Dell 922 All-In-One InkJet Printer Logo
Posted on Nov 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can get my dell922 to print - Dell 922 All-In-One InkJet Printer
Anonymous
Level 2:
Scholar:
New Friend:
  • Expert 81 Answers
  • Posted on Aug 03, 2010
Anonymous
Expert
Level 2:
Scholar:
New Friend:
Answers
81
Questions
0
Helped
12980
Points
154
You will have to uninstall the software provided by dell , use revo uninstaller for this purpose , you can download it free from google
once unisatlled the revo uninstaller will give you options to delete the registry values, delete all the registry values , restart the computer , and reinstall the software and try to print document .
hope this should resolve your issue .
Why does some txt print when using ctrl shift print to print a document or email and some lines do not print at all?
There are two way email e-print.
A> Open email and select print area and see preview, if preview ok then you given print. If not ok then go to printer setting option and set printer paper or text. Then see print preview if ok then given print.
B> Second option is copy email print job any doc file or then print select and command given. But print before also check it print preview.
If any issue create i share a print related problems link please visit and read it. I hope solved your issues.
Source..ePrint Job Did Not Print
Thanks,
HP Phone Number
2answers
The printed output may be printed incorrectly. Clicking [Resolve Error], and then try to print again.
1helpful
2answers
My hardward wizard cannot locate softward for my dell 922 All in one printer
(Dell 922 driver--->http://ftp.us.dell.com/printer/922ENA04.exe)
Instructions
A.Download
1.Click Download Now, to download the file.
2.When the File Download window appears, click Save (Windows XP
users will click Save) this program to disk and click OK. The Save In:
window appears.
3.From the Save In: field, click the down arrow then click to
select Desktop and click Save. The file will download to your desktop.
4.If the Download Complete window appears, click Close. The file
icon appears on your desktop.
B.Install
1.Double-click the new icon on the desktop labeled 922ENA04.exe.
2.The Self-Extracting window appears and prompts you to extract or
unzip to C:\DELL922. Write down this path so the executable (I.e.
Setup.exe) file can be found later.
3.The Self-Extractor window appears.
4.Click OK.
5.After completing the file extraction, if the Self-Extractor
window is still open, close it.
6.Click the Start button and then click Run.
7.Type C:\DELL922 in the Open textbox and then click OK.
8.Follow the on-screen installation instructions.
1helpful
MY LEXMARK 4505 LEAVES 3-4 BLACK BLOTCHES ON THE EDGE OF EACH PAPER IT PRINTS, TRIED CLEANING THE ROLLERS TO NO AVAIL, ANY SUGESTIONS
ADJUST THE COLOR AND PRINT SPEED You may need to adjust the color and print speed. CHECK THE LEVEL OF INK IN THE PRINT CARTRIDGES 1 From the Finder desktop, double-click the Lexmark X5400 Series folder. 2 Double-click the Lexmark X5400 Series Utility icon. 3 From the Maintenance tab, check the ink levels of the cartridges. If an exclamation point (!) appears on a cartridge, the ink level is low. Install a new cartridge. Improving print quality These are possible solutions. Try one or more of the following: CHECK PAPER • Use the appropriate paper for the document. If you are printing photos or other high-quality images, for best results use Lexmark Photo Paper or Lexmark PerfectFinish Photo Paper. Do not use Lexmark Premium Photo Paper. Your print cartridges are not compatible with this type of paper. • Use a paper that is a heavier weight or bright white. CHECK PRINT CARTRIDGES If the document still does not have the print quality you want, follow these steps: 1 Align the print cartridges. For more information, see "Aligning print cartridges" on page. If print quality has not improved, continue to step 2. 2 Clean the print cartridge nozzles. For more information, see "Cleaning the print cartridge nozzles" . If print quality has not improved, continue to step 3. 3 Remove and reinsert the print cartridges. For more information, see "Removing a used print cartridge" on and "Installing print cartridges" . If print quality has not improved, continue to step 4. 4 Wipe the print nozzles and contacts. For more information, see "Wiping the print cartridge nozzles and contacts". If print quality is still not satisfactory, replace the print cartridges. For more information, see "Ordering print cartridges". CHECK PRINT CARTRIDGES If the document still does not have the print quality you want, follow these steps: 1 Align the print cartridges. For more information, see "Aligning print cartridges" on page 124. If print quality has not improved, continue to step 2. 2 Clean the print cartridge nozzles. For more information, see "Cleaning the print cartridge nozzles" . If print quality has not improved, continue to step 3. 3 Remove and reinsert the print cartridges. For more information, see "Removing a used print cartridge" and "Installing print cartridges" If print quality has not improved, continue to step 4. 4 Wipe the print nozzles and contacts. For more information, see "Wiping the print cartridge nozzles and contacts"
3helpful
2answers
Do pixma Mp610 support duplex printing
The MP610 does support duplex printing.
Duplex Printing
The duplex printing function allows you to print data on both sides of a sheet of paper.
The procedure for performing duplex printing is as follows:
Performing automatic duplex printing
You can perform the duplex printing without having to turn over the paper.
1. Open the printer driver setup window, check the Duplex Printing check box, and confirm that Automatic is checked.
2. Select Normal-size Printing (or Fit-to-Page Printing, Scaled Printing or Page Layout Printing) from the Page Layout list.
3. When printing a document that has small margins, click Print Area Setup... and set the print area.
When you perform duplex printing, the print area of the document becomes slightly narrower than usual and the document may not fit on one page.
sub.gifTo print without reducing the page:
Select Use normal-size printing.
sub.gifTo reduce the page slightly during printing:
Select Use reduced printing.
4. Specify Staple Side.
The printer analyzes the Orientation and Page Layout settings, and automatically selects the best staple position. Check the Staple Side setting. If you want to change the setting, select another value from the list.
5. If necessary, click Specify Margin... and set the Margin width.
6. Click OK.
Duplex printing will be started.
Performing duplex printing manually
You can perform the duplex printing manually.
1. Check the Duplex Printing check box and uncheck the Automatic check box on the Page Setup tab.
3. Specify Staple Side.
4. If necessary, click Specify Margin... and set the Margin width.
5. Click OK.
sub.gifIf a media type other than Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed on one side of a sheet of paper. When printing is complete, reload paper according to the displayed message and then click OK. The document will be printed on the opposite side.
sub.gifIf Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed front and back alternately for one sheet at a time. Load the paper according to the displayed messages.
caution.gif Note sub.gifDuplex Printing is unavailable when:
- A media type other than Plain Paper, Photo Paper Plus Double Sided or Hagaki is selected from the Media Type list.
- Poster Printing is selected from the Page Layout list.
sub.gifWhen Booklet Printing is selected from the Page Layout list, Duplex Printing and Staple Side appear grayed out and are unavailable.
sub.gifAfter printing the front page, there is an ink drying wait time before starting to print the back page (Operation stops temporarily). Do not touch the paper during the time. You can change the Ink Drying Wait Time at Custom Settings on the Maintenance tab of the printer driver.
sub.gifWhen you perform the automatic duplex printing for Hagaki, print an address first and then print your message.
refer.gif Tip sub.gifIf you select Photo Paper Plus Double Sided for Media Type on the Main tab, the Duplex Printing check box on the Page Setup tab is not checked automatically. To perform duplex printing, check the Duplex Printing check box.
sub.gifIf the Media Type dialog box appears when performing borderless printing during duplex printing, select Plain Paper or Photo Paper Plus Double Sided.
sub.gifWhen performing the automatic duplex printing, do not use any plain paper smaller than A5. Also, do not select any type of paper other than Plain Paper, Photo Paper Plus Double Sided or Hagaki at Media Type.
sub.gifPhoto Paper Plus Double Sided is highly recommended for printing photographs on both sides of a page.
sub.gifIf the back side of the paper becomes smudged during duplex printing, perform Bottom Plate Cleaning in the Maintenance tab.
1helpful
What is the usual maintenance and wear & tear for a Canon Color Imagerunner C3220 copier?
Durables for IRC3220
[1] Waste toner container - 60,000 prints*
[2] Secondary transfer outside
roller (120/230-V)-300,000 prints* actual number of
prints
[3] Transfer cleaning unit 100,000 prints*
[4] Fixing roller 100,000 prints* actual number of
prints
[5] Pressure roller - 100,000 prints* actual number of
prints
[6] Transfer belt - 300,000 prints* actual number of
prints
[7] Drive roller 300,000 prints* actual number of
prints
[8] Primary toner roller -300,000 prints*
[9] Secondary transfer inside
prints
[10] Feed roller (each cassette
holder)
250,000 prints* actual number of
prints
Pls help in this VB code, Sato CX400 barcode printer
jst try this u create a label from label printing software using ato font then make a prn
then attach u r vb code in to prn it will work
rohitjain
prn example-------------
A
Z
A
CB+18
Z
A
CD250,3300
Z
A
AR
Z
A
A100950647
Z
A
%2h416v0072BG01031>H23456111
%2PSP02h573v0021L0101XS922
%2PSP02h618v0021L0101XS18K
%2PSP02h415v0089L0101XS17125
%2PSP02h416v0039L0101XSPO124
%2PSP02h416v0022L0101XS215gms
%2PSP02h618v0043L0101XSDR37/0.20
%2PSP02h618v0064L0101XSDR37/0.20
%2PSP02h618v0085L0101XSDT/B44/0.82
Z
vb code example------------------
Open "LPT1" For Output As 1
Do While rs.EOF = False
For I = 1 To Val(Text1.Text)
Print #1, "A"
Print #1, "*&"
Print #1, "Z"
Print #1, "A"
Print #1, "CB+18"
Print #1, "Z"
Print #1, "A"
Print #1, "CD250,3300"
Print #1, "Z"
Print #1, "A"
Print #1, "AR"
Print #1, "Z"
Print #1, "A"
Print #1, "A100950647"
Print #1, "Z"
Print #1, "A"
X = "%2h380v0065BG01031>H"
Y = rs.Fields(6).Value
X = X + Y
Print #1, X
Print #1, "%2PSP02h618v0085L0101XSKT"
Print #1, "%2PSP02h600v0085L0101XS", rs.Fields(1).Value
Print #1, "%2PSP02h618v0064L0101XSNetWt"
Print #1, "%2PSP02h600v0063L0101XS", rs.Fields(2).Value
Print #1, "%2PSP02h618v0043L0101XSDiaWt"
Print #1, "%2PSP02h600v0041L0101XS", rs.Fields(3).Value
Print #1, "%2PSP02h618v0021L0101XSColWt"
Print #1, "%2PSP02h602v0021L0101XS", IIf(IsNull(rs.Fields(4).Value), " ", rs.Fields(4).Value)
Print #1, "%2PSP02h430v0084L0101XS", rs.Fields(5).Value
Print #1, "%2PSP02h371v0028L0101XS$"
Print #1, "%2PSP02h405v0028L0101XS", rs.Fields(7).Value
Print #1, "&"
Print #1, "Z"
Print #1, " A"
Print #1, " #E5"
Print #1, " Z"
Print #1, " A"
Print #1, " CS2"
Print #1, " Z"
Print #1, "A"
Print #1, " 0000"
Print #1, "TEXT1.TEXT"
Print #1, "/"
Print #1, "Z"
2answers
Top Dell Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Ngoro
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
