Question about GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker problem
I have a GE side by side model #SSS25KFMC WW and my issue is that when the water is dispensed into the tray it is also leaking water into the holding tray so everytime it makes ice the next time it pours the water some of it is coming into the holding tray causing the ice to become frozen into the tray. Is there something that I should be looking at specifically to locate the problem????????
  • jasper31 Jan 21, 2008
    same thing for me !
  • GEJeff Jan 26, 2008
    I have a PSSS25 and get ice build-up on the sensor arm and in the ice collection tray. It appears the unit is overfilling the ice maker and the extra water runs down and then freezes. I am usually quite good at fixing problems, but do not know where to start on this one.
    Sergeant:
    Champion:
  • 262 Answers
Try turning down your water inlet pressure go about half way and play with it from there also check the tube going to the icemaker to put water in the maker make sure it is all the way into the ice maker
Posted on Feb 03, 2008
I have a GE Refigerator (PSF26MGWA WW). the ice maker will not fill up with water. The tray heats up and the sweeper works. The fill solenoid for the ice maker does not work properly.The drinking water...
the ice maker is in control of the valve, however, the valve is one assembly containing the valve for the water dispenser and the one for the ice maker, take your model to the appliance parts store and get you a water valve assembly for your model number.
Dec 23, 2017 | GE Refrigerators
I have a GE Refrigerator GSS22JFMD WW with a ice
The water supply in the recessed part of your door is frozen. very common with this model. You will need to turn unit off and with freezer door open use hairdryer on the area where water dispenses and on the recessed area as well. This is time consuming but only other remedy is to leave off and door open for 24 hours. hope this helps.
Feb 12, 2010 | GE Refrigerators
GE Fridge - model gss25tgma ww - will not dispense water. Ice
solution part # wr49x10173. door heater. comes with instruction. install in 15 min. good luck.
Jan 19, 2010 | GE GSS25TGMCC / GSS25TGMWW Side by Side...
Rust ruining door at lower corners of ice/water dispenser.
when you dispense ice or water, you are allowing the drip tray to overfill and the water builds underneath the tray until the water reaches the point were it will leak down the front of the door. the water will rust the panel beyond repair. you will have to replace the whole door at this point. hope this helps.
Oct 20, 2009 | GE GSS22JEM Side by Side Refrigerator
GE profile side-by-side water dispenser works, no ice though
Ice maker bad or the ice maker water valve mounted on the same bracket as the dispenser is bad. These frigs are prone to bad ice makers after a few years.
Sep 29, 2009 | GE Profile PSW26P Stainless Steel Side by...
My ice maker will not work, Ge profile Arctica.
Here you go...my dad had the same issues...Good Luck!
http://www.youtube.com/watch?v=sW2yqQjEcLI&list=HL1329704348&feature=mh_lolz
Jun 23, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Ice maker is leaking into the tray where the ice is dispensed causing the ice to become embedded into the tray
there is a screw in the ice maker unit that can adjust the water level open the ice maker whit cover and you should see it but turn it gently little by little each time...and see how much you getting :) very EZ good luck
Jun 06, 2008 | GE PDS22SIS Bottom Freezer Refrigerator
The ice maker usually is an easily removable assembly, lift and pull or something like that. It may be the little water line has cracked, plastic don't like being cold.
Jan 14, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Water leaking out of freezer door water dispenser
The fill valve that supplies the water may not be shutting off completely. Also check to see that the lever is closing completely.
Apr 04, 2007 | GE GSS20IEP Side by Side Refrigerator
GE refrigerator
this may be water from the defrost cycle. if this drains to tray over compressor, check tray is not too full (water evaporates from heat of compressor) otherwise defrost water will go to a seperate container which may have a split or is overflowing. fault can also be caused by poor door seals which would produce too much ice on evaporator pipes
Mar 21, 2007 | GE GSS25JEMWW Side by Side
GE (PSS26MSRSS) Side by Side Refrigerator Logo
214 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
