Question about Symbol LS1902T Handheld
Need instructions Symbol LS1902T Barcode Startup Instruction.
    Scholar:
  • 117 Answers
it depends on the configuration of your host and scanner. Usually there it works like this:
Connect the scanner to USB or per Keyboard Wedge Select the correct language set for your Scanner Try to scan your barcode if this will not work - enable the barcode you need to scan with the programming barcode from Manual
The Barcodes needed to set up the device are listed in the Reference Guide at http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=5093002apdf
Posted on Nov 18, 2010
6ya staff
SOURCE:
Symbol ls1902t-1000 scans extra characters when scanning a barcode
Download the quick start guide from support.symbol.com and reset to default by scanning the code from the PDF manual. This could either be a programmed ASCII prefix, or an error in the codes you are scanning. Have you seen the same problem with more than one scanner?
Oct 29, 2012 | Symbol LS1902T-1000 Handheld Laser Barcode...
I Have a new symbol scanner LS1902T-1000, whose software/Driver got missing, when i tried to read the bar codes, the unit beeps and a green light come on but I do not see any thing in the screen Please...
Hello Sabrina,
it depends much on the connection between the scanner and computer. The good sign is that the scanner is set correctly to scan the barcode. You need also scan the correct barcode for the connection art. Please scan from the Product Reference Guide the Barcode for USB, RS232 or Keyboard Wedge.
The Product Reference Guide is located at http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=5880807apdf
Oct 22, 2010 | Symbol Cobra LS1902 Handheld
Is there a driver for barcode scanner i am holding Model No - LS1902T-1000 company - symbol tech inc. hotsville n.y.
The barcode scanners are usually using ans Standard PS/2 or USB interface in the same way as keyboard, therefore you dont need an driver.
You would probably need to setup the barcode scanner according to the used connection/interface.
Here is the manual for yur scanner http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=5880806apdf&sliceId=&dialogID=189660311&stateId=1%200%20189654341
Jul 08, 2010 | Symbol LS2208 Handheld
Symbol handheld scanner problems
scanners are just plug and play.. be sure the scanner is programmed to read the type of bar code you are scanning.. Check the symbol to make sure it is not defaced. Try scanning test symbols of the same barcode type. and last tip, move the scanner closer to or further from the bar code.
Aug 11, 2008 | Symbol LS2208 Handheld
Programing
What kind of programming do you need to do? I've got most Symbol Manuals.
Jan 07, 2008 | Symbol Cobra LS1902 Handheld
Symbol LS1902T Handheld Logo
1,111 people viewed this question
Top Symbol Computers & Internet Experts
Ekse
Vish Iyer
Vish Iyer
Thomas F. Schneider
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
