Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
Sony Grand WEGA 50 or 60 inch, 6 blinking lights
I read on post before from circuitcity on here but can't find it again. He said the problem with the Sony Grand Wega with 6 blinking lights - after you've changed the bulb can be the thermal fuse. I need this part number and need to know where I can purchase it - and get the instruction manual. Please help.
  • Anonymous Mar 18, 2014
    I have a 50 inch sony grand wega the red light blinks 4 times I thought that meant it's over heating but my fan works. I don't know what else to try any suggestions?
  • Anonymous Mar 25, 2014
    bulb is out I need instructions on how to remove the back of the television and reassemble it
  • 4,402 Answers
6 blinks is a problem with the G1 board DD 6v output. G1 board Sony part # is A-1060-177-A , prices are $90-$116 exchange core from several suppliers.
Posted on Jan 14, 2008
  • 232 Answers
Hi, you can find that info & buy the parts here, good luck it`s not an easy job take pictures if you have a digital camera, BMW Rider
How do i fix my sony grand wega tv kf60xbr800 with 6 blinking lightshow do i fix my sony grand wega tv kf60xbr800 with 6 blinking lightshow do i fix my sony grand wega tv kf60xbr800 with 6 blinking...
Good day!!!
6 blinks its the clear indication that you have bad power supply board..
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Nov 20, 2011 | Sony Grand WEGA KF60XBR800 60" Rear...
55' sony grand wega will not turn on. The green light blinks 5 times and then red light blinks 6 times. red light cycles 6 times again. What is the problem? Can I fix it myself?
power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like, to buy a whole refurbish power supply board for the replacement.
Take care.....
Dec 07, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
Tv will not turn on red standby light blinks 6 times
tv will not turn on red standby light blinks 6, on a sony grand wega kdf-55xs955 55 in. rear projection hdtv television
Jun 19, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sony Wega Tv powers on w/ green power light and
need to know how many time the red light is blinking there should be a pause. 4 blinks is a fan, 3 blinks is the lamp door is not closed 6 blinks is thermal sensor.
Apr 22, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sony grand wega KDF55WF655 6 red blinks
you can try these steps if this doesn't work I suggest replacing IC8002 on the power supply
Low HV Shutdown:
On the D Board.
Check IC8004/pin 7 should be 7.4v.
Check IC8006/pin 2 should be 2.5v if lower will trigger shutdown by causing pin 1 to turn on.
Check IC8006/pin 3 reference voltage 2.2v.
IC8006/pin 1 normally at 0v. If high turns D5007 ON which turns the latch circuit Q6532,
Q6530, and Q6527 ON and turns the AC relay RY6501 OFF.
NOTE: 6 blinks also can be Low B+ protection.
Unregulated 7.5 v from the power supply to 5v reg IC504 on the A Board. 5v to M Board Q2314
to CPU IC2300/pin 43. If 5v missing set will shutdown with 6 blinks
Jan 24, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony wega rear projector
What color does it flash? Also it may be blinking a code so we need you to count the # of blinks it should blink a certain # of times, then pause, and blink that same # of times again. Let me know and I will be able to help you furthur.
Sep 11, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
WEGA KDF-55WF655 6 blinks
Hello malenoj,
To make another long story have a bad thermal fuse. This fuse can be found near or around the lamp housing. Part # 1-910-023-93 Average cost $10
Best regards
Jul 05, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Kdf55wf655 55 inch sony wega 6 blinking lred lights
For free sony support go the link choose the produce and chat for free
Thanks for using fixya. Hope this solution may have helped you.
May 30, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony Grand WEGA KDF-42WE655 42 in. Rear Projection HDTV Television buzzing
Hello mccueke,
This is what i know for a fact worked. This will not cost you more than 0.99 at the store.
Best regards
May 12, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony KF-WE50
Hello Failrlane.
You have a bad thermal fuse. You must remove the back cover in order to fix this unit. The thermal fuse can be found near the lamp housing. part number for kit: A-1137-954-A
Best regards
Jan 03, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
849 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
