Question about Tappan TGF320 Gas Kitchen Range
Tappan gas stove
When turning on the burners/stove...gas is coming through but won't ignite. And the stove plug is tripping the electrical outlet.
  • 2 more comments
  • HILLA Jan 15, 2008
    I HAVE THE SAME STOVE AND I AM HAVING THE SAME PROBLEM WITH THE PLUG TRIPPING THE ELECTRICAL OUTLET. WE TOOK THE CORD OFF AND HAD IT TESTED AND DETERMINED THAT THE PROBLEM IS IN THE STOVE BUT WE CAN'T FIGURE OUT WHERE.
  • Anonymous Feb 07, 2008
    When turning on the range top burners...gas is coming through but won't ignite the burners. I have to light them with a match from the top of the stove. The pilots are lit and and one of the burners lights with the turn of the dial but the other three do not. If the burners can be cleaned, How? If they can't and need to be replace, where do I get the necessary parts?
  • rich molster Aug 27, 2008
    igniters keep clicking even with the knobs turned off all 4 are clicking together
  • delbert913 Aug 30, 2008
    My burner on top of the stove will not ignite.
I had the same problem, and finally took the rings and the covers off of the burners. I used an old toothbrush to clean everything really good, and then used a vacuum ( or you can just close your eyes and blow really hard ) around the burners. If there is a build up of junk or if a pot has ever boiled over, sometimes junk can get lodged in the little igniter and this prevents it from lighting.
Posted on Jun 14, 2008
Tappan gas stove
Older gas stoves used a battery to ignite the flame but due to its age, I would get a hand held gas lighter.
Apr 21, 2017 | Kitchen Ranges
I have a magic chef oven model # 61S04PAW. the
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Jul 07, 2010 | Magic Chef 31000 Gas Kitchen Range
I have a tappan gas range all the burners but one works when i turn it on. You can hear the flow of gas, and the oven doesnt work. what could that possible be
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good "blue" arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Mar 25, 2010 | Tappan 24 in. Freestanding Gas Range...
The gas burners are not igniting when being turned on??? When the dial is turned the gas comes on but the burner does not lite - no clicking sound? Thanks for any help!
Feb 09, 2010 | Heartland 3635B Dual Fuel (Electric and...
None of the four burners will ignite when the gas is turned on. The electric igniters don't spark. The gas comes out and can be ignited with a separate butane lighter. I believe the electric power is on to...
Check that electric power closely. A boil over and attempted re-start or water (or other liquid) leaked / spilled into an igniter switch can trip your GFI outlet. Sometimes the outlet the cooktop is plugged into is fed from a GFI recepticle further " up stream " so you may have to look around to find a GFI which has tripped.
Feb 08, 2010 | Cooktops
Igniter keeps clicking ...gas all burners light, but clicking continues
Oct 06, 2009 | Tappan TGF320 Gas Kitchen Range
Tappan gas range electric pilots will not light
The gas line in your Tappan could be closed or
stucked up. Have it check.
Sep 23, 2009 | Tappan TGF320 Gas Kitchen Range
You have to light burners on stovetop with a match all the time.
The pilots for the range top are beneath the top of the range top. YOu will see them if they are there. YOu stove may use electronic ignition and you can hear the sparking when you turn the knob to the "light" position.
If it is electronic ignition, make sure the stove is plugged into an operating outlet
Apr 15, 2009 | Tappan MGF500PBW Gas Kitchen Range
Gas burners/electronic ignition
Jan 26, 2009 | Tappan TGF657 Gas Kitchen Range
Igniter "clicking" on its own...
new spark module. Most stoves use a common part.
Jul 25, 2008 | Tappan 24 in. Freestanding Gas Range...
Tappan TGF320 Gas Kitchen Range Logo
246 people viewed this question
Top Tappan Kitchen Ranges Experts
Paul Carew
Sal De
Craig Butler
Craig Butler
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
