Question about Kyocera CS-2550 Black and White Copier
Password problem my scanner will not scan to my PC, it is asking me for a password, i do not know the password.
    Problem Solver:
  • 3 Answers
A password has been programmed into the scanner setup , if you know how to enter setup just remove the password,check the authentacation setup and turn it off , if this doesn,t help email me @ gafxitmn@ cs.com for more details.
Posted on Jan 15, 2008
How do i setup scanner from my machine to my laptop? please start from step 1 including cable connectios and scan to folder instructions. I am using windows 8.1 pro
Before you even start, your machines "Network Support" firmware needs to be up to date to be able to connect to a Windows 8.1 PC.
Secondly your machine has to be networked. No USB scanning supported on Ricoh Devices. Create a shared folder on your C: drive called "scans". Share so "everyone" can access the folder. On the MP2852 select scanner mode and tap the block with "Prg Dest" on the screen. Select Folder and Browse for your PC. Enter your PC Username and Password when asked. Find your shared "scans" folder, select it and then tap OK on the screen. Next enter your name and save. You should be good to go. Keep in mind anti-virus and firewalls can block it. Also ensure your PC is part of a "Home Group" otherwise you will not find your PC when you browse from the MP2852. If your PC is not in a "Home Group" then you can just create a "Home Group" under your "Network and Sharing Center" and while you are there ensure that "Password Protected Sharing" is switched off under your "Advanced Sharing Settings" also found in your "Network and Sharing Center".
May 28, 2016 | Ricoh Aficio Mp 2852 B&w Copier
Username for scanner mode
look like the previous owner had a password for scanning , ask him
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 27, 2014 | Konica Minolta Minolta Di450 Di470 Di550...
I have Kyocera Mita KM-2050 Printer/Scanner. The machine has moved networks. I have setup the printing OK but cannot get the scanning to work. I have gone into the panel on the machine & changed the IP...
The NIC card will need to be reset back to the factory defaults if you do not have the user name and password.
If you contact me through www.gfbm.net I will assist you with resetting the scanner over the phone.
Once reset the scanner NIC you will need to re input the IP and all your other scanner information.
I hope this is helpful,
Shawn
Jan 31, 2011 | Kyocera Mita KM-2050 Printer
Brother 9840CDW won't scan/fax legal size pages from glass or ADF
Is a setting in the printer.
Go to start >Brother> start center> on top go to configuration. then it will ask you for a password. use "access" for the password.
click on general setup and you'll see document scan at the bottom.
Change it from letter to legal and apply.
Voila!
Sep 02, 2009 | Brother MFC-9840CDW Laser Printer
DS6608 scans encrypted barcode triggers print
You need to program the scanner through 123 sofware or by scanning specific barcodes. I can provide you with either or need. You can always contact me directly akowalski@legacyglobal.com or 630-622-2024 toll free 866-271-9891 Ask for Andrew
Jul 05, 2009 | Symbol DS 6608 Handheld
Copystar cs 305 scanner is not connecting to computer
I do not know much about the situation but, I'll give it a try. First turn the pwr off to the scanner and try to ping agian just to make sure you are not trying to use an ip adress that is aleady being used. You should not recieve a responce untill you turn the power back on but, if you do get a reponce while the scanner is off change the ip adress on the scanner. Next if that did not help, you will need a correct path to your computer from the scanner like example( \\server\public\scans ) next you will need a username and password to gain access to the shared folder..
Mar 30, 2009 | Copystar - CS-3035 Printer
Ricoh MP4000B
hi
a rijas working in dubai
my Gestetner MP 4000B nw its showing waste toner bottil is full please advice me how to solve dis problem
Feb 18, 2009 | Office Equipment & Supplies
Using hp scanjet 3970 Just loaded hp scanning software and the large install of the 3970 drivers. When I enter the program the scanner opens and scans te image on the tray. (I am trying to scan a...
Have you checked the cord from the scanner lid to the scanner base. if that doesn't work I would try uninstalling the scanner and then reinstalling it. It sounds like a problem with the twain driver for the scanner.
Dec 20, 2008 | Computers & Internet
Scanner password
HI there try the following.
  • Open Internet Explorer
  • Type in the address bar the IP address of the scanner (If you do not know this print out a status page)
  • Once you have typed in the IP address you will then have the scanner configuration screen on the left you should have passwords section you will be able to change it from there.
Hope this helps you
Thanks J
Jan 14, 2008 | Kyocera CS-2550 Black and White Copier
Kyocera CS-2550 Black and White Copier Logo
252 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Chris Schutte
Marvin
Marvin
Adorjani Laszlo
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
