Question about Microsoft Xbox 360 Console
Disc xbox unable to read disc cleaned with a dry cloth but not effective. also making whirring noises when loading disc
    President:
  • 4,402 Answers
I just solved this problem, very simple actually. Possibly can happen when the drive WILL close, but then loud noise as it tries to spin the disc up. Open the drive up (4 little screws on the bottom) and lift the lid up. If you look on the top white magnet spinner, the bottom side of the magnet system broke off of the disc motor. It will look like a little metal ring stuck to the white spinner thing whatever it's called. I popped that off and examined it, then used some krazy glue to stick it back on the motor spindle and it's away and going now. The reason the drive will not close, is because when the little magnet first breaks off it can get misaligned then when it tries to shut it gets in the way. The MAY be the cause to the problem. I fixed this issue today with mine, hitachi drive.
Posted on Jan 14, 2008
My xbox 360 game, skate 3, stops working after I get to the part were you skate then a text pops up and quotes unable to read disk clean with a soft cloth and I have dun that and it still dusent work how...
Try misting the disc with tap water, then dab it off with the cloth and let it dry. Repeat this a few times, it fixes the problem most of the time. Alternatively, you can buy specialist disc cleaners that can do this a lot better.
Jun 02, 2012 | EA Sports Video Game Consoles & Games
Tip
XBOX 360 WILL NOT READ DISC SAYS OPEN TRAY
eject the game from the cd console if in the drive make sure your xbox is on warm it up take the disc if it is dirty run under warm water all over the silver side of the disc till dirt and debris gets completely removed after still holding the disc turn off the water and use scott SCOTT brand toilet paper the straight kind and use about four sheets to dry the disc or use a blow dryer, not preffered prefreably scot toilet paper after the disc is dry and warm very dry take your clean index finger and remove the rest of the debris off the disc and when the xbox says open tray let it say close tray close it see if it says read the disc if it says read the disc then it is not your laser or the laser needs to be blowed off with an air gun or compressed air. Get it to say close tray and itll close it self, wait ten seconds turn off the xbox turn it back on and go to my xbox mash play wait for it to read the disc. THE DISC WILL NOT WORK IF IT IS DIRTY I reccomend running it under warm water (let dry on both sides while still holding it properly) use a non scratch cloth to clean the disc preferablly scott toilet paper the smooth kind, after it is dry put the disc in the console if youve tried the disc try a brand new disc it might definately work after it says read if it says play the game then its the disc. If nothing happens like it dont say reading disc then your laser is cracked corrupted, or it has debris on it or is wett. Dont let your laser head get wet because i told you to run it under water make sure the disc is dry and completly free of scratches and smudges. WASH THE DISC WITHOUT SCRATCHING IT. Dont put a wet disc in your x box. Mash the hard drive button down and release mash reset to recycle the xbox green lights. Remove all the cords fromt the xbox wait two weeks or shorter, I waited a month or more before i played my game and it worked after I cleaned it twice one time and a month later i cleaned it without soap and used luke warm water.Remember Open tray, press buttom close tray closing automatically should say read reading reading disc then play if does not read the disc then its your laser. If its your laser and you are sure its your laser do not remove the hardrive or any screws they can tell youve botherd it because that will void your warranty. go to www.xbox.com/support its a pdf file print shipping label follow the steps to repair.
on Jun 13, 2010 | Video Game Consoles & Games
My NBA 2K11 game disc has a scratch going around the disc like a ring. I was playing and tilted it on its side to check something on the side. It stopped responding and told me the disc could not be...
try to clean the disc with a clean cotton cloth or you can use a cleaning fluid for the disc then dry with a cotton cloth or a damp cloth then put it on the XBOX 360 if that does not work the disc is really damaged or check the disc if its a light scratch or permanent scratch mark
Feb 07, 2011 | Microsoft Xbox 360 Console
My xbox 360 makes 2 tick like noises and then says open tray with any disc I put in please help
Inspect and clean your disc Take a close look at the bottom side of your game, movie, or music disc (the side without a label or image). Are there scratches? Excessive scratches or smudges can prevent your console from reading the disc. Clean your disc Hold the disc by the edges without touching the top or bottom surfaces. Using a soft, clean, slightly damp cloth, lightly wipe from the center of the disc outward.
· Note Use ONLY water to clean the disc.
· Once the disc is clean, load the disc into your console and see if the disc plays.
Or Click here to download repair guide
Jan 04, 2011 | Microsoft Xbox 360 Console
The xbox is on with the green light and everything seems to be working, until you put a disk into the tray and it says reading then open tray, it makes no noise as though it is not spinning
Click here to download repair guide...if u need
Dec 28, 2010 | Microsoft Xbox 360 Console
Unable to read disk
check the disc for any scratch,try cleaning it using a soft cloth,if still the same issue,try other game disc ,check if it will happen with other game disc,if not, the modern warfare disc is the issue,but if the error persist with all the game disc,the problem is your console you need to call xbox your repair
Jun 30, 2010 | Microsoft Xbox 360 Pro System Console
WHEN I GOT A NEW GAME IT WAS WORKING BUT A COUPLE OF DAYS LATER IT SAID THE DISC COULD NOT BE READ AND IT TOLD ME TO CLEAN IT WITH A SOFT CLOTH AND RESTART THE CONSOLE AND I DID IT AND IT SAID THE SAME...
Check to see if there are any scratches or laser burn marks on the discs. If there no scratches evident on the disc, try a laser lens cleaner, these are normally quite cheap.
Scratches or marks on discs will render game discs unplayable or will freeze the game and will often show a message stating "Disc Read Error" or something to that effect. Best remedy for starters, is to clean the discs and make sure there are no scratches or marks left on the play-side of the discs. A common problem that XBOX owners are reporting is; if the console is moved during play, a whirring noise is heard and then when the disc is removed, very visible laser burn rings are found on the disc.
Laser burn, looks like complete or partial circular scratches around your disc. This occurs to discs when the games console has been moved whilst playing. Discs are then impaired by a ring of laser burn, which is a circular scratch into the disc. Some home remedies may help with very light scratches on some discs but a professional disc repair service is normally required to fix laser burn scratches or damage to XBOX discs.
For further help on XBOX disc repairs or to get XBOX discs repaired back to "As Good As New Condition", visit:
www.discREPAIR.ie
Check the "More Info" & "FAQ" Sections for further details on disc repairs and related matters.
If this laser burn scenario is consistently happening to your game discs especially if the console has not been moved or bumped against while the disc is in play, the games console itself may require repair. You should contact Microsoft for assessment and guidelines.
Hope this Helps!!
May 20, 2010 | Microsoft Xbox Console
My xbox keeps scratching all discs and wont play them.also tray is loose .when disc is in the screen says reading then makes a noise then says open tray
Check to see if there are any scratches or laser burn marks on the discs. Scratches or marks on discs will render game discs unplayable or will freeze the game and will often show a message stating “Disc Read Error” or something to that effect. Best remedy for starters, is to clean the discs and make sure there are no scratches or marks left on the play-side of the discs. A common problem that Xbox owners are reporting is if the console is moved during play, a whirring noise is heard and then when the disc is removed, very visible laser burn rings are found on the disc.
Laser burn, looks like complete or partial circular scratches around your disc, also known as “the ring of death”. This occurs to discs when the games console has been moved whilst playing, from an upright to a horizontal position or vice versa or simply knocked against or the wires may have been just tripped upon. Discs are then impaired by a ring of laser burn, which is a circular scratch into the disc. Some home remedies may help with very light scratches on some discs but professional disc repair services is normally required to restore disc laser burn damage back to "As Good As New Condition".
For further help on Xbox & Xbox 360 disc repairs, visit:
www.discREPAIR.ie
Check the “More Info” & “FAQ” Sections for further details on disc repairs and related matters.
If this laser burn scenario is consistently happening to your game discs especially if the console has not been moved or bumped against while the discs is in play, the games console itself may require repair.
Hope this Helps!!
Apr 02, 2010 | Microsoft Xbox 360 Console
Xbox wont read brand new beyonetta disc
Possibly a bad disc? Check the back. Clean it with a soft damp cloth and then dry it with a soft cloth. If it doesn't work still, then return it.
Jan 28, 2010 | Microsoft Xbox 360 Console
How to repair nba 2k9 for xbox 360
When I have problems with scratched DVD's or games, I use the scratch remover cream that goes on your disc, Leave it on for a few minutes to dry, then wipe it off with a very smooth cloth... Its about $7 or $8 I think.... Good Luck, Like I said this usually works fine for fixing scratched discs
Oct 18, 2009 | 2K Games NBA 2K9 for Xbox 360
Microsoft Xbox 360 Console Logo
60 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
