SEAGATE 500GB USB 2.0 SLIM HARD DRIVE Where can I get the driver. I can't get mine to work. the detector light remains red, and my pc says it is not recognized. Thanks.
  • 1,601 Answers
How to connect
You need a USB cable to connect the seagate drive to the PC and you need to plug the seagate's power supply into the seagate drive and the wall....
Jun 17, 2012 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate 500GB FreeAgent GoFlex Hard Drive it didn't appear on my computer
Just because this starts with the same steps as other solutions does not mean it ends with the same fix.
1. Click Start
2. Right Click Computer: Select Manage.
3. The Computer Management Dialog box will appear.
4. Select the Disk Management Icon located in the right pane of the Computer Management Dialog box.
NOTE: Under volume you will NOT see the Seagate Drive.
5. underneath the volume pane you will see Disk 0, Disk1 and so forth. look for the Seagate drive ... mine was Disk 2.
6. Right Click on the Drive: Select Properties.
7. The "Seagate FreeAgent GoFlex USB Device Properties" will apear. Select the Driver tab.
8. Select the Uninstall Button.
9. Unplug your Seagate external hard drive and plug it back in. This should re-install the Drivers and it should work like it use to.
P.S. Sorry for the bad grammar\spelling.
May 09, 2012 | Seagate 500GB FreeAgent GoFlex Hard Drive
Seagate FreeAgent 500gb Hard Drive not showing up on computer
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
click start control panel administrive tools computer management disk management right click on your drive select properties
click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in one box then select
check now start or you might tick one box then return after its finished the first repair then return and tick the second box
(I have found better results ticking the first box then reurn and tick the second box) you should not do anything while the chkdsk utility is in progress any input may damage this drive
hope this helps you
Mar 25, 2012 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate 500GB FREEAGENT DESKTOP 7200RPM EXTERNAL USB 20 HARD DRIVE 16MB it just stoped working in the middle of the movie, complete blackout, tryed conect to another PC nothing came up, what it could be...
Try this:
1. Turn off the power supply to the hard drive.
2. Turn off your PC/laptop.
3. Connect the hard drive to the PC/laptop.
4. Turn on both devices.
It worked with mine.
You could also try installing Seagate Manager which can check for errors on the drive.
Jun 10, 2011 | Seagate 500GB FREEAGENT DESKTOP 7200RPM...
My Seagate FreeAgent Go 500 GB, stopped working in the middle of copying some of its data into my PC. Now instead of the constant light-up when connecting to the pc, it blinks continually. And the hard...
First i would remove and reinstall drivers for this device,next try device on another system if it works ok on another system drive ok if not drive has failed.Good luck!!!
Jan 08, 2011 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Drive manager is grey and says that no drive is attatched.
You need to get a Seagate Harddisk Utility software to check the disk intergrity.
Although hardware issues like can sometimes be very difficult to fix due to the impact on a volatile component on the harddisk which are most times not replaceable
Apr 06, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate Hard Drive issue
i want drive freeagent pro 500 gb firewere400,usb2.0, eSATA
May 13, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Windows 98 driver for FreeAgent
If your PC is still running Win98 then it probably has a USB version 1.0 port. I don't think the Faster USB version 2.0 devices will work properly even if you have the correct driver - i.e. you have a hardware version conflict. Try Purchasing a USB version 2.0 Daughter board for the PC and plugging the Seagate drive into that iinstead.
Jan 01, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Computers & Internet Logo
66 people viewed this question
David Payne
David Payne
