Question about T-Mobile Wing™ Smartphone
My Wing won't reboot!
My T-Mobile Wing won't reboot after I installed new softwares. I just get the T-Mobil screen and then the green Windows Mobile! Thanks!
Loli
  • winginvenice Jan 14, 2008
    I did, numerous times. Then I turned off the phone, took the memory card out, rebooted w/o the card. It started up normal, and I put the card back in. However, if I do a soft reset with the card in, it won't reboot.
    Thanks!
  • 871 Answers
I suggest that you reset your phone as if this takes too long, it may even render your phone un usable.
Posted on Jan 14, 2008
Areo mobil password
Hello:
defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Jan 30, 2013 | Dell Aero Smartphone Cell Phone
Hello my mobil have a problem when i install themes it is not installing certificat error
The errors are caused because of the security measures introduced into the new version of Symbian Series 60 mobile operating system disallowing installation of old applications and invalid certificates, however bypassing this security feature and fixing these certificate errors to install themes and softwares is very easy, simply follow the instructions below:
  1. Open you mobile main Menu.
  2. Navigate to Settings -> General -> Date and time
  3. Now change the year back one year.
  5. Now install the application.
  6. Don't forget to change date back to original.
If the above does not solve the problem goto Application Manager > Options > Settings and set "Online Certificate check" = Off and Software Installation = All.
Mar 18, 2011 | Nokia E63 Cell Phone
The T-Mobile WING has to be rebooted to run another application
You might try searching forums.xda-developers.com
They have a Wing/Herald section and they have custom ROMs.
I am running Windows Mobile 6.1 using the OpenTouch v7.5 Pro. It's not great due to the lack of hardware that HTC built the phone with. My best solution for this problem is tough it out until the HTC Touch Pro II (will likely be called the T-Mobile Wing II) is released, which will have better hardware (but not by much); or get an iPhone. I will likely be switching when my T-Mobile contract expires in the fall.
Jul 06, 2009 | T-Mobile Wing™ Smartphone
Tmobile wing frozen
Turn off your mobile and then pull out the storage card, Restart your device, it should work now !!!
Jan 10, 2009 | T-Mobile Wing™ Smartphone
Won't stay on/ blank screen
2 things-
If the screen is blank white then the cable is probably loose: Follow this guide but just reseat the lcd cable
How to Fix T-mobile Dash LCD Screen
For the software issue:
The Windows Mobile installation may be corrupted.
The only way to fix that problem is by re-installing the windows software on the phone.
You can get the software for the T-mobile dash at the following link: http://www.t-mobile.com/wmupgrade/
Nov 12, 2008 | T-Mobile Dash Smartphone
Tmobile wing screen searching for SD card
ok first you need microsoft sync on your pc second you need to download the wing update from t mobile it will walk you through the process the bars you are seeing means it is in flashing mode this software will fix the problem any questions e mail me at blok420@yahoo.com
Oct 05, 2008 | T-Mobile Wing™ Smartphone
Dash stuck on opening TMobile screen
Be warned that if you use this method most of the data on the phone will be lost, like text messages and etc. Your contacts should be fine as the are stored on the SIM Card and if you have been syncing your contacts with your PC then they should get loaded when you do the up
Jul 04, 2008 | T-Mobile Dash Smartphone
I need a Driver For My t-mobile wing
If you have windows XP, download Active Sync 4.5 from the following link.
http://www.microsoft.com/windowsmobile/a...
install that, reboot and try connecting your phone again.
Jan 22, 2008 | T-Mobile Wing™ Smartphone
T-Mobile Wing LCD replacement
You may want to check with HTC website they make the wing.
Dec 29, 2007 | T-Mobile Wing™ Smartphone
T-Mobile Wing™ Smartphone Logo
Top T-Mobile Computers & Internet Experts
Computer Repairing
Computer Repairing
ismael castillo
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
