Question about Dryers
Blowing cold air
This tumble dryer is only blowing cold air.I suspect heater element.Has this dryer got a reset button on and if so where would it be mounted?If it is the element is it accessed from the front or the back of the machine.Instructions on how to access the element would be most welcome as no info available.Thanks in advance.
Bill
  • willbee Jan 14, 2008
    your advice will be very useful when i actually gain access to the heater element.I'm quite adept at using a multimeter.I'm not familiar where the heater is located andwould appreciate your help with this.The appliance is an zanussi condensing tumbledryer model 482W.Hope this helps,if you need any more info please let me know.
    Bill
  • willbee Jan 15, 2008
    Hi jsrock516,
    I'm a complete novice with tumble dryers so could you describe in more detail what the lint screen looks like?.How big is this this lint screen?.I really appreciate your time and trouble helping me out.
    Bill
  • 5,911 Answers
There is not a reset button on an electric dryer that I know of. If a dryer is blowing air at all, that tells me that the blower assembly and drum motor are working. If you have not heat it is generally caused one of the following:
1. Bad thermal cut-out - located near the heating element housing. Should read a SHORT (0 ohms on an ohm meter) if good. If bad, it is generally a good idea to replace the TCO along with the Hi-Limit Thermostat (mounted right next the TCO in most cases) because the TCO is designed to protect the thermostat and heating element. If the TCO fails, it is likely that the thermostat could also be damaged.
2. Hi-Limit Thermostat failure - located near the heating element housing. The thermostat opens when the internal heat reaches about 157 degrees (on most dryers). This helps regulate the dryer temperature and helps protect the heating element. If it reads a constant OPEN (infinity reading on an ohm meter), replace it along with the TCO (as mentioned above).
3. Bad Heating Element - located under the drum on some dryer models and in the rear on others. The element should read about 9-11 ohms if good. If they go bad, the element will generally burns itself OPEN.
I will need you model number (located near the dryer door opening) in order to give you better advice on how to access the inside of the dryer. Post back with comments and let me know. I hope you find this helpful.
PS I hope I didn't insult your intelligence, but some people are little more saavy than others, so I try to explain things in the simplest of terms.
Posted on Jan 14, 2008
  • 1 more comment
  • Jeff Rockwell
    Jeff Rockwell Jan 14, 2008
    Does the dryer have a lint screen on the top of the dryer or is it located in the door? It sounds funny, but does matter in how the unit is configured. Please let me know...
  • Jeff Rockwell
    Jeff Rockwell Jan 15, 2008
    Okay...if the lint screen for the dryer is located on TOP of the dryer, the heating element is located in the REAR of the dryer and will require you to remove the back of the dryer to gain access.
    If the lint screen is located inside the DOOR of the dryer, the heating element will be located somewhere UNDER THE DRUM of the dryer. You will need to gain access to the inside of the dryer. Some models have a panel under the door that you can remove to get to the heating element. If the front of the casing is one piece, access will have to made by removing the console and finding the screws that hold the top of the machine in place. Once the top is removed, there will be a couple of screws that hold the front panel in place.
    Since I do not know exactly what your dryer looks like, I'm basing my advice on the experience I have had with MOST dryers. These are the configurations I'm familiar with, so I hope I'm giving you the proper advice you need. Please provide feedback as to whether or not, you need further assistance.
  • Jeff Rockwell
    Does your dryer come equipped with a means of collecting the lint from the clothes? You have to clean out between loads. It is just a screen that traps lint. Usually, a dryer will come equipped with a top mount screen that pulls out from a slot in the top of the dryer on dryers equipped with a top mounted lint screen. Or, there will be a pull out screen located inside the door opening on other models. It is usually mounted in the path of the blower fan prior to the exhaust. This filters the air before it gets to the blower unit to ensure lint from your clothing does not become clogged in the ducting or blower fan assembly.
6ya staff
SOURCE:
White knight tumble dryer cl847 not heating
-Possibly one of the heater element blow out.
-Timer switch assembly stuck in low position.
Good luck
Mai
Nov 21, 2013 | Dryers
Bosch nexxt 500 series dryer runs but stopped heating blows cold air and tumbles but just have no heat.
The heater element has failed,if electric dryer,. The element should be accessed at the rear panel.
If Gas heater...same but gas burner has failed to ignite.
Hope thes helps you
This help is free...Please find time to rate me.
Jun 28, 2011 | Dryers
My dryer still runs but does not heat up (just blows cold air), any idea how to fix? Will it be a thermostat or the heater element itself?
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Jan 04, 2011 | Whirlpool AWZ7303 Electric Dryer
My Bosch Exxcel tumble dryer will only blow cold air
the heater element is toasted,but it's not hard to change and not $$$
Mar 28, 2010 | Dryers
No heat from my tumble dryer
There should be 2 limits mounted above the heating element on back along with a limit mounted on the heating element. I have some repair video: HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 16, 2010 | Zanussi TC7102W Electric Dryer
Tumble dryer running but only blowing cold air
If your dryer is turning then things are not so bad. If a dryer is not heating then you need to check a few things.
First disconnect the power to the unit. Then you must check the heating element and the limits which are mounted on the heating box.
Remove one lead from the element and check for continuity thru the element. If you have continuity then check the limit by measuring for continuity, again you must remove one of the leads. This should solve your problem
Sep 15, 2009 | Dryers
Will not heat, it only blow cold air, how do I change the heating element inside the unit
If the drum turns, it could be as simple as a blown fuse or breaker. The dryer has doule breaker or fuses at fuse panel. If the one blows, the heater will not work but motor willturn as motor rums on 110volts. It may be cut out thermostat or could be element, but check the power to the plug of dryer out let and make sure you getting 110 volts on from neutral to both sides and 220 between two live lines.
Apr 27, 2009 | Dryers
Dryers Logo
433 people viewed this question
Top Dryers Experts
Marvin
Marvin
jimorris77
