Question about Texas Instruments TI-89 Calculator
Ti-89 titanium SIN!!!!!
When i type in sin(75)*16 my answer should be 15.45 but instead i get something else like 4 (square root of 3 + 1)*square root of 2. Im going crazy dont know whats wrong, it also does it for cosine and tangent!!!!!!!!!
The answer that you have received in actuality is correct. However, it is in exact form when the answer that you were looking for was an approximation (decimal form) answer. To achieve this all you have to do is hit the alpha button (the yellow button with a diamond in the center) and then enter which will give you your desired answer :-)
Posted on Jan 15, 2008
  • Texas Instru... Master
  • 8,016 Answers
Go to the Home screen. Press the MODE key. Scroll through the configuration options. Look for the line Exact/Approximate and change the setting to approximate. Also make sure you angle unit is set to degree.
Posted on Jan 31, 2013
Why wont my ti-89 integrate
It ts easy to find solution for this problem. Type int(sin(377x-1.231),x,0.299,3.94)
See captured image below
Oct 06, 2012 | Texas Instruments TI-89 Calculator
My TI-89 Titanium won't graph sin, cos, or tan?
Set your calculator to RAD mode and then graphing functions.
See example for y=sin x
Nov 10, 2010 | Texas Instruments TI-89 Calculator
My TI-89 won't solve for sin, cos, or tan. I can type in: sin(127) but instead of an answer it gives me sin(127) again. can someone please tell me how to fix this so that I can do my precalc homework?
Press diamond ENTER to convert the result to numeric form.
To have everything come out numeric, press MODE F2 then down-arrow down to Exact/Approx, then right-arrow and select APPROXIMATE. Press ENTER to set the choice, then ENTER again to save and exit.
Sep 21, 2010 | Texas Instruments TI-89 Calculator
Hi, I recently purchased a ti 89 calculator from a friend and I am having the following problem: The calculator will not evaluate trig functions. For example, if I type Sin(Pie/4) and hit enter, the...
The calculator is set up to produce exact results. If you want the expression to be evaluated put a decimal mark at the end of the 4.
to making 4 a floating point number instead of integer.
Alternatively, press the [MODE] key. Scroll down through the pages of options until you reach the line labeled Exact/Approx. When cursor is on that line, use the right arrow key to open the menu. Select [3:Approximate]. Press [ENTER] to save.
Aug 25, 2010 | Texas Instruments TI-89 Calculator
All trig-based graphs give me weird results on my TI-89 Titanium. Taking y=sin(x) for instance, I get a clean diagonal line through the point (0,0), almost resembling the graph y=x with window xmin = -10...
You have your angular mode set to degrees. Ten degrees is about 0.17 radians, and for small x: sin(x) is nearly equal to x. Thus, sin(x) from -10 to 10 is indeed nearly a straight diagonal line.
Press MODE, then scroll down to "Angle" to change the angular mode.
Jun 03, 2010 | Texas Instruments TI-89 Calculator
"Err: Domain"
I think you may find arcsin(x) is equivalent in older nomenclature to sin^-1 (x)...ie use the "2nd" and the SIN key instead of typing arcsin.
eg. arcsin(0.5) is 30 degrees is the same as sin^-1(0.5)
The ^-1 does not mean reciprocal, but "the angle whose sin is." Here the minus one indicates a kind of inverse operation. The word arcsin indicates that same inverse.
Mar 23, 2009 | Texas Instruments TI-89 Calculator
Need symbolic instead of numeric answer for integration
Clear all variables [F6] [ENTER]
Here is a screen capture of the display for your integral.
Hope it helps
Dec 27, 2008 | Texas Instruments TI-89 Calculator
Solve it plz......
cos x + root 3 sin x =root 2
cos x + ö3 * Sin x = ö2
squaring both the side
(cos x + ö3 * Sin x)2 = (ö2)2
Cos2 x + 3 * Sin2 x = 2
Cos2 x + Sin2 x + 2 * Sin2 x = 2
1 + 2 * Sin2 x= 2
2 * Sin2 x = 2-1
2 * Sin2 x = 1
Sin2 x = ½
Sin x = ö½
Sin x = 1/V2= Sin 45
X = 450
Aug 28, 2008 | Super Tutor Trigonometry (ESDTRIG) for PC
Cosh Squared or Cubed
if you want to square sin(3), press:
sin
Sep 24, 2007 | Texas Instruments TI-89 Calculator
Texas Instruments TI-89 Calculator Logo
1,221 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
