Question about GE Spacemaker JVM1640SJ Microwave Oven
Lights quit The other day my wife move something and the lights underneath the microwave quit working. The bulbs are still good. Is there a fuse that could have blown? The microwave still works as is the interior light.
  • GE Master
  • 9,098 Answers
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jan 20, 2008
Turntable, lights and fan inop
sounds like a cross wire, and a short. I'd inspect the socket for the bulbs to ensure that there's no short circuit.
Feb 11, 2008 | Magic Chef CMV1000B Microwave Oven
All three lights on my microwave ge model 1800 do not work. Is there a common fuse or something
suggest you go back to 10 amp globes and check that the fuse is good
Jan 01, 2015 | GE Microwave Ovens
My MH713OXE light underneath quit working
Check for 110Vac at the center pin of the light socket. If there could be the pin needs to be pulled up a bit so it makes contact with the bulb. If no voltage, most likely relay on board is bad. Be careful around these units they are very dangerous since they have 4000+ volts insde that can easily kill you!
Aug 19, 2014 | Whirlpool MH7140XF Microwave Oven
I went to change a light bulb, light bulb pulled out of threads. Tried to remove threads and without turning power off and shorted something out. Underneath lights and fan will not work. The microwave...
I would say you have blown a fuse on the unit. As you now have found out, that's one of the reasons why you unplug any electrical equipment before working on them. You will have to take the outer cover off the microwave and locate where the fuse is. It is most likely on the back of the main PCB or possibly inside a plastic sleeve or mounting near where the cord enters the unit.
Feb 22, 2014 | GE JVM1440 Microwave Oven
Goldstar MIcrowave stopped working when light bulb blew out.
when that happen to me i change the bulb and the fuse in of the microwave f the don't work send it to the company that made it and they should tell what wrong.
Mar 11, 2009 | Goldstar MV-1501 Microwave Oven
Cooking light inoperable, everything else working fine
just did further testing...I stated incorrectly before, appears to be one/both relays for this light
Nov 12, 2008 | Whirlpool MH1150XM Convection/Microwave...
Exploding microwave sounds - No Lights, No Fan, but Heats Okay
Mar 07, 2008 | Microwave Ovens
GE spacemaker xl 1400, lights on bottom won't work
To Person who answered Best Solution above,
This worked nicely thank you.
After removing my circuit board the long silver strip was intact, however where it makes the turn about quarter inch, the solder or foil seam had a break in it which I filled-gap with solder.
My guess is if the "foil" or thin 2" long strip is serving as a fuse, it would still melt again even with my solder on the shorter section, in event of overload. Also seen on the plastic area directly behind where the circuit board would mount, and where the "foil" was blown, was a small blackened area as evidence of the blown foil. 2 new bulbs and all is well again Thanks!
Jan 01, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Hood lights
This is a problem with the control board, which we commonly repair for $32.50. This is caused by not disconnecting the microwave from the power line when removing or installing a bulb.
May 30, 2006 | Sharp R-1481B Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
79 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
