Question about Canon (6981A002AA) for imagerunner 2200, 2800, 3300 Print Server
CAnnon Imagerunner 2800 Error code: E000002 0000
This little 2 minute fix cost me $160 the last time I had to call for service - Can I get a fix code from you?
  • 1 more comment
  • toti1971 Feb 24, 2008
    how can i solve problem CAnnon Imagerunner 2800 Error codeE000002 0000 problem?
  • Anonymous Jun 27, 2008
    J'ai eu le meme probleme mais for heureusement;j'applique cette formule pour la premiere foi c'était bien mais pour la deuxieme fois c'est devenu difficile le copieur ne réaagit pas que dois faire? Donne moi la solution
    pour la preemiere fois la solution était bonne mais pour la deuxieme fois le copieur ne repond pas, donne la solution
  • Canon Expert
  • 287 Answers
Hi Ofcgdss. This would normally require a tech, but I can help you reset the code. However, the code indicates a sub system within the copier that is critical and if the the problem still exists the copier will almost immediately display the the code and if that indeed occurs you WILL need service. Here we go.I am going to tell you a procedure that only service techs use, there is no harm in giving a one time shot as the copier will reset, attempt to recover and if the problem remains the code will return and prevent harm. Press the the " additional functions" button, then the numbers 2 and 8 simaltaneously,and then the additional functions button. This should be done in a smooth but timely 3 step sequence. This will bring up a new screen that will have several "blocks" and one of those will say "COPIER". Press the copier block. Now you will have a screen that has several " tabs" at the top and other crap in the main screen. At the top tabs you will see a block that says "function" Press function and you will get a new menu below. One of the blocks will say "CLEAR". Press clear and a new screen will appear. At this new screen you will see a block that says "ERR". Press it and then in the bottom right corner you will see a block that says "OK". Press the ok button and the copier will know that it needs to reset the code and attempt to recover from this "critical" error code.Unplug the machine, wait 10 seconds or so, and then plug it in again. The copier will assume everthing is ok and attempt to resume normal operation. Again, if the problem remains the copier will determine this rather quickly (< than 5 mins) and will return to the error condition. But without being even more long winded than I already have been, you have a decent shot at getting back to normal. I KNOW this will reset the code, I just hope it was a temporary glitch. Good luck and let me know if I can help further. ............sincerely.......SPINAL
Posted on Jan 16, 2008
J'ai un problème avec mon copier ir 2200 qui affiche error E0000002 0000
pouvez vous m'aider à resoudre ce problème?
merci
Posted on Oct 26, 2009
Pour la premiere fois c'etait bien mais pour la deuxieme foi le copieur ne repond pas
Posted on Jun 27, 2008
Oh man...you're a lifesaver spinal...thanks I had the same error and this solved the problem. Thanks.
Posted on May 19, 2008
  • 1 more comment
  • mtituh a
    mtituh a Nov 19, 2013
    hi, if i press *28* comes , can u assist the meaning of these numbers
  • mtituh a
    the menu on screen is
  • mtituh a
    when i press the arrows numbers change
Canon error code 801
E602-0003 try to recover you program turn OFF the machine when turn ON just hold 19 when the small box show just wait in few minutes until the screen tuning full white.... if the code is the same just contact SC near by you to reprogram machine
Mar 06, 2012 | Canon (6981A002AA) for imagerunner 2200,...
SIR MY XEROX MACHINE IS PROBLEM ERROR CODE : E000002-0000
MACHINE MODEL : CANNON IMAGERUNNER 2200
Jan 18, 2011 | Canon (6981A002AA) for imagerunner 2200,...
Sir my canon 3300 error e00000-0000 pls help me
what you need to do is just resetting your machine.
1. Press * 28 * on your machine in a quick move.
2. Select copier
3. Select Err.
4. Select Clear then press O.K
5. Turn your machine off for 1 minute and turn it on again.
The error code will not be there anatmoreand your machine will be functioning well.
plz do rate solution if helped
Nov 16, 2010 | Canon (6981A002AA) for imagerunner 2200,...
E000007-0000 error in diplay
The Canon imageRUNNER 3300 System error e007 code means that the fusing film is out of Home Position or the film is ripped. You will need to most likely have the fixing film replaced. You are probably going to have to get a service to repair it.
fixya.com/support/t6195187-cannon_ir2018_system_error_e007
November 7, 2002 Product : IR 2200 / 2800 / 3300 Title : E007 code for the IR 2200 / 2800 / 3300 Problem :
E007 code is occurring for the IR 2200 / 2800 / 3300
Solution :
In Service mode / Copier / Function / Part Check, energize M4 (the Fixing Drive motor). If the Fixing Drive motor does not come on, replace M4 (part number FH6-1848-000). Canon USA, Inc. Systems & Technical Support Division
you access service mode by pressing ADDITIONAL FUNCTIONS-2-8-ADDITIONAL FUNCTIONS...
Nov 02, 2010 | Office Equipment & Supplies
I need a hard disk drive for a cannon 2200 imagerunner the copier keeps showing a error message
If you have a Service Contract with the local CANON office, call them, and get them to make a service-call to fix your printer.
Jul 17, 2010 | Canon (6981A002AA) for imagerunner 2200,...
Cannon Imagerunner 2200 Error COde: E000051-0000
There is information in the Service Manual to fix this problem. Make a service call and get a technician to fix this problem.
E051 is Horizontal registration HP detection error
0000 At start-up, home position is not detected when the horizontal registration assembly is moved 100 mm in the direction of home position.
Main cause: The horizontal home position sensor is faulty. The horizontal registration
motor is faulty. The DC controller PCB is faulty.
This problem should be handled by a technician.
Jul 03, 2009 | Canon (6981A002AA) for imagerunner 2200,...
Code error of Cannon IR3300 E000006-0000
getfile.asp?rid=1258 November 7, 2002 getfile.asp?rid=3215 Product : IR 2200 / 2800 / 3300 Title : E007 code for the IR 2200 / 2800 / 3300 Problem :
Solution :
Apr 29, 2009 | Office Equipment & Supplies
Error Code
Jan 27, 2009 | Canon (6981A002AA) for imagerunner 2200,...
Wats the meaning E00602-0003
Call the serves and must support you
or cheak un cannon site what the error
Dec 15, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Error code E00003-0000
The film (plastic) film is probably torn from a piece of paper that got jammed between the upper and lower section causing an overtemp lockout condition.
1. Remove left paper door.
2. Remove conector rear plastic(black) and fuser shields(2) screws holding fuser cover shield and unplug (3)connectors,2on the rear and a small one on the front lower right of fuser unit
3. Remove (2) assemlbly mounting screws one at rear and one
on the front sides.
4. remove unit and purchase new complete unit from cannon
5.Installed new fuser by reversing above steps.
May 28, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Computers & Internet Logo
5,267 people viewed this question
Top Canon Computers & Internet Experts
Aashish Chaudhary
Aashish Chaudhary
Computer Links
old marine
old marine
Are you a Canon Computer and Internet Expert? Answer questions, earn points and help others
