remain or not..If the crackling sounds gone replaced the inverter board..Also I need to how many inverter board you have? if 2 or more disconnect it one by one to determine if where is the specific faulty inverter board..
I disconnect #1 inverter still have crackling disconnect #2 inverter and reconnect the #1 inverter until you found the faulty one..Note when you doing this make it sure you power off the TV before you unplug or disconnect inverter board because its high voltage..
I need the picture your TV screen..just send it to
Jan 20, 2012 | LG 42LC2D 42 in. LCD HDTV
Mitsubishi WS-55809 55" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
