Question about Bosch Classixx WFC 2465 Front Load Washer
Only hot water pipe going in
It seems there is only a hot water inlet and no cold water pipe on our machine, which means the water going in is the temperature of the boiler. This means it is too hot most of the time and is rinsing wit hot water. We have tried turning the temperature down at the boiler which is okay but a bit of a pain. Does anyone else have this same problem. I've done a couple of jumpers already and all my other clothes have shrunk a size or two.
  • 30 Answers
Hi if there is one water valve it will be a cold water one not the hot one
Posted on Mar 07, 2008
  • 4 Answers
Don't know that particular make, but if there's only one water inlet available the machine should use its own electric heater. A "Wash Temp" setting switch should be available.
Posted on Jan 14, 2008
6ya staff
SOURCE:
Hot water in no cold water inlet screens ok
I don't know what you mean by (screens ok) an acute bend in the cold water pipe or you need to replace the water dual inlet valve eric
Jan 17, 2018 | Washing Machines
Is the indecit wm12x washng amchne a hot or cold water fill?
Hi from retired Englishman in SW France @ 13:45 Tues afternoon.
You can easily check by looking at the back where the water pipe or pipes need to be connected. If there is only one inlet then it is a cold fill and the machine will heat the water up itself.
If there are two inlets the hot is normally marked RED and the cold BLUE.
When the hot water is not hot enough for the particular wash, the machine will heat it in the same way as it would heat just cold water. If, however, the hot water is too hot, it will mix in some cold!
Cheers,
John C
Feb 08, 2011 | Miele Washing Machines
I have a model WFE1070BD*CD,(5 months old) does this machine use cold water ? Both hot and cold taps were connected at installation but on delicate wash clothes are still very hot .
Check the hose connections on the back.My guess is the lines are crossed. Double check: Is the cold water supply piped to the cold inlet on the washer and the hot water piped to hot inlet? They may be reversed either on the hoses or in the wall.
To check the in-wall piping, feel the the hose bibb marked cold...well, is it? cold I mean. If it is hot, the pipes are crossed in the wall. If it's cold, check that the hose is running to the inlet marked C or cold, or is blue. If it isn't your inlets are crossed. Either way, switch the hoses and you should be good.
Dec 09, 2010 | Whirlpool Washing Machines
When iput washing on it seems that the hotwater isnt hot the pipes are on ive checked
Some washing machines allow hot water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally. If you're sure the machine isn't working the way it used to--or should--try these tests: Is the hot water turned on? If not, turn it on.Is the washer getting cold water but no hot water? If so, check to see if the control panel settings are correct.Is there hot water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, completely replace the Valve.
Nov 30, 2010 | Hotpoint Aquarius WD640 Front Load...
Hi I have a hotpoint wd72 which is showing an error ' E10 CHECK WATER SUPPLY' when going into rinse mode. I've checked the cold water supply pipe from source to the washer and thats fine, it seems that...
First check the screens in the end of the hose and inside the water inlet valve. If clear you need to remove the top and check to see if you have power to the water inlet valve, there will be a solenoid for hot and one for cold. Check for power on the cold solenoid when washer is put into a fill cycle. If you have power replace the water inlet valve. The whole valve must be replaced. They are inexpensive and easy to replace. Here is a link that should help http://appliancehelponline.com/washerwaterinlet.html
Sep 16, 2010 | Hotpoint Ultima WD72 Front Load...
Why is my warm water is cold? The hot is hot and cold is cold but warm is cold.
There is too much pressure on the cold feed, reduce the pressure on the cold by partly closing off the tap on the cold.
Or ensure the hot feed is fully open and not blocked, check if there are filters inline - remove the feed pipes at the washer end and look into the inlet valves - clear if blocked.
The inlet valve is common to hot and cold water with only a small pipe to fill the machine, the cold water is being forced back up the hot water pipe due to the pressure you can feel the pipe cool down after running hot then go to warm, if hot water is flowing the pipe will stay hot, if not then cold is going up the hot pipe.
Jun 28, 2009 | Admiral AW22 Top Load Washer
Orientation of inlet pipes
I am not to sure if this answers your question but I think you are asking which way the hot and cold hoses connect to the wasing machine? if this is the case if you look on the back of the washing machine you will see stamped in the metel a H for hot connect the hot water inlet hose to this, If it is not marked, hook up the hot water hose to the washing machine and place the water temp selector to hot and turn machine on if hot water comes out you have the correct hose hooked up,if not then the cold water hose goes were you hooked up the hot water hose. hope this helps
Jun 24, 2009 | Washing Machines
Washing maching won't rinse in cold water
hi is this hot and cold water piped machine? ie two connections on rear of machine for hot and cold pipes ? if so are your pipes connected properly on machine and the water supplies? if cold supply is connected to hot supply then wash inlet allows water in washer then washes in cold? but when rinse is due? the elec valve that has hot water pipe connected?? is failing to open allowing water flow of hot on rinse so advise recheck pipes for flow of water from both? when disconnected from machine if flow ok then possible valve blocked/faulty hope you can understand above? if you can give more info on your machine it would help to offer a remedy?
Nov 01, 2008 | Hotpoint Washing Machines
I have just disconnected the inlet pipes on my Zanussi FJ1296 Washing machine but forgot to look which way round the go for putting them back - I can see no indication on the machine as to which inlet is...
inner one is hot and outer one is cold.
to check after fitting hoses, put on rinse program and only cold water should come in. if hot water comes in then you have the hoses wrong way round.
Aug 27, 2008 | Zanussi Washing Machines
Gushing water - Hoover SPB11 washing machine
First plug off the wall. Before connecting the "hoses" (both hot and cold) to the machine inlets see that the inlet is clean. Connect the outlet hose to the standpipe, not too deep. The outlet hose has to be about 3 feet above ground level; there is a water level mark behind the machine. Both the inlets should be well screwed in, noting the threads of the inlets
You said the water was gushing.....into the machine? Fine .....what next.......post back.
Dec 06, 2007 | Washing Machines
Bosch Classixx WFC 2465 Front Load Washer Logo
59 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
jimorris77
Dw Wooten
Dw Wooten
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
