Question about Frigidaire ATF6000ES Front Load Washer
Front loader will not spin
Yesterday the washer Frigidaire (MOdel GLTF1670ASO) Gallery Series stopped spinning. The water will come into the tub but the tub will not spin on any wash or spin cycle. Belt is intact?
  • 4 more comments
  • desilu3131 Apr 26, 2008
    I have the same model. Mine wouldnt spin out a small rug a few weeks ago. It has been running fine though until yesterday. Washer was running then started making a loud banging noise. To me it sounded like a broken belt. I have no idea where my manuel is so I'm not sure how to open the washer to find out if it is indeed the belt. I see 4 screws at the top of the back of the washer. not sure if the top comes off? Thanks for any assistance. Lori
  • Anonymous Apr 29, 2008
    I purchased a frigidaire front loader last March. A few weeks after I purchased it I had problems with the clothes still being sopping wet. I was told I was using too much soap, (I used 1 capful of the HE type detergent, was told to use 1/2 cap. Seemed to work fine until it was exactly a yr. old. Again clothes came out sopping wet. Repairman came and said there was some coins in the drain hose and to be careful aabout emptying pockets. Now a month later its still doing the same thing. Another repair man came and said the circuit board is gone and will cost $350.00 for repair...it is now 1 month out of warranty. I am really disgusted and will never purchase a front loader again. I was complaing to my sister in law about the whole situation last evening, she lives out of state. She told me she had a whirlpool front loader that laster 3 yrs. lots of problems so she went back to the top loader. Whta is so upsetting is how I was talked into this expensive washer and now 1 yr. later its worthless. Beware!!
  • 4hillbill Apr 30, 2008
    I have the same problem and it just started on Sunday 27,08. Had this washer for 3 years too.Trying to trouble shoot this crazy thing and not having any luck!
  • eagleball1 May 05, 2008
    Have a frigidaire front loader # gltf2940esi washer will not spin at end of cycle counts down from 11,10,9,8,7 minutes remaining and turns off with a final beeeep. According to the person I finally talked to at electrolux , it's a timer relay (cost $5.62) . According to a local repair person it's a door lock (cost $62.00). Machine is just over two years old. I have two of them and the other one just started doing the same thing on friday.... Any Suggestions?
  • Ratchets May 06, 2008
    I have a front loader Frigidaire model gltf1670as0, water will fill the tub, agitates slowly or not at all, as it gets to final spin cyclke it just emptys the water from the tub wilol not spin. I took the back off, belt is fine, motor does not appear to run, no noise from motor. Had two broken shock struts,k replaced those, thought there might be a leveling problem and woulod not spin, did nt help
    Any ideas? Does anyone believe it is the motor
  • Anonymous Mar 16, 2014
    Gallery frigidaire top load vibrates on spin wash how do u fix problem
    Problem Solver:
  • 10 Answers
The problem is the door latch assembly. You can get it at your local parts supplier or oder it through repairclinic.com. Should cost $50-$55. My hubby is replacing mine now. Not an easy part to replace, but by all information I have gathered from the manufacturer and the parts department, this is a common problem and most likely the cause of the machine not spinning. It runs through all the rest of the cycles, but will not spin, even on spin only cycle. The good news... if you replace the door latch assembly once, the replacement part is much stronger than the original and shouldn't have to be replaced again.
Posted on Jan 02, 2009
We had the same problem with it not spinnig out... We paid big bucks last year for a repair man, only for it to do it again. My husband took the front panel off the washer, disconnected the hose that goes into the pump, cleaned all the change and strange things that it had collected out, and when he hooked it back up, it worked just fine....
Posted on Mar 05, 2011
The repair man called me to save me a trip charge.....my washer has a welded part broken in the drum....what he referred to as a "spider". I was told to fix my washer would run around $750.00. That's just a little less than what I paid for the set! My NEW set is being delivered today! No, it's not Frigidaire...lesson learned!
Posted on May 05, 2008
  • 4 Answers
Might be a burned (a few coils) motor - feel any burned paint smell?
Alternatively, a broken belt - you'd hear rthe motor spinning, though - or some sensor/wiring malfunction.
Posted on Jan 14, 2008
Hi
Could be a number of things. If you have checked all the connections to electric motor and found to be okay, The next thing i would check is the motor brushes. They may be worn down and need replacing.
Good luck.
Paul
Did you check for any belt broken? You may remove rear cover.
May 06, 2008 | Frigidaire ATF6000ES Front Load Washer
The machine is not draining and it is not spinning
Your machine will never spin if there is water in the tub. Remove the pump and clear the obstruction.
Jul 17, 2010 | Frigidaire GLTF2940ES Front Load Washer
I have a mo# FTF2140ES0 front loader washer that won't spin
check the pump for a blockage,if the water cantget out of the wash tub,the machine senses this and wont spin out the load,also make sure to check both sides of the pump from the tub to pump and pump to house drain sides
Mar 12, 2010 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire frontloading washer won't spin at all
Have a GLTF2940. Error code E20 and E30 came up. Will not drain and spin.
What to do?
Jul 27, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Drum makes loud noise when spinning
HI thanks for the question. Frigidaire has a life time warranty. on that part .call them. thanks the appliance doc. please rate my answer. thanks.
Apr 29, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire GLTF1670ASO is cycling fast and not spinning
Hi , try to check timer small motor .,also available in appliances store.
Feb 15, 2008 | Frigidaire GLTF1670A Front Load Washer
Front load Frigidaire Gallery washer
You are having a door switch problem change it out and you will have a new washing machine.
Dec 14, 2007 | Frigidaire GLTR1670A Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
1,040 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
