Question about Kyocera CS-2550 Black and White Copier
Scanner password my kyocera copy star 2550 has a passowrd set to scan documents to the PC, this is an old password that no one in my office knows. is there any way to reset the password??
  • 417 Answers
HI there try the following.
  • Open Internet Explorer
  • Type in the address bar the IP address of the scanner (If you do not know this print out a status page)
  • Once you have typed in the IP address you will then have the scanner configuration screen on the left you should have passwords section you will be able to change it from there.
Hope this helps you
Thanks J
Posted on Jan 16, 2008
  • pravin bhappa Feb 26, 2013
    user id and password forgeted how to reset userid and password
6ya staff
SOURCE:
How do you install new e-mail addresses on scanner for kyocera km 2550
Open the browser on your computer, type the Ip address of the scanner on the address bar, the page of the scanner will open, under scan to email destination, you can add or remove accounts.
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Dec 01, 2011 | Kyocera Mita KM-2550 All-In-One Laser...
I am trying to set up newtwork scanning on our Kyocera KM 2550 multifunction machine and I can't find in the manual how to do it?
cool... ok here is what you do goto usa.kyoceramita.com then downloads... then where it says choose product... choose legacy copier then choose product then... where it says select subcategories... select manuals you need the scan system f operations guides both the setup and functions editions...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Dec 22, 2009 | Kyocera Mita KM-2550 All-In-One Laser...
Km-2550 fax machine stays busy for long periods while it has document in memory and is communicating. The product is not a Lexmark, its a Kyocera KM-2550, but thats not a choice so...
1.....connect a regular fax to the line and see if you get the same response if you do then its a phone line issue... ... now lets troubleshoot...plug a phone in and pick up the reciever... listen for static on the line... if there is static... that can cause issues... call phone company... also if its voip... that can cause issues... if so tune your voip or get filters and this might reduce it... and possibly eliminate the issue.... if not... then i would call a kyocera tech and have him update the firmware for everything on the machine... printboards... scanners, fax... main system and if it keeps happening I would replace the fax board... still happening replace main board...
Oct 19, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Copystar CS-2550 Set up add'l scan folders - need to reset psswrd
The password is 6482, this is the admin password for all copystar machines.
Thanks for using Fixya
May 20, 2009 | Copystar CS-2550 All-In-One Printer
Scanner
to be able to scan to pc you have to have the scan file utility set up on the pc
the scan file utility is on the CD that came with the copier.
you can Google the file if need be
when you have loaded the file you will need to go to
start, all programs,kyocera (scanner file utility and open it
once in configuration you will need to do the following
select setup
on the top you will see a box, type in 001
file destination, you should hit the box next to this and select kyocera/scan file
press ok and you are done
Next
get the ip address of the scanner, you will find this in scanner default when you have pressed thecounter/system menu button
get back into normal copy mode
on your web browser type the scanner ip into the address bar and you will get into the scanner command center
press the start icon bottom left of your desktop, go to run and type in cmd
once in dos mode type in ipconfig, this will give tou the destination address for your scans
now back to the command center, select sender info (left side menu) and type in kyocera after selecting 001 (blue numbers) and submit
then go to destination setup (scan to pc) and under 001 (blue) enter the relavent info, the address will be your pc's ip address.
say no to all password requests
and submit
very important now is to close the browser as you cannot scan when the command center is open
please take the time to rate this fix
Mar 27, 2009 | Kyocera Office Equipment & Supplies
Can't print on Kyocera km-2550
I have an HP 1350 all in one printer/scanner. It was printing fine until I wanted to scan a document. I pressed the scan button and now its stuck there. I can't get it out of scanning. I tried turning it off, unpluging and replugging. Can you help me.
Feb 06, 2009 | Kyocera Mita KM-2550 All-In-One Laser...
Scanner - memory is full
A KM-2550 has 64 MB RAM built in. I believe less than 30 of it is for image storage. You may be able to lower your scan resolution.
Best solution is to add more memory. Look for a Kyocera compatible 100 pin dimm (don't buy from the manufacturer). It will read 16 MB to 256 MB sticks. You have to take out 6-8 screws holding on the part of the back the sticks out on the upper left. Make sure after installing you print a status page to make sure the memory was recognized.
Mar 27, 2008 | Kyocera CS-2550 Black and White Copier
Scanning problems
reload your driver that came with the printer,be sure to go to properties and select shared.Although the print and scan functions use the same network cable they have diferent IP addresses and the driver software assighs the IP for scan funtion.
Mar 03, 2008 | Kyocera CS-2550 Black and White Copier
Password problem
A password has been programmed into the scanner setup , if you know how to enter setup just remove the password,check the authentacation setup and turn it off , if this doesn,t help email me @ [email protected] cs.com for more details.
Jan 14, 2008 | Kyocera CS-2550 Black and White Copier
Scanner will not connect to PC
Make sure that the scanner file utility is running on the computer you are scanning to. Go to Start - Programs - Scanner User Software - Scanner File Utility. It will open in the system tray by the clock on the PC. Try to scan again. If still have the same error, go to the webpage of the scanner (just enter the IP address of the scanner NIC in Internet Explorer. Go to the bottom left side of the page and click Scan to PC Destination List. Click on the number to the left of the name you are scanning to. check the IP address listed on the webpage and make sure it matches the IP address of the Computer you are scanning to. One of these should fix it.
Please remember to rate you answers.
Dec 28, 2007 | Kyocera CS-2550 Black and White Copier
Kyocera CS-2550 Black and White Copier Logo
518 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Marvin
Marvin
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
