Question about Labtec Elite 820 - headphones
Clicking sound Hi there, One of the ear cups sounds like the magnet is not sticking anymore, and each time I move my head, there is a loud clicking sound, like something's moving around in there. I've looked high and low trying to find a way to pop off the ear bud to see if I can fix it myself, but without any luck. It doen't pop off or turn off, I've tried prying it off, no luck. Any ideas. If I tilt my head a certain way, the sound does improve, so I'm guessing something did come apart.
4 Suggested Answers
SOURCE: Sennheisser cx300 ear buds ..one channel has lost volume.
I have been having the same problem for the past week, I have just fixed it, reading your post gave me the idea to clean them and it actually worked
What i did was to "heat them up" with a hair dryer so that any wax from my ear that had gotten inside would "melt", then I cleaned them with alcohol and a q-tip and I made sure I let a bit of alcohol to get inside the ear bud, then I dryed it with the hair dryer again very carefully and tested to see the results and WHALA works just fine
Posted on Jul 15, 2009
damnor01
  • 1179 Answers
SOURCE: my right ear bud cuts
It shows that there is a loose connection.
Take the item back to place of purchase and get a replacement. It should be under warranty.
Take care!
damnor01
Posted on May 28, 2011
  • 23 Answers
SOURCE: There is a horrible echo whenever i try to record and then there's a loud noice that sounds like a very high-pitched whistle and i don't know what to do.
This type of audio feedback loop can happen on any mic if you are playing back audio at a loud volume on speakers that are close to the mic while the mic is on - which tends to happen on Skype calls. Try lowering your speaker volume or using headphones to hear the audio, then speak into mic, and the feedback should be reduced.
Posted on Apr 14, 2012
2001 Yamaha r1 cuts out sometimes then has trouble starting
Try ex,up valve in exhaust some times they stick shut, that would give it bad idle, and loss of power, just a thought, hope this helps.
Aug 28, 2016 | Yamaha Motorcycles
Machine does not make coffee and make a loud kicking sound
you have a problem with the gears of the mechanism that drives the brew unit. They are 2 in number and change easily if you can open the covers of the machine and remove it.
You can try to make the quantity of ground coffee a bit less . It can fix it for litlle period of time. But the gears must be changed.
Have a nice day
Oct 04, 2017 | Saeco Vienna Deluxe
BUSH 42" plasma no picture or sound?
You have a power supply problem, replace the Module.
What you ear is a click relay No juice to activate the relay
Some cups may be dried.
Nov 01, 2012 | Bush Furniture Bush My Space Rhea 42 in....
How much zoom would be sufficint 4 a super picture?
Sound travels through different kinds of matter. Sound travels through gases,
liquids and solids. 1. Hold a plastic bag of water against one of your ears. Cover
your other ear with your hand. Have someone hold a ticking
clock against the bag of water. Listen.
2. Keep the clock in the same place. Remove the bag of water. Listen.
3. Place a block of wood between your ear and the clock. Listen.
Do you hear the clock best through the air, the water or the wood?
B. 1. Place the clock 20 cm away from your ear and listen to the ticking.
2. Have your partner hold the clock at the 20-cm mark on the meter
stick. Place your ear at the end of the meter stick and listen.
3. Have your partner hold a metal rod to your ear and place the clock
against the rod 20 cm away from your ear. Listen. Does sound move
differently through some solids than it does through others?
C. 1. Take the plastic cups (telephone) and hold your cup to your ear
while your friend talks slowly and clearly into the other cup. Keep
the string tight. How does it work? What is vibrating? How do the
vibrations of your friend's voice reach your ear?
2. Can a third person talk and listen if another cup with a string is
attached? Take the separate cup with the string and attach it to
the first line. Keep all strings tight while one friend talks into
one cup and the other two friends listen. Can you hear the message
of the third party? How many lines could you attach? Does each
addition weaken the vibrations?
Jan 04, 2011 | Answer Racing Ion Motorcycle Jersey 2010
1989 vt1100c motor oil to reduce engine ticking
20W-50 is good for muffling sounds in the motor. Depending on the loudness the ticking could be caused by Exhaust gaskets (o-rings) from the head to the head pipe(ticking sound ((at idle))and popping or backfiring on deceleration). When automatic cam chain adjusters are going bad you get a clicking sound, or worse, hydraulic valve lifters (for zero tolerance) going bad. Lifters tend to be a loud clacking sound.
Jul 28, 2010 | 1989 Honda VT 1100 C Shadow
I hear a loud knocking on the passenger side of the engine. it doesn't start until I put it into gear. It sounds like my engines going to fall apart but it is by the belts.
One of your pulleys, tensioners, idlers, alternator, power steering pump, etc, is shot. Or the harmonic balancer. You will have to grab hold of each of these things and find out which one is loose. Or take a 3/4 dowel, 3 ft long, or broomstick, cup your hand around the end of the stick and around your ear at the same time, don't let the stick touch your ear, now put the other end carefully on an engine part that isn't moving, carefully, bolt, casting, bracket, pump, etc, you will hear what is the loudest. And the broken one. Even do the engine in a few spots, you can hear every valve. Hope this helps.
May 28, 2010 | 1994 Buick LeSabre
Noisy along the bearing of the aircon and transmission.We changed the bearing at the aircon but still has a loud noise.
This is dangerous, but it works, take a long screwdriver, or a piece of wood, broom handle, with the engine running, be real careful not to engage any moving parts, put the stick near a part of the car that is suspect, put your ear to the other end with your hand there to cup the sound into your ear, you will find the loudest spot real quick.
Feb 10, 2010 | 2003 Honda CR-V
Clicking sound from A/C
the clicking is caused by a part called a temperature control ac/heater blend door actuator motor, most likely the door it moves is sticking and the little gear drive inside the part is clicking.
Oct 03, 2009 | 1999 Mitsubishi Diamante
Loading clicking noise on spin
Could be excuse me ..Bra wire in drum stick your head in and look, if so best way to remove is take out heater to fix only if you are confident in repair..Good luck
Oct 02, 2009 | Washing Machines
Loud clicking
Open the cassette deck and use a pen to push down the heads. After this it probably works better to avoid using cassettes in this machine.
Feb 16, 2008 | Sony MHC-RXD3 CD Shelf System
Labtec Elite 820 - headphones Logo
Top Labtec Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Michael Galve
Michael Galve
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Labtec Audio Player and Recorder Expert? Answer questions, earn points and help others
