Question about Brother GX-6750 Typewriter
Cannot get daisy wheel to type correct letters
I dropped my GX-6750 Brother typewriter and cannot get daisy wheel to line up correctly. I have tried code and reset and looked for the switch on the inside right as you suggested but all to no avail. This is a brand new machine and my boss is gonna kill me! PLEASE HELP!
Thanks in advance,
Chris Beaty
  • 1 more comment
  • Anonymous Jan 30, 2008
    Type 4 and I get and lower case L
  • Jane S Feb 12, 2008
    Daisy Wheel does not type the correct letters and numbers typed. When I took it out the Daisy Wheel turns freely like it isn't attached or anything. It won't reset or anything.
  • Anonymous Apr 21, 2009
    the hammer is not working
    Problem Solver:
  • 8 Answers
Each time you turn on the typewriter it locked the daisy wheel to its home position. This is how the control mechanism remember each pin position of the daisy wheel. However if there is any problem with the mechanism it may unlock from its home position and therefore type the wrong key.
Before you try my suggestion make sure the daisy wheel is OK. It should move freely inside its casing and each striking pin should be straight and evenly position between pins. The best way is to try with another daisy wheel and if it is OK chances are that your typewriter is OK.
Try this:
After initial turn on check that the hammer head align correctly. You do this by manually pushing the hammer towards the striking pin of the daisy wheel against the platen roller. The hammer head should accurately align at the center of the striking pin. If it is no good take the following steps:
a) Loosing the two screws left side to the hammer head (just loosen do not unscrew completely.
b) Move the hammer head left or right to align correctly towards the striking pin.
c) Once you got that you need to screw back the two screws while maintaining the new positon.
d) It is important to maintain the distance between the hammer head and the striking pin while doing that.
Posted on Feb 20, 2008
    Champion:
  • 204 Answers
Turn oFF the typewriter, take the ribbon out.....use the lever on top to release and remove the print wheel cartridge. Lightly rotate it to see if it will move and reinsert the cartridge. snap it back into place.
Turn on the machine, the typewriter should move the carrier to the left and reset the printwheel....if it is snapped back properly.
Posted on Feb 05, 2008
6ya staff
SOURCE:
Typewriter spaces the letters wrong and types the wrong letters
how to install and set the daisy wheel correctly onto the typewriter
May 22, 2013 | Brother GX-6750 Typewriter
When I type words, it does not type the letters in the word. For example I typed in cindy and it will say Kr Ki not even anything like the word I am trying to type. Is there a way that I can check the...
Might have a problem in installing the daisy wheel or the ball. Or the daisy wheel/ball is not the right type for your typewriter. Check it. If it's correct, then it might have problems with the typewriter.
Apr 18, 2011 | Brother GX-6750 Typewriter
My typewriter (Brother GX-6750) does not print correct letters
look for bent or broken spokes on daisy wheel .turning unit off for 20 seconds and back on should reset the daisy wheel home position. probably the daisy wheel.
Oct 26, 2009 | Brother ML-100 Typewriter
Its not typing the correct letter. When you type. U can hit letter ''t'' and may type a ? mark.
if turning off for 20 seconds doesn't fix it look closely at the spokes and letters on the daisy wheel for bent or broken spokes or letters. replace daisy wheel if bent or broken about $35.00.
Sep 24, 2009 | Brother GX-6750 Typewriter
Changed Daisy Wheel and it's still not typing the correct letters
You can see the info on replaceing the daisy wheel here:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_GX6750_EN_214.PDF
If yo need more assistance- you can give us a call or send an email.
Take care and good luck
Duane ONeil
www.FJAproducts.com
800-982-9989
bc.cbi?cbdid=423141670777502444&wdid=1041068402873934082
Sep 15, 2009 | Brother GX-6750 Typewriter
HELP..BROTHER DAISY WHEEL TYPING RANDOM LETTERS AND SYMBOLS
Press the Code button and the Q/Reset button at the same time and the wheel will spin and go back to the correct place.
Feb 06, 2009 | Brother SX-4000 Typewriter
Gx-6750
Guarantee, Brothers have excellent Guarantee.
Jul 07, 2008 | Brother GX-6750 Typewriter
Daisy wheel
this is a piece of **** typewriter, and just throw it out.
Jun 12, 2008 | Brother GX-6750 Typewriter
Brother GX-6750 Daisy Wheel
Install wheel, turn machine on and off this resets the printer and home timing. If it still does not correctly, adjustments needed..
Apr 23, 2008 | Brother GX-6750 Typewriter
Brother GX-6750 Typewriter Logo
2,486 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Jim Keysor
