Question about Delphi Roady XT XM Radio Receiver
Signal is fine, but service goes away after ten minutes.
When I turn on car I have no problem with my signal and I am able to hear channels. However, after approximately ten minutes, I cannot hear channel even though signal is still showing to be at maximum. This has been going on for quite awhile. However, when I travel to the mountains it appears to clear up. Any suggestions?
  • JEFF SCHmidt Feb 07, 2008
    The screen displays the station information but no music just static while in use in the car using the fm modulation.  When using the cassette it works fine.  While I am using it in the home dock it frequently cuts out.  I often take the radio from its home dock to the car but this has not been a problem until recently especially in the home dock.  The weather here in milwaukee has been blizzard like conditions.  Could this interfere with the signal?  In the car i just use the cassette option at home i annoyingly need to take on and off the radio from it's dock with mixed result.
  • 28 Answers
Try using a different frequency for the fm modulator, let me know how this works, and maybe we can come up with a better solution!
Posted on Mar 16, 2008
2004 impala turn signal switch lights up dash
sometimes the dash light brightness adjust switch gets in a bad spot and will cause odd reactions, move the dash board dimmer control up and down a few times and see if problem goes away
Feb 06, 2014 | 2004 Chevrolet Impala
Intermittent turn signal problem 2005 malibu
Check that the fuse for the turn signal is not loose. Sometime a firm push inside is needed. If that doesn't work replace the fuse. If it is still loose then take a narrow pice of wire and insert it in with the fuse to keep if from being loose.
The problem could also be at your turn signal stalk. Turn of the turn signal and then move the turn signal stalk in different directions and hold it. You are trying to see where the intermittent problem goes away. If it doesn't , then the stalk is fine.
Aug 17, 2010 | 2005 Chevrolet Malibu
DBX586 signal goes away then returns then goes away etc.
A transistor junction in an IC is going bad. You will need an oscilloscope and schematic to find it. (or service tech)
Apr 11, 2009 | Audio Players & Recorders
Mitsubishi WS-55857 55 in issue
Hello Rodfamy:
You will need to look in the small signal board section of your service manual.
Aug 10, 2008 | Mitsubishi WS-55857 55" Rear Projection...
Humm coming from speakers - can't get cable to work
The RF input is the correct one for a cable signal. The other sources use the RCA and other ports which you can connect to other devices, like DVD or VCR players.
If the humm noise only happens when you're on the TV channel then it's likely just the station. Try changing the channel and see if that helps, and make sure the coax is screwed in all the way. Also make sure the other end, if connected to a VCR or other stuff, is tightly attached. If you share cable with many other people and the signal has snow (white spots on the TV), then you may need to buy an RF signal amplifier to reduce the noise.
Source changes the input (RCA versus coaxial versus component inputs), change the channel for different channels..
Jan 31, 2008 | Akai LCT2701AD Television
Keeps shutting off
It is not sensing an input signal. Try using another input source or seek service.
Nov 19, 2007 | LG 32LX3DC 32 in. LCD HDTV
Delphi Roady XT XM Radio Receiver Logo
74 people viewed this question
Top Delphi Audio Players & Recorders Experts
xxxxxx xxx
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
