Back to:
Tags:
Routers
Generic problem for all Routers
Dynes Wireless G Router (by 2 users)
posted by SAMichael on Jan 14, 2008
I keep running into the problem that states that there is no internet connection on my PC when I try running the internet thru the wireless router. When I run the internet directly thru my PC, it works fine.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by smh41, posted on Jun 24, 2008
I just loaded the Dynex wireless router on to my laptop but it doesn't work. I apply a security name . but it shows no wireless servie available.
Clarification Request
by russ1eftel, posted on Feb 03, 2008
hi,
how exactly have you set the network up.
it should look like this:
modem connects to the internet through the phoneline.
modems ethernet cord connecs to the internet port on your router.
another ethernet cord connects to one of the routers ethernet ports and connects to the computer
Solution #1
posted on Feb 04, 2008
Not Rated (0)
SirHanz
Rank:Guru Guru
Rating: 86%, 118 votes
Try turning everything off, PC, Router, and Modem. Then turn on the modem, then the router, then the pc. Your modem needn to connect, then the router will be assigned an ip address, then your pc will acquire an ip from the router.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Dynes Wireless G Router:
I don't want to Accept this solution
Can you Help with these Routers problems?
Linksys Wireless-G Broadband Router
When I connect Modem to Desptop directly Internet works......
Routers
have 1 laptop and wan to use wireless
Belkin (F5D5231-4) Router
I purchased a new laptop and am trying ot install the...
Routers
attempting to connect a printer to the wireless system....
Linksys Wireless-G WRT54GS Router (e125894)
We have several computers in our office that work off of...
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
