Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Ice melts and leaks out of the front of through the door Ice dispenser
The top of both the refrigerator and freezer is warm and the bottom of both freezes. The Ice melted and leaked out the front.
Is this a problem with the controll module?
  • Anonymous Mar 19, 2014
    ice melted, hot air in freezer and in top
    Passionate:
    Visited the website for 10 consecutive days.
  • 106 Answers
Sounds like a bad fan motor.when you open the freezer,can you hear a motor running or not?
Posted on Jan 14, 2008
Ice Melting towards the front of the ice hopper
Check that the fan motor wiring has not been disturbed. If the freezer fan is not working, the fridge will generally start cooling but due to poor air circulation , it will stay colder at the back but will get warmer at the front hence causing the ice to melt. The usual temp for a food compartment is around 4 degrees. The freezer should be -18 degrees celcius.
Nov 25, 2013 | Electrolux EI28BS56IS (278 cu ft) Bottom...
Top drawer of freezer seems to work but large bottom drawer not freezing even at -5degrees. Can this be fixed?
This problem seems to be two sided. A refrigerator defrost it is supposed to take the water from defrost down a pipe located behind the freezer rear wall to a pan below the refrigerator where there is a fan blowing warm air over the water to evaporate back into your home or business. If that drain is blocked your refrigerator will accumulate a large block of ice and frost behind the rear panel of freezer and temperatures will warm considerably in fresh food compartment and freezer. Here is one site I want you to read over=> Leaking Refrigerators Just What may Be Happening and here=> Leaking Refrigerators here is a link to a service manual=> LFX25960xx Service Manual Let me know if this service manual is close enough to your model number. At this point I am looking for air blockage behind the rear panel of freezer. If air is being blocked by ice and frost you can use a hair drier to help speed you up while melting ice. If drain is blocked use whatever you can to open the drain line mentions on the links I sent you to and let me know what is found, Thanks Sea Breeze
Feb 18, 2012 | LG LFX25971ST Bottom Freezer French Door...
Freezer & Refrig does not get cold
without a model number to check out what else might be in that area of the door i'd say a piece of tubing from the water source is leaking, or you are getting ice melt from inside somehow making it out through that panel now. i believe the water for the door comes in through the bottom of the freezer door and works its way up to the dispenser area, the solenoid for the water inlet is behind the fridge near the bottom (you'll see the water tubing).
more likely somethings just not fitted or aligned properly and waters making it out someplace it shouldn't.
best of luck to ya
May 27, 2010 | Frigidaire FRS26H7CS Side by Side...
Our subzero freezer has a new problem. The cubes
Ice cubes WILL BE slightly moist when they land in the ice bucket. they've just been slightly melted in order to eject from the ice maker. Stop playing with the settings, for starters. put them back to normal, i.e., middle setting, place thermometer in center of freezer, and if you can, one in center of fresh food. monitor after 24 hours, and for the next three days thereafter. freezer temps should be in the -5 - +5°F, sometimes up to 10°, fresh food should be 35-40, sometimes up to 44°at the normal settings. If you are not having temperature issues, see if you notice any frozen drips of water on the underside of icemaker, indicating a possible crack in the ice maker mold, or a faulty water valve. You didnt include your model and serial number, so not knowing the path of the ice shoot, some go out the freezer door, some slide over and get dispensed from the fresh food side. Its possible you may have a problem instead with the flapping door that opens to allow ice cubes to be dispensed, or similar type mechanism. If this door does not seat completely when its closed, it will leak warm air directly into the ice bucket, which would make them slightly moist, also too, this warm air can cause frost and ice to buildup near the warm air source...look for any unusual forms of ice and or frost leading up from the flapping door to the ice bucket. Also look for any gaps in the door gasket when closed, this warm air leak can also cause similar problems, but its most likely with the ice door. could be the door, the spring, the solenoid, or something else i wouldn't know without personal refrigerator inspection.
Mar 27, 2010 | Freezers
Hi freezer on american style fridge freezer is
there is a defrost mode that melts any frost or ice on the evaporator coils and drains it into a pan under the fridge. if that drain is blocked, the water will pool inside. also check the door seals. if warm moist air leaks in, it'll condense on the cold interior and pool as well.
Nov 10, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool ultraease refrigerator (ED7FHG) making water sounds, and drips water onto steel pan in bottom rear of freezer side. Purchased new. This is an obvious change. Problem?
You have a water leak somewhere (I'm assuming this water sound is constant). If not write me back for other possible solutions.
The only place water comes into the freezer is for an ice maker or a door water dispenser. Check around the ice maker for a leak. If there is a water dispenser in the door then check the piping to it also.
There is a drain in the bottom of the freezer compartment which is there so when the frost is melted by the defrost heaters, it has somewhere to go. This drain drains into the "drip pan" (or condensate pan) in the bottom of the unit. Here the water will sit until it is evaporated into the air.
If this helps you, please select YES to the first two ratings questions. Thank you, and Good Luck.
Oct 13, 2009 | Whirlpool 21.7 cu. ft. Top Freezer...
Magic Chef Side by Side MOdel RC224RDA
I have the same problem. It turned out to be a problem with the doors. When my kids go to get a snack and close the fridge door (read slam the door) the air pressure pops the seal open on the freezer door causing the ice cubes to begin melting. The bottom items stay frozen (warm air rises). It took me a long time to work this out.
Remove the ice maker tray. Remove the ice blob, being careful to put the u-shaped wire ice-level sensing wire thing, in the up position or the system will dump ice and water all over the freezer. Put all back clean and dry and buy a velcro adhesive strip and install it on top of the freezer door to prevent the door from always blowing open.
Hope this helps
Jul 03, 2008 | Magic Chef (CSD2610KRW) Top Freezer...
Hotpoint Side by Side leak and cooling issue
fault is poss that drain for defrost water is blocked and this can cause both faults. remove back cover of freezer and check if ice build up. if so melt of with hairdryer and make sure drain is also free of ice
Feb 15, 2007 | Hotpoint HSS25GFP Side by Side...
Leak from icemaker shorts electricity in house
It sounds like the ice in the bin is warming up enough to melt for some reason then re-freeze. Check your door gasket seal and also the ice chute door flapper seal to make sure warm room air isn't being drawn into the ice bin area. Also make sure the freezer area is VERY cold like 0 degrees F or lower, that will keep the ice hard and help stop the ice from having a liquid surface film from opening and closing the freezer door too often (then freezing again). The water down the back is from the ice cubes melting a little then re-freezing. Also, is the frige working OK? Does the compressor turn on and off normally? I ask because sometimes the compress start device is failing and the refer can warm up quite a bit while the compressor is trying to start up... eventually the compressor will start but by then the ice has melted a little then the compressor runs for a long time to bring the temps down again. Monitoring with a thermometer every hour will show if the temps are lowering in the freezer section too much.
Dec 10, 2006 | Maytag MZD2669KE Side by Side Refrigerator
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
70 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
