Can't set up belkin wifi
When i connect the wifi and go to the http://192.168.2.1/ site the page pops up an icon saying not connected to the internet even though it was to begin with via speedial to the phone socket. This icon keeps popping up all the time and does not go away unless i taskmanager it away. Where am I going wrong - the firewall is switched off but i still have norton 360 on the laptop?
    Scholar:
  • 141 Answers
You can only access http://192.168.2.1 if your pc has an active connection with your belkin. You don't need internet connection to access that. You are only accessing the belkin configuration page. Check ip address of your pc, IT SHOULD BE 192.168.2.X. if you are not getting this ip your pc is not connected to the Belkin network
Posted on Mar 14, 2008
6ya staff
SOURCE:
My taskbar icon says I am connected to wifi but my computer is slow, wont load pages and pages arent responding.
can you plug in directly to your modem, do ookla speed test, maybe your internet server provider sucks [isp] or you're too far away from the router? my pc says I'm connected quite often & I'm not I sometimes go to troubleshoot in search bar & change adapter settings
Dec 15, 2017 | Icon Computers & Internet
Tip
Belkin F5D7234-4 v1 (important thing)
In Belkin f5d7234-4 v1(only version 1) router, do not disable "WiFi protected setup" learn more about wps
  • If you do so, then the router will no longer work in 90% of cases.
  • The WiFi protected setup is enabled by default in this model.
  • The computers using XP,vista,win7 may not connect to the wireless network. 96cff88.jpg
Solution:
In that case you can add the wireless network manually in the computer.Still if it says error message as "windows cannot connect",then follow these steps according to your operating system.
WINDOWS XP:
Start>
Control Panel>Network and Internet Connections(Network connections)>Right Click Wireless Network Connection icon>Click on Properties>authentication tab>uncheck IEEE authentication
WINDOWS VISTA:
Start>
Control Panel>Network and Internet (Network and Sharing Center)>On your left hand side click on Manage Network connections>Right Click on Wireless Network Connection icon>Click on Properties>authentication tab>uncheck IEEE authentication
WINDOWS 7:
Start >
Control Panel>Network and Internet (Network and Sharing Center)>On your left hand side Click on Change Adapter Settings>Right Click on Wireless Network Connection icon>Click on Properties>authentication tab>uncheck IEEE authentication
  • Now try to access wireless network.
  • If it still says windows cannot connect then no other go.
  • You need to disable WiFi protected setup.This will fix the issue for sure...
Click here to know how to disable wifi protected setup...
To learn more about WiFi protected setup, please click here...
on Apr 19, 2010 | Computers & Internet
How do i set up my daughters connection for er dsi? error codes 051099-1 comes up and the dsi says: no access point in range. check your ssid settings or move closer to an access point. what do i need to...
This probably means your not connected to any wifi.
You can check for a wifi access point by following these steps
  1. Go to your dsi settings (the wrench icon)
  2. Scroll over to the third page, and select "Internet."
  3. now choose "connection settings"
  4. click on one of the them that says "none"
  5. Click on "Search for an Access Point."
  6. a list of wifi access points should pop up
  • The wifi connection you are connecting to must have No Security or WEP
  • If the wifi connection is WPA you will not be able to go online for games
7. Choose one of those access points to connect to and if it is secured by WEP you must put in the password for that access point.
Good luck :)
Jul 21, 2011 | Nintendo Video Game Consoles & Games
How to connect my laptop wirelessly to the belkin router?
You may want to click to wireless network icon on the bottom part on the rght part of your monitor and search for network. Then you may want to chose your network and, if you chosed this option, to type the password for the network.
Let me know if you were successful in solving your problem
Mar 01, 2011 | Belkin Computers & Internet
I have a NetGear router set up as a primary router connected to the modem but it was giving me problems with WiFi. I bought Bellkin f7d4302 to use for reliable WiFi connection and also to connect my main...
I got your issue, I hope you are trying to connect the 2nd router to the first router through LAN-LAN connection (i.e, LAN port of the first router is connected to the LAN port of the 2nd router)
Then you need to change the ipaddress of the 2nd Play Wireless router . Please follow these steps.
1. Connect the computer-router with ethernet cable and open up internet explorer and clear the address box and type in 192.168.2.1 and hit enter.
2. You will be logged into the Belkin router setup page, in the Left hand side under LAN setup click on LAN settings
3. It will ask for Login password, leave it blank and click on submit
4. Change the LAN ipaddress from 192.168.2.1 to 192.168.5.1 and click ok
5. The page will say cannot be displayed, then clear the address box and type in http://192.168.5.1 and hit enter
6. If your first router is connected to the internet , then automatically the internet status will says connected
7. You will be able to go online wired
Good Luck!
Thanks in Advance!
Regards,
Prema
Dec 29, 2010 | Belkin Wireless Play Router (F7D4302)
I recently restored my Compaq Presario V2000 back to windows xp (it was vista before). Now, I cannot connect to the internet. The laptop picks up the signal and the icon on the bottom right says that...
A Belkin router doesn't usually force the utilities page on you. I would advise checking your start page - you might have set it to your router's homepage by accident.
Aug 19, 2010 | Belkin N1 Wireless-N Wireless Router
Changed internet companys and now my belkin g router dosent work how do I reconfigure?
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Click on WAn settings and set it as your internet service provider settings.Then click on wireless settings enable wifi turn radio on If you want secure wifi then enable WEP security enter WEP code it is your password to connect wifi.. Let me know if you need further assistance. Thanks for using FixYa.
Jul 25, 2010 | Belkin (F5D7231-4) Wireless Router
Ipod touch will not connect to belkin wireless router.
If your Ipod touch will not 'find' your Belkin N router - or it did and then vanished forever try this- it worked for me.
1.Turn wifi off on your computer, ensure you have the latest firmware on your router,reset the router to factory default.Do this using a wired connection from the admin page.
2. Change the SSID name from what it was previously say from Belkin xyz to my router.
3. Power down the router wait about 30 seconds then power it back up.
4. As you reset to factory setting you will need to put in your internet access info again - do this from the admin page. Also set up your security at the same time.
5. Restart the router from the admin page.
6. Unplug wired connection start wifi and connect to your computer -make sure that you have full internet access from you computer - dont forget you need to connect to the newly renamed router.
7. Take ipod and make sure wifi is off.
8. Clear network settings.
9.Turn wifi on and it should find your newly renaned router - join and enter your pass key.
Why it does it I have no idea neither do Belkin or Apple but it worked for me - a trial and error solution !
Good luck
Mel
Jan 25, 2010 | Belkin (F5D7230-4) Router (587009)
We called the tech number we just bought this product the instructions that came with it is horrible at telling you what you need to do and it comes with no other instructions on if something happens. We...
I can offer this page of information on DNS servers, but that's more than I know about them...However, this page, this page, and this site in general may help you get connected. Note the troubleshooting section.
This page will offer a wealth of helpful vista guidance and is a good starting point for checking your overall network.
You might also find better instructions for your router online at the Belkin support site here. FWIW.
Normally, you will set up the wireless access point using the existing desktop computer. Then the wizard will help you to add the laptop. You may also want to set up the new laptop first by connecting it to the ethernet cable and establishing the network connection. Then proceed to use the wireless network connection wizard to configure the wireless network connection, to get the laptop connected to the wireless AP.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Aug 29, 2009 | Belkin (F5D8231-4) Wireless Router...
Wireless connection
Access the routers admin page with the hardwired pc.  http://*gateway*  right click network status on pc and get gateway.  Google the model you have for the default passwords.  Setup your wifi security then do the same to your laptop and attempt to connect again.  Bad settings somewhere.
James Mac
Sep 09, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Open Questions:
Computers & Internet Logo
302 people viewed this question
Ekse
Marvin
Marvin
