Question about Motorola Mobility RAZR V3
Motorola Razr locks up when texting
Enter 3-4 text charecters and phone locks up. Have to remove battery to reset. Have heard itap_user_dictionary is corrupt. Any thoughts as to how to fix this issue?
  • chuck37 Jan 14, 2008
    motorola razr ve cellular phone
  • Anonymous Jan 20, 2009
    I have the EXACT same problem.... Did this guys advice help you?
  • 43 Answers
Try re-flash you language flex. google for a language flex then download it . it sud b compatible to your V3. use RSD lite to reflash it don't forgot p2k driver to connect your phone -google again.
google is the ans for those key i gave you. if you having problem find those let me know so i can upload them for you
Posted on Jan 15, 2008
6ya staff
SOURCE:
Problem with RAZR V3i, take itap off
Hello there, the iTap feature is a the mobile phone dictionary feature which helps to spell the words which are located on your phone dictionary. This feature functions when you try to type a text message and it helps to spell the words by the use of a single tap on each key.
To exit iTap mode you simply press the middle button then select entry setup to bring up the menu for that screen selection and from there you can switch between iTap mode on or Off.
Also you can use the # button to switch between modes. To understand this better here is a link to the phone user guide Details on iTap can be found on page 40.
Hope this support has been helpful?
Thank you for visiting FixYa.
Sep 27, 2011 | Motorola Mobility RAZR V3
Cant change my messaging from dictionary to odinary text
To disable predictive texting on Motorola V360:
  1. Select the "Texting," "Text Messaging" or similar option on the menu screen.
  2. Choose the "Text Options" or "Options" selection on the "Text Messaging" screen. Choose "New Message" or "New Msg" if no "Options" selection is available, then press the button associated with the "Options" selection found on the blank message screen.
  3. Select "Entry Mode" on the screen. A list of options appear.
  4. Select a non-iTap mode, such as "Symbols" or "abc2." Press "OK." The iTap entry mode is disabled.
Jun 27, 2011 | Motorola Mobility V360 Cellular Phone
How to change from predictive text on my razr 3i
Press # in a text entry screen to select an
entry mode
1 Your Primary text entry mode can be set to any iTAP® mode or tap mode(indicated by 1).
2 Your Secondary text entry mode can be set to None, or set to an iTAP
mode or tapmode (indicated by 2).
123 Numeric mode enters numbers only.
@ Symbol mode enters symbols only
Jul 13, 2010 | Motorola Mobility RAZR V3i Cellular Phone
I have a motorola v545 and want to turn off the predictive text help!
Go to messages, new message, go to the menu(middle button) select entry options/method/settings, go to primary and select TAP English, go to Secondary and select None.
Text-Entry Methods:
iTAP - Lets you enter words using one key press per letter. The iTAP® method combines your key presses into common words and predicts each word as you enter it.
TAP - Lets you enter letters and numbers by pressing a key repeatedly to cycle through the letters and number on that particular key.
TAP Extended - Same as TAP, but cycles through additional special characters and symbols as you repeatedly press a key.
Text-Entry Modes:
Primary - You can set your Primary entry mode to any iTAP or TAP entry method.
Secondary – You can set your Secondary entry mode to any iTAP or Tap entry method, or you can set it to None if you do not want a Secondary entry mode.
Numeric - Enter numbers by pressing the number keys.
Symbol - Enter symbols by pressing a key; its symbols are displayed at the bottom of the screen. Scroll to the desired symbol and then press Select.
To set the text-entry mode or method:
  • From a text-entry screen, press Options.
  • Scroll to and select Entry Setup or Text Setup.
  • Select the desired text-entry mode or method.
Tip: From any text entry-screen, you can quickly change your text-entry mode without leaving that screen. Press the # key repeatedly to cycle through the text-entry modes: Primary, Secondary, Numeric, and Symbol. With each press of the # key, the mode indicator in the upper left of the text-entry screen changes.
Nov 15, 2009 | Motorola Mobility RAZR V3
How do I turn off predictive text on my motorola razor?
go to create a message, then press the - key, go into entry setup then change primary to TAP. this then enables the function you require.
Happy Texting
Jan 03, 2009 | Motorola Mobility RAZR V3
My phone freezes when trying to create a text message
try deleting some text messages, especially your outbox and unused files on your phone.
Feb 10, 2008 | Motorola Mobility RAZR V3
How do i remove predictive text
go to your messages... then choose message setting... look for default text input and just choose iTap (i think???) just play around with your message setting...
Feb 08, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Using predictive text
no you can't put it in the dectionary instead you have to change the settings "iTAP english" to "TAP english"
to change it while you are creating a message select options go to text setup then change the primary text to "TAP english"
peace!
Nov 25, 2007 | Motorola Mobility W375 Cellular Phone
Probs with text
Go to Settings->Other->Text Input->Personal Dictionary or Word Completion. If you have Personal Dictionary enabled, any predictive text words you've used in the past are still stored. With Word completion on, your Razr is auto-completing words from the Personal Dictionary. If you like to type the words in yourself, letter by letter, just turn these settings off. You can also want to reset your Personal Dictionary.
Jan 30, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
54 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
Lawrence Oravetz
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
