Question about Kenmore 21.7 cu. ft. Top Freezer Refrigerator with Acceler-Ice 3xi Ice System
Ice maker not making ice.
I have a Kenmore Acceler Ice. There is a red light flashing inside the freezer. The ice maker stopped making ice a few days ago. I checked the tube that supplies the water for the ice maker to make sure there is no ice trapped inside but there wasn't. Do you have any suggestions for me? Thank you, Melissa
  • 3 more comments
  • Anonymous Feb 04, 2008
    This has just happened to me for the 2nd time. I replaced the unit myself (working from instructions over the phone from my out-of-state brother who is a repairman) and it's worked great for about 8 this going to be an on-going problem???
  • Lono33 Mar 11, 2008
    exact same problem, red light blinks and the ice maker no longer makes ice. The water works fine on the fridge side, so I don't think that is the issue. the model # is 106.56534400
    thanks in advance for any advice. please drop me a line if you could as well.
    lono33 @
    Kevin L
    Parker, CO
  • Anonymous Nov 13, 2008
    What is the red light blinking? Is there a reset button?
  • mloura Feb 03, 2009
    My ice maker stopped too! Red light is flashing, ice looks like it's ready to come out but nothing happens. Checked to see if cubes were blocking the gears but it looks ok.
  • Anonymous Mar 30, 2014
    there is a red flashing light in the freezer
  • 447 Answers
These Icemakers have plastic gears on the modules that are breaking, also some have thermostats that are malfunctioning. I recommend haveing an experianced tech look at the unit to see if you need the new upgraded indoor ice maker.
Posted on Jan 15, 2008
Ice maker kitchenaid super ba is not working . Chilled water dispenses but no water seems to enter ice maker.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
Both refrigerator and freezer not cooling properly in refrigerator?
The ice maker not working: ---
Compressor not running on refrigerator?
Water dispenser not working on refrigerator?
Ice maker stopped making ice?
Water Overflows in Ice maker and freezes inside?
How to replace Ice maker assembly?
These will help.
Dec 22, 2012 | KitchenAid Superba KSRG25FK Side by Side...
57029 Side by Side Refrigerator: ice maker not making ice and red light inside the ...
Your ice maker may be turned off. The blinking light is the sensor. The switch is right beside it. Is it in the on position?
May 16, 2010 | Kenmore 57029 Side by Side Refrigerator
Ice maker stopped working, red light is flashing, however water is working? What is the problem, how do I fix?
For the red light try removing or replacing your filter.
The ice maker usually has a make ice bar about it inside the freezer. The down position is usually on.
Dec 02, 2009 | Kenmore 23.1 cu. ft. Side-By-Side Counter...
Six hours to make eight cubes???
when you first hook up an icemaker it sometimes takes a couple of days for it get up to speed. there may not be a problem give it some time.
Sep 30, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
Ice maker hasn't worked in years. A couple of days ago food below the ice maker was thawed. Today I felt that the ice maker was hot to the touch. Is there anyway to disengage the power to the ice make
Yes you will need to take the screws that mount the Ice maker to the side of the freezer and unplug the cable plug that is hidden behind the back of ice maker. The only time that element is needed to become hot is the moments before the ice maker drops ice. Thanks, Sea Breeze
May 15, 2009 | Kenmore Refrigerators
Automatic Ice Maker making grinding noise and will not release ice
The mold heater on the bottom of the ice maker is shot, that is why the cubes will not release. The grinding is the sweep arm trying to push the frozen cubes out.
May 06, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
Freezer stopped working
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary
Mar 22, 2009 | Kenmore 57029 Side by Side Refrigerator
The fridge was working but the freezer had stopped working...
you migh have a buildup of ice in the freezer compartment previnting the fan from delivering cold air to your items. you will have to disconnect the fridge for two or three days to let all ice to melt have bucket and mops ready
Mar 17, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
No ice making
First i would check the water valve in the back. One side is for water.. the other side is for the ice maker... If you have a ohms meter check selonid for continuity look for blisters of plastic on sides showing in would be bad... You can also make a test cord to energise the valve by passing the icemaker to tell if valve is good. ALSO This would put water into you ice maker telling you.. you have a clear path for water to icemaker You only need to plug in for few seconds .. to keep from over filling icemaker if vavle good and water comes thu
Aug 20, 2007 | Kenmore 21.7 cu. ft. Top Freezer...
Check the cam wheel beneath the front cover of the icemaker it is probably not turning.
May 31, 2007 | Kenmore 21.7 cu. ft. Top Freezer...
Kenmore 21.7 cu. ft. Top Freezer Refrigerator with Acceler-Ice 3xi Ice System Logo
900 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
