Question about Canon i9900 InkJet Photo Printer
My I9900 is not printing
The light is constantly flashing from green to orange and there is no window that indicate the problem. I tried to print a PDF file and habitually there is no problem. I am on a Mac G5.
Mine does the same thing and I've been trying for months to fix it...will not print. I reccommend switching to Epson...better quality prints anyway!
Posted on Feb 18, 2008
Continuous orange light, how to fix/ turn on the printer ?
The constant orange light is the standby indicator. Do you have the correct driver for this model? Did you select the correct printer from the list of printing devices.
In Windows, often after installing a printer driver and software you'll notice more than one printer installed. But only one has a green check mark beside it (set as default device). If that is the one you want to use, then when printing make sure you select it. If you select another and it isn't set as the default device it won't print until it is set as the new default.
Generally from Windows if you're going to need to print something, after clicking the, "Print", button from the program you want to print from, it will open the print dialogue. Make sure the default active printer is set. Most printers come with software to access other functions. Some functions include status query and a cleaning print head option as well as print sample image/text.
For Mac's a similar procedure only there is no option to select from a variety of printers. If there is a printer installed, Mac's will try to send to that device only.
Aug 30, 2015 | Office Equipment & Supplies
Canon i9900 wont print, light keeps flashing green to yellow
Good Day,
Have you tried software update? According to this article, http://support.apple.com/kb/HT3669#epson, it says Canon has updated it's drivers via Software Update.
OR
f possible, spray some Windex in the heads and let it sit for, oh, 10-15 minutes. Then try to print. Any dried ink guck will be dissolved by the Windex.
Jan 01, 2010 | Canon i9900 InkJet Photo Printer
Canon i950 won't print
try this Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print (exit service for i960)
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter.
one by one
Jan 25, 2009 | Canon i9900 InkJet Photo Printer
Pixma i9900 orange light flashes 5 times
hi guys,
Flash in orange 5 times indicates that the printhead is faulty so that the printer cannot detect the printhead. Rarely, faulty logic board and carriage unit may cause the same problem.
Regards,
Source:
Canon Inkjet Forum
Dec 13, 2008 | Canon i9900 InkJet Photo Printer
I have a cannon i9900, it has always worked perfectly. For the past week I can not print anything. I reinstalled software today still down, I see one green light followed by 5 yellow flashes (keeps...
Dear Bill,
Flashing 5 times in orange indicates that print head error occurs so it cannot be detected properly by the printer. To make it sure, install a good print head in the printer. Is the problem fixed?. If the problem still persist, carriage part may be faulty. Overall, the print head is the most faulty part in this case. So, you need to replace the print head with new one.
Regards,
Source:
Canon Inkjet Printer Forum
Nov 28, 2008 | Cannon Office Equipment & Supplies
Canon i9900 Error reads as follows. Operator error. Press printer’s RESUME button. If this doesn’t clear the error, cancel printing and turn the printer off and then back on. I've cycled through...
there is something inside the printer, i have the same problem and that was it, a paper or something blocking the headprint to run from right to left
Oct 22, 2008 | Office Equipment & Supplies
Printer Problem
This was not the sollution for my pinter..
My Magneta is half full and my error led is also blinking 15 times
I found this service manual for the IP4200 but this methode also doen not solve my error led..
Is their someone who has the sollution for this strange error?
1) With the printer power turned off, while pressing
the Resume/Cancel button, press and hold the Power
button. (DO NOT release the buttons. The Power LED
lights in green to indicate that a function is
selectable.)
2) While holding the Power button, release the
resume/Cancel button. (DO NOT release the Power
button.)
3) While holding the Power button, press the
Resume/Cancel button 2 times, and then release both
the Power and Resume/Cancel buttons. (Each time the
Resume/Cancel button is pressed, the Alarm and
Power
LEDs light alternately, Alarm in orange and Power
in
green, starting with Alarm LED.)
4) When the Power LED lights in green, press the
Resume/Cancel button the specified number of
time(s)
setting) (THEN HIT THE POWER BUTTON >AFTER THIS< TO SET).
Time(s) LED indication Function Remarks
0 times Green (Power) Power off When the print head is
not installed, the carriage returns and locks in the
home position capped.
1 time Orange (Alarm) Service test print .
2 times Green (Power) EEPROM information print
3 times Orange (Alarm) EEPROM initialization
>>>>>>>>THIS ONE
4 times Green (Power) Waste ink counter resetting<<<<<<<<<<<<
5 times Orange (Alarm) Destination settings After
entering the destination settings mode, press the
Resume/Cancel button the specified number of time(s)
to select the destination. For detail, see
"Destination settings procedures" below.
6 times Green (Power) Print head deep cleaning
(Cleaning of both black and color)
7 times Orange (Alarm) Reserved
8 times Green (Power) CD / DVD check pattern
9 times Orange (Alarm) CD / DVD print position
correction (horizontal: X direction)
10 times Green (Power) CD / DVD print position
correction (vertical: Y direction)
11 to 13 times Orange, Green, Orange(Alarm,
Power,Alarm) Return to the menu selection
14 times Green (Power) Left margin correction Not used
in servicing.
15 times Orange (Alarm) Return to the menu selection
Time(s) LED indication Destination CD / DVD print
0 times Green (Power) No change of the destination
1 time Orange (Alarm) Japan Supported
2 times Green (Power) Korea Not supported
3 times Orange (Alarm) US Not supported
4 times Green (Power) Europe Supported
5 times Orange (Alarm) Australia Supported
Oct 30, 2007 | Canon PIXMA iP4300 InkJet Photo Printer
Canon i9900 InkJet Photo Printer Logo
103 people viewed this question
old marine
old marine
