Question about Alpine Air XL-15 Air Purifier
Alpine XL 15 not working after cleaning
My XL 15 is not working after cleaning the filter, what should I check for? Thanks.
  • 1 more comment
  • acguajara Jan 29, 2008
    Thank you so very much for your help!! It works!!You are the best!! :)
  • Anonymous Mar 29, 2008
    I just cleaned my machine and it isnt working
  • Anonymous Jun 13, 2008
    I had the same problem and Stephen2's solution worked perfectly! Thank you!
  • 3 Answers
Bottom small plastic covered screw is a trigger for interlock switch, won't work if it doesn't push in the metal trigger.
Posted on Jan 20, 2008
Alpine Air XL-15 Air Purifier - never taken out of box - won't turn on whatsoever. Plate is accurately placed and the rear filter is properly fitted.
Is the fuse in properly? Try popping it out and put it back in, also check it when it is out..just to be redundant since you did it already. push on the bottom of the filter the switch pushes in . I at pushed down my first time.
Jul 06, 2012 | Alpine Air XL-15 Air Purifier
Alpine air filter X15 not coming on, what could be wrong
I would check the line fuse located near the power cord. The other thing would be the safety switch. Make sure the clip on the lint filter is making contact witht the safety switch.
Dec 07, 2010 | Alpine Air XL-15 Air Purifier
I just purchased a used Alpine Air XL-15 from ebay.no ozone spell
You probably have a burned out high voltage transformer. That's what produces the ozone. Helpful hint...........the high voltage transformer is also the one used in bug zappers
May 10, 2010 | Alpine Air XL-15 Air Purifier
My Alpine Air XL-15 Air Purifier youst to have a
The Classic XL-15 should have 2 individual indicator lights. The 'red' light is the ionizer indicator, and the 'green' light is the ozone level indicator. Both lights should be illuminated, if the unit is operating properly. The red light should be pulsing, and the green light should be dimly lit, and brightened as the output knob is turned up - indicating a higher ozone production. If the green light is not lit, you likely won't smell the ozone. The first thing you should try, is cleaning the filter and glass ozone plate. Unplug the unit and remove the rear air filter. Clean the filter with clean water and allow to COMPLETELY air dry. Removed the glass plate by depressing the lever behind the glass plate, and gently pulling it out. Clean the glass with a half water, half ammonia (or distilled white vinegar, if ammonia not available) and an old toothbrush to clean between the mesh. Dry plate with a hair dryer and re-place plate into unit. Replace dried air filter, making sure the little tab on the bottom is secured into the interlock. Power the unit on and you should see the indicator lights and smell the fresh ozone!
Nov 14, 2009 | Alpine Air XL-15 Air Purifier
Took the filter off to clean it and now it will not work. What is wrong?
Looking at it from the rear, there is a small switch on the right side. There is a plastic piece on the filter that has to push in on the switch to allow the unit to operate.
Oct 17, 2009 | Alpine Air XL-15 Air Purifier
How do I clean the inside of my Alpine Air? Not
If it's an XL-15 or Classic, there are four screws through the bottom that hold the main chassis in-place. But first:
1) Unplug the unit, and remove the lint filter in back.
2) You'll need to remove the power switch (carefully pry out with a screwdriver or putty knife), disconnect the spade terminals (note which wires attach to which terminals), and remove the knobs for Fan and Ozone controls.
3) Remove the four screws. As the chassis slides out the back, you'll need to disconnect the spade terminals to the fan motor as well.
Clean thoroughly, make sure everything is re-assembled with good connections in reverse-order. Be particularly careful to leave any sensors clean and connected.
If I can be of further assistance, or if you have questions about any of my response(s), please let me know before rating me.
If this solves the issue, please rate it accordingly. My goal is to earn a "FixYa" rating from everyone I help.
Thanks for using Fixya.com,
Jon
Sep 09, 2009 | Alpine Air XL-15 Air Purifier
I need Alpine Air XL-15 Air Purifier Repair service
Best bet is to call EcoQuest at 1-800-989-2299 and they can direct you to the closest repair center.
There is also a way to upgrade to a newer model the FreshAir 2.1 getting $100 back for your old XL-15.
To do this go to www.healthylivingia.com or call 1-800-798-6925 and ask for Eric.
Jan 13, 2009 | Alpine Air XL-15 Air Purifier
Does XL-15 air purifier work well in a lakefront home enviorment?
i dont know if it will kill mold. I had mine in the houston area--high humidity and it definetly cleaned the air. You could check with the manufacturer, their customer service is excellent.
Mar 21, 2008 | Alpine Air XL-15 Air Purifier
Alpine XL 15
Also make sure the safety interlock switch is properly closed when re-assembled. It's the springloaded switch inside the little notch in the chassis - the small tab on the lint screen should fit in and push that switch closed. If you do it wrong, the unit won't work. You should hear an audible click when the tab closes the switch.
Nov 17, 2007 | Alpine Air XL-15 Air Purifier
Alpine Air XL-15 Air Purifier Logo
235 people viewed this question
Top Alpine Air Air Purifiers Experts
Jerry Greenberg
Jerry Greenberg
Tom Chichester
Are you an Alpine Air Air Purifier Expert? Answer questions, earn points and help others
