Question about Electronics - Others
Trutech digital photo frame
Help! Do you need to leave the usb flash drive IN the digital photo frame to see all the photos? I can't seem to download the pictures from my flash drive onto the frame. Thanks for any advice.
dabolger@gmail.com
    Master:
  • 788 Answers
Most digital photo frames do not have internal memory and require external media to be plugged in permanently. Only the expensive ones have there own memory and usually not a lot.
Get an SD card and move your photos to it, that way you won't need to have the USB drive sticking out of the frame. That's if the frame has an SD slot.
Posted on Jan 14, 2008
I just bought a digital photo frame for my husband for christmas and i get so many pictures downloaded...then it just stops and says insufficient memory card.....i thought there was something wrong with...
I'm pretty sure this means that you have filled up the internal memory on the picture frame.
I just bought my sister a photoframe for Christmas (made by Phillips) and we got the same message. Not the most precise wording on the error message, but we tried deleting a few photos and the error went away. Then I checked the internal memory of the frame, and it is only 128M, which is not alot of photos.
I think the solution will be to buy a USB memory stick to leave in the frame. For about $10 you can get a 4G USB memory stick, which is about 32 times the space of the internal memory, at least if you have a similar model as we do.
See here: http://www.amazon.com/USB-Flash-Drives-Storage-Add-Ons/b?ie=UTF8&node=3151491
Dec 23, 2010 | Philips Cameras
Trutech Digital Photo Frame
Image quality using default factory settings is awful. Colors are over-blown, faces are washed-out, and highlights are cropped. People on the internet compained that there is no brightness control -- there is..but its hidden in a menu. Press the Setup button on the remote and move to the "System" settings. I've found these settings produce a fairly correct balance of color, detail, and brightness:
* Brightness=5
* Contrast=1
* Saturation=2
Mar 31, 2008 | Electronics - Others
How to send photos from laptop to digital photo frame
The photo frame will either have a card slot or a USB connection on it. If it has a card slot you will need to connect the card to your compuer first (through a card reader) and download the pictures onto it. Then put the card into the photo frame.
If it has a USB connection, you can use a usb flash drive - first plugged into your computer to download the pictures then plugged into the photo frame.
It is also possible that the photo frame has internal memory - in which case you would connect the frame to your computer directly using a USB cable. It would them show as a "Removable Disk" and you can download directly to it.
Nov 04, 2009 | Office Equipment & Supplies
Can't get frame to read files on USB flash drive
keep the drive you use to 2g or 4g max.for some reason a lot of the cheap frames cannot handle anything bigger.
Mar 29, 2009 | Nextar N7 - 7 Digital Photo Frame with...
Quantaray 5.6 Digital Photo Frame not working properly
Maybe if you were to calm down and approach the situation calmly, you could figure it out. Or, or course, you could try looking in the manual - that often helps.
Mar 13, 2017 | Quantaray 7-Inch Digital Picture Frame -...
Order of photos
Hi, u need to arrange the photos by size or by alphabetical order in your desktop first, then u need to transfer it to ur pendrive, then plug it to ur device everything will b fine then. Rate the soln dude plz n tell me what happened
Jan 25, 2009 | Electronics - Others
Transfer pictures
Plug the frame into the usb slot on your computer. Open up the folder with your pictures on it. Then open up my computer and look for the drive that is the frame. Drag your pictures right to the frame,s drive.,
Dec 13, 2008 | PANDIGITAL 7-Inch Digital Photo Frame with...
TruTech 7 inch digital photo frame
Setup Menu>Custom Setup>Repeat Mode>All
Jul 22, 2008 | Electronics - Others
Trutech 7 Digital Photo Frame.
Try a new unformatted SD card (now they are around $10/1GB).
Jan 12, 2008 | Tao MUSIC SPECTARE 5.6 DIGITAL PICTURE...
7" Trutech digital photo frame
I don't have the booklet for this darn thing and I just got it for mothers day.... I have a sandisk in it and I can see the pics just fine, but it doesn't save them??? I can only view when I have something in it??? That's crazy?? Isn't it?? Help
Dec 29, 2007 | Tao MUSIC SPECTARE 5.6 DIGITAL PICTURE...
Electronics - Others Logo
181 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
