Question about HP OfficeJet 6210 All-In-One InkJet Printer
Hp 7100 series scanner problem
My printer works sometimes, my scanner and fax will not work anymore.
I need to use the scanner today. In the window, it states that the scanner will not connect to the pc.
  • MBR77 Feb 04, 2008
    I have an HP 6610 Scanner, Printer, Copier, and Fax in one. I can't scan anything, it says I cannot connect to PC. However my printer works. What can I do to resolve this?
    Thanks
    My email is Female1977NYC@aol.com
  • Ashwin Kadadi May 11, 2010
    Could you please let me know the operating system that you are using on the computer, also whether the full featured HP All-In-One software is installed on the computer?
  • 4 Answers
In most cases this can be resolved by uninstalling the hp software, disconnecting the printer from the computer, still powered up, and reinstalling the correct software for your operating system and not connecting the printer to the computer until the software requests you to. All necessary drivers and software can be downloaded from HP Support.
Posted on Mar 02, 2008
Cant get the scanner to work. Do I need a CD to reboot it?
Troubleshoot scanning problems - Windows - Microsoft
windows.microsoft.com/.../troubleshoot-scanning-pr...
Microsoft WindowsI added my scanner to the computer but I can't select it when I use Windows Fax and Scan ... I tried putting more than one picture on the scanner at one time and scanningeach of them to a separate file, but it doesn't work. ... Get the word out.
Scanner won't work on my Hp printer and I can't find a way t ...
h30434.www3.hp.com > ... > Scanning / Faxing
Scanner won't work on my Hp printer and I can't find a way to view my ink level. Options. Mark as ... If you get stuck I will help you through it. If this does resolve ...
my scanner won't work - HP Support Forum - 867
Jan 18, 2016 | Office Equipment & Supplies
How do i scan a picture on my printer
You may refer to the Lexmark X7170 User's Guide on how to use the scan feature. If you're using Windows, you can view the user's guide by going to the Start -> Programs -> Lexmark 7100 Series -> Lexmark Productivity Suite. Or click to download the Lexmark 7100 Series User's Guide.
Feb 17, 2011 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
HP Solution Center does not recognize the scanner anymore... We are operating on a Windows 7 system... the drivers had to be downloaded from the internet because the cd that came with the printer was for...
I had the same problem and solved it. I was using HP Solution Centre to run my HP Scanjet 5590 on Windows 7 Pro 64 bit without problems. Then I ran the scanner using Windows Fax and Scan, but didn't like it, so went back to HP Solution Centre - whereupon the scanner was not recognised.
After hours of reinstalling software etc etc, without success, I suddenly noticed four device icons on the left hand side of HP Solution Centre. These were labelled (when hovered over with the mouse) hp scanjet 5590, hp scanjet 5590 #2, hp scanjet 5590 #3, hp scanjet 5590 #4. Only the top icon was active, but when I clicked on any of the four it moved to the top.
Clicking on hp scanjet 5590 #2 gave me a working installation once more - problem solved. No doubt the multiple icons arose from my desperate attempts to try different USB ports.
Feb 02, 2010 | HP Officejet 6500 Wireless All-in-One...
C6180 FAX UNABLE TO SEND OR RECEIVE
check the the phone line, The fax sinal need good clear. Surely,plug the phone-line is rigth line socket. If you do that all, the broblem is still happenning,need to change "relay" on moderm fax board.
Jul 27, 2009 | HP Photosmart C6180 All-In-One InkJet...
My problem is with the HP PSC 950 series printer, fax, scanner, copier. The fax and copier work sporatically, sometimes producing a copy or fax and most times not. Please help
faxing,scanning and copying use the same mechanism,thts the scanner,if its doing it intermittently you can try a reset on the printer.see if tht works.
Jun 24, 2009 | HP PSC 950 All-In-One InkJet Printer
Hp4300 series disc won't work with my new hp window vista computer my printer is a 4315v
Please perform the steps given below and check if yuo are able to fax
1. Open a MS Word Document.
2. Click File -> Send to -> Recipient using a fax modem.
3. Follow the instructions given in the fax wizard. Ensure that you select the HP all-in-one as the fax program.
Now check whether you are able to send the fax.
OR
Try setting up the Fax once again
=== Fax Setup wizard ===
- Double-click on the HP Solution Center to open it.
- Go to Settings --> Fax Settings & Setup --> Fax Setup Wizard.
Complete the fax setup wizard and then, try to fax
Vishwanath V U
May 19, 2009 | HP Officejet 4315v All-In-One InkJet...
Lexmark 7100 series will receive faxes but wont send them
I have a problem sending/receiving faxes. I have been trying to send a fax but it will not go through.
Mar 19, 2009 | Lexmark X6170 All-In-One InkJet Printer
HP officejet 4100 series all-in-one Scanner not working
tengo problemas de compactibilidad ente los istaladores de la hp 4110 all-line one con windows vista que hago
Feb 18, 2009 | HP Officejet 4110 All-In-One InkJet...
HP OfficeJet 6210 All-In-One InkJet Printer Logo
105 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
